Question about LG Washing Machines
My front-loading washing machine isn't getting our clothes clean.
This machine appears to be very short of water as it reverses slowly back and forth, and over time our white clothes--like new T-shirts--are getting dingier and dingier. When we bought the machine, it was top-rated, so maybe it's just not set up correctly.
  • LG Master
  • 19,396 Answers
Check the water supplie and the water level floating sensor.
Posted on Nov 20, 2008
  • Ginko
    Ginko Nov 20, 2008
    Check if there is enough water coming from the hose attached to the machine.
    There is a valve called the inlet valve, see diagram below, check that the inlet valve is clean.
    There is a also a water level switch that is a sensor that can stop the water flow, that can also be the problem.
    Start checking the water supply hoses, usually they are cause of similar problems.
    Front Load Frigidaire/GE/Kenmore Style
  • prem mathew Jul 01, 2012
    Most machines today hv low levels of water for conservation. As a short term solution you just have to add a liter of water via the soap drawer while it is filling up for the initial run, that is after the soap has washed down.
    See that the inlet valve is open fully, and that you hv good pressure. Cleaning as how Ginko has explained; with an old tooth brush.
Front load washer, try to spin, but stops altogether and want wash it fills up but want wash
Make sure that you don't over load the washer. As it starts to spin back and forth it is sensing the load balance as the clothes fall back and forth. If it doesn't sense a balanced load because the clothes can't fall back and forth it will not start the wash process. Refuse your load and try again.
Oct 16, 2013 | Frigidaire GLTF2940ES Front Load Washer
I have a MHWE500VW11 and I hate it! It doesn't get the clothes clean. Give me my old top loader any day. I have to over wash everything on steam clean and it's killing my clothes. I do more dry...
One thing to check is the capacity of the machine. If you used to have a top loader you may be used to packing more clothes in, and the front loader may not be able to clean the same capacity.
Your manual should indicate the maximum weight of clothes for each kind of load. For example a 40 degree mixed load should usually weigh less than a 40 degree cottons load.
If you try washing less in each load you should find your clothes get cleaner.
Jul 25, 2011 | Maytag EPIC MFW9700S Front Load Washer
Hi can you tell me which programme is the short wash and spin please
I think I have the same type of washing machine as you do. Wash is when all the clothes get agitated or mixed with soap and water (ever look in there when its washing? the water can get pretty gross looking!) So in my washer, the rinse cycle is when all that gross water is drained, and the washer spins while spraying clean water over the clothes to get rid of the dirty water and soap. I think mine does this 5 or 6 times in the cycle. Next is the spin cycle, which is when the washer spins REALLY fast to **** as much water out of the clothes as possible, so that the clothes aren't sopping wet when you put them in the dryer.
It sounds like your mom has a newer washing machine, probably a front load one, and they do seem to keep using clean water, instead of just agitating the clothes in dirty water.
May 17, 2011 | Electrolux EW1000i Front Load Washer
Clothes have "dirty dishrag" smell after washing
If you open the door of your Neptune, you'll notice a small trough between the door gaskets (inner and outer) There is a drain at the bottom that can get blocked by lint and other funky stuff. Next time you do a load of towels, take a small dirty towel and wipe that area of your machine out real well. Secondly load a slightly smaller load in your machine. Be sure to use a HE compatible soap...less foaming- it does make a difference.. Also the swishy slushy sound is normal and there is liquid in the drum for balancing...it's normal.. I think with a clear door drain, a bit smaller load .you'll find it won't be smelly.. I've got one of these and the only time it gets ordoriforous is when I've jammed it to max capacity. Let me know if all this helps you out. k
Jun 08, 2009 | Maytag Neptune MAH5500B Front Load Washer
Dirt left in creases after washing clothes. Clothes never look clean
Too many clothes in the load , if it says 5lb then that is the maximum you should fill it with otherwise the clothes do not seperate as they are being agitated
Also
Not enough detergent (Try the old powder types)
Hard Water area (Use a small amount of Washing Soda)
Water level too low , use add water button if fitted
May 21, 2009 | Fisher and Paykel GWL11 Top Load Washer
Thumping hitting front stops on wash cycle.
if it was not NEW and under warranty, you bet i would ask for your paid service in heartbeat.
the repairman is arriving finally tonight.i will update what he finds.
Apr 05, 2009 | GE Washing Machines
Water backs up into washing machine after washing a load.
check your drain hose and drain pipe,if not that then i think your inlet water valve is not closing all the way,try it on cold only see what happens,then try on hot only see what happens,let me knoe what you find-mike
Jul 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Frigidare front load washing macine leaks water
Sounds like the dispenser is leaking somehow, there is no filter that would cause it to leak. Remove lid of washer by screws on back lip and inspect during fill to see where leak is.
Jan 20, 2008 | Washing Machines
Creda machine won't agitate with clothes in it
Your load is prob to heavy for the older washer. it just doesnt have the power to handle it no more. time to replace it, sorry.
Jul 30, 2007 | Creda W120VW Front Load Washer
Washing Machines Logo
56 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
