Can't view all my channels on LXI series TV
I have basic cable with channels from 2-99. I can not get to the channels between 46 and 93. I have an old LXI series TV that I don't have a manual to. I guess I need to know how to program the TV. The only buttons it has are audio, picture, tv/av, catv, prog, obc, down arrow, up arrow, mono, stereo/L2,add/erase. I've tried many combinations of prog, add/erase, and the arrows to add the other channels. The back of the TV says the model number is 562 plus alot of other numbers.
  • 2 more comments
  • Philip Link Mar 22, 2009
    I have a LXI modal 564-42351650 .
    Channels 47 - 98 are missing.
    Also time display is missing.
    Please help!
  • Anonymous Mar 28, 2009
    want get past channel 46
  • brossman Apr 17, 2009
    I can't get 48-94 to display either. How to reset this? I don't have the original remote and there is no menu, set up or program button. I have the 1988 series 20 squareview model # 564-42152754. Thanks!
  • Andrew Atwood May 26, 2012
    I no longer have this tv
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
For anyone with a set with this problem that is older----IT DOES NOT HAVE THAT PART OF THE CABLE BAND BUILT INTO IT--only solution is either to put a cable box to it or buy a new set.
SD TECH
Posted on May 27, 2012
2 Suggested Answers
SOURCE: TV will not get cable channels
If you have it hooked up to a digital box, it shouldn't matter if the TV is on cable or antenna mode. The only thing that matters is that the TV is on channel 3. Channels will be changed on digital box. Some newer TV's use input 1 or 2 or AUX for it to work. If I were you i would hook everything up and start playing with the channels going up and down until you get a picture.
Posted on Apr 21, 2007
Antenna not working anymore?
talk with a tv technician as to the capabilities of the tv set but you may need a better outdoor antenna if the signal has changed from am to digital or fm in your viewing area
Jan 20, 2016 | Westinghouse Televison & Video
RCA TruFlat 27F520T 27
Just check this TV by connecting it to on-air programs. Connect external antenna to it, and make an auto tune function. Refer to its user manual for details. If TV do not tune in to on-air channels too, the tuner to your Tv should be checked and replaced. If it receives on-air channels, and only cable channels are missing, you must contact the service provider to your cable connection.
Jun 19, 2012 | RCA TruFlat 27F520T 27" TV
My cable channels dont work only 52 53 &54 series Lxi Tv
Try connection with a cable box that uses the audio/video output jacks and connect to a similar input on rear of set---you may have a bad tuner in the set and going via the AV jacks from a box to the set will bypass that.
Jun 10, 2012 | Televison & Video
Cannot connect to DVD player
Use channel up/down. Hit channel down below channel 2, will be your video inputs.
Nov 24, 2011 | GE 27GT271 TV
I have a LXI series 13''tv,no manual-can't program channels
in menu switch the language to english, then find the channel setup feture under that there should be an auto search option run that and it should setup ypur channels
Sep 10, 2009 | Televison & Video
Lost some stations on my Sony lcd TV.
It is most likely a signal issue. Bad coax connections, splitters and faulty cable are usually the culprit. Best to call your cable company and request a signal test. You may also try swapping tvs. Swap sony with viewsonic in the room where viewsonic tv is.
Jul 03, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Add or delete channels on LXI tv
I have a Phillips LXI 46in TV. How do you save channels?
Jun 15, 2009 | Philips TP2784C TV
Suddenly SNOW on all channels
your tuner has failed;
time for another set the cost to repair is too high
May 29, 2009 | Televison & Video
No remote on LXI series TV
I PURCHASE FROM A TV FROM A SALE AND I CAN'T HOOK UP THE DVD PLAYER AND I DON'T HAVE A REMOTE. THE OPT ARE CABLE AND AIR AND NOTHING WORKS WHEN I SWITCH IT OVER LIKE MY OTHER TV HELP.
Jul 31, 2008 | Rio Go Video DDV9475 Dual Deck VCR
Televison & Video Logo
388 people viewed this question
Top Televison & Video Experts
