Question about Sanyo DS20930 20" TV
Cant get to input. front or back
My remote recently stopped changing my sanyo tv to front or rear input. i cannot use the channel up or down option to change to the input channels. this is frustrating because it was working perfectly a week ago. i thought it was my remote at first so i exhchanged it for the same type, that mind you was working properly before, after an annoying process of programming it i still failed to change to the inputs. this is most annoying and i would love some help with this problem. the remote is a rca universal remote if that helps any, but remember the old remote and new remote both will not change to input. this was working before. another oddity is that on the remote the input button seems to be the info button and the info button is useless as far as i can see, some of the other buttons are messed up as well. one of these remotes worked perfectly before and the problem started then the new one did the same exact thing.
Add the device with your universal remote. if you are trying to view a dvd or vcr this will work. just enter the code for the device manufacturer as you would with your tv, but if you have a gaming console, getting to input is tricky, and often times does not work with most tv's
Posted on Feb 04, 2011
  • 81 Answers
A lot of universal remotes will not work some tv's. It sounds like you may have to replace the remote sensor within the tv.
Posted on Dec 15, 2006
Won't channel up and down, stuck in input mode
Good morning Cheri
try restarting the tv, just disconnect all electricity for 30-60 sec.
connect again. If that does not work, Try set- up on the menu, if you get the apparatus to obey you and leave the input mode.
If that does not work I always restart the router and "exchange"box,
enjoy your day
kolbrub
Mar 25, 2014 | Sanyo DP50749 50 in. Plasma TV
How to change input on tv without a remote
Which TV do you have? Some will have an Input or Source button on the front panel. A few will have an option to change the source from the menu. Both of these options require the front panel lock to be inactive.
A few older TVs allowed you to find the A/V input by pressing Channel Down on the front panel buttons until you passed channel 2 (or Channel Up until you nearly reached Channel 2). This option wouldn't work if the A/V inputs had been deleted when someone minimized going through unused channels.
If the Source or Input button was only available on the remote, you will need a universal remote that includes this feature. These cost a bit more than the lowest end remotes. Then you will have to try all of the codes to find the one that makes the Source button work with your TV. (Several codes may work for On/Off but not the change input.) The Universal remotes that can be programmed from a computer (USB connection) will be the easiest to set up. Remotes.com may have a replacement original or substitute remote for your TV that should work for all of the TV functions.
I hope this helps. Please add a comment with the TV make and model for specific options for your particular TV.
(low end TVs usually only had the Source/Input button on the remote.)
May 12, 2012 | Sony Televison & Video
Getting a specific channel on the TV without using a remote
Usually if you go into the setup menu, there is an option to allow you to either "scan" for a channel, or "input" a channel. In this case, select "input" and see if the TV will allow you to press the up and down channel buttons and go to a specific channel. If so, when you get to channel 4, press the "add this channel" option (or whatever the menu option says) and you should then be able to go to channel 4 using the buttons on the front without skipping over it.
Jan 24, 2010 | Televison & Video
Change input without remote
Go to menu on front of tv, scroll down to source/input heading.Use the volume or channel select buttons to change the source
Sep 14, 2009 | Sanyo DS20930 20" TV
I have a rca dvd recorder+vcr combo drc8320n i want to set up watching/changing cabletv channels on the dvd remote. i have tried buying universal remotes cheap& expensive but they no longer work on my
With cable input connected to "RF in"on rear of unit make sure vidoe input is set to "Tuner". This will show up on the TV screen. Change channels numerically or using up/down arrow keys on DVR remote. Note there is a slight pause between changing channels.You probably will have to "autoscan" for channel setup/etc. If you say your TV set is old; it probabaly is equiped with coax
connection only/set TV channel to "3" or "4". when yot opt to play vcr/dvd it will override your
cable channel selected. Hope this helps!
Apr 13, 2009 | RCA DRC8320 DVD Recorder/VCR
I cant change my TV from Input to output...
Quick fix - Should be an "Input" button on the TV itself that can be used to switch between inputs. Depending on model of TV, this may also be done by going to channel 3 then going down to see if it cycles through inputs.
Other than that, may want to try another universal remote that has a "TV Input" button on it.
Mar 19, 2009 | Sanyo DS31590 31" TV
No remote-
Have you bought a universal remote for the tv? That is what we had to do to get to av mode and when you do make sure you try the input button before settling with the first code that works. We stopped at the first code that changed the channels and still could not get into av mode. Finally I tried the rest of the codes and found the correct one. HOPE THIS HELPS
Aug 10, 2008 | Sanyo DS27820 27" TV
Input problem
If you have the original remote, hit video, source, or input button, if it dont have them, then try to change the tv to channel 00 (zero or zerozero), if not then the channels might have to scroll to it, from channel 02 down to make it loop, if it goes to the next highest channel, then you need a remote. It may be set in the menu options to have the video source not saved to your list of saved channels. when you scan the channels, the tv might not look for the A/V source (audio / video), maybe just the RF source. The 3 DVD RCA wires are 1 video and 2 stereo, one stereo for left and one stereo for right. The TV has only 2 , 1 for video and 1 for mono 1 channel sound. This wouldnt have anything to do with why you cant use the DVD player. but try that with the original remote (or a universal remote that is set to your tv set that has either video, input, source or something similar. It is what tells the tv to change from the cable source (RF) and the AV source (the Red White and Yellow plugs, in your TV's case, 2 plugs, one yellow and the other either red or white or something). Dont really know how to explain it much more but hope it helps.
Jan 05, 2008 | Sanyo DS24205 24" TV
DS24205 TV INPUT PROBLEM
if you have a sky remote or know someone who does you could try programming it by using one of these codes, try them all one at a time
Sanyo 0159, 236, 073, 100, 064, 174, 185, 367, 039, 245, 246, 398, 241, 572, 583, 037, 132, 182, 244, 191
SANYO DS32224
I have this problem as well..have tried many universal remotes..still cant access menu options
Dec 02, 2007 | Sanyo DS31520 31" TV
Sanyo DS20930 20" TV Logo
297 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
