Question about NetGear WGR614 Wireless Router
When I have not accessed internet from my laptop through netgear
A 12 hr period i must disconnect power supply to router to access internet,Thi happens constantly .Is myrouter broken?It gets extemely hot Please advise a solution
  • 854 Answers
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
Posted on Sep 16, 2009
I have NetGear (WGR614v7) Wireless Router. 1st thing i couldn't access internet...while making the connection mistakenly i put different WAN IP now i got huge problem. setup wizard in not opening so what...
Using a CAT5 cable, connect your computer to the router, disconnect the power supply from the router, and hold the reset button for 10 seconds. Then reconnect the power cord, and open the browser on your computer. Type in the address www.routerlogin.net and press the enter key. This will take to the main setup menu. Set up the router as you wish. To secure your router connection, vist these websites: http://www.labnol.org/internet/secure-your-wireless-wifi-network/10549/ and http://www.practicallynetworked.com/support/wireless_secure.htm. Hope this helps! For more info on your router, go to http://support.netgear.com/product/WGR614v7
Oct 26, 2013 | NetGear WGR614 Wireless Router
Http://192.168.1.1/error_page.htm?flag=2
Ewwww ~ man! That's a sled and just in time for Santa too! PLEASE don't waste any more time with that old dog...
For $15 (INCLUDES SHIPPING) get one of these ROCKET SHIPS! A deal I could NOT resist ~ I just received TWO today. Mine are SO clean I'm going to order TWO MORE and resell them... I 'see' what the photos look like, but mine look GREAT!
Sale! NETGEAR Smart WiFi Router Model R6300 eBay: 112692810878
This guy is a SUPER FAST shipper too!
*NOTE ~ a Power Supply is NOT provided
So just order one of these:
Motorola 12 Volt 3 AMP Supply for $5.95 here (Includes shipping ~ USA SELLER)!
eBay: 253075543498
HONESTLY, it took me LONGER to find a spare CAT-5 Cable than it did to setup! It actually almost setup itself... but I changed a few things like passwords, WiFi names and a few other things!
Just for testing, this is the THIRD Router connected to my Spectrum Internet Router (also owned by me)... Right now I am using WiFi ONLY (as I type now) from my R6300 and trust me ~ my Internet ACCESS SPEED is 'transparent'!
Sale NETGEAR Smart WiFi Router Model R6300 eBay
Motorola 12 Volt 3 AMP Universal Power Supply Standard AC
Adapter 12V 3A...
Aug 04, 2013 | Gateway Wireless-B Router (wbr-100)
How do i secure wireless net work its shows local only
Hi if it shows local only means you not connected to the internet and only you can access your network make sure you apply wireless password to make your network secure check the WAN cable which directly connect to your NetGear DG834G Router you can disconnect that directly connected to your laptop and see if you can access the internet should you need any other help please contact me on my weblog http://computernetworksupportindubai.com/
Jul 22, 2011 | NetGear DG834G Router
All three of our wireless laptops stopped getting internet access
Have you checked to see if your wireless router has the latest firmware updates from NetGear? If not, go to netgear.com to get the latest updates. This can also be accomplished in the router remotely.
May 03, 2010 | NetGear WNDR3300 - RangeMax Dual Band...
I can't access the internet via my Optus Netgear
I am having exactly the same problem. It occurred on Sunday 17th. I have phoned Optus who seem unable to work out what has happened. It will work wirelessly but not recognise it when set up via ethernet cable.
Jan 17, 2010 | NetGear CG814M Wireless Cable Modem...
I have a wireless router (netgear rangemax) and had my laptop connected to it. I connected my ps3 to the internet and now i cannot get internet connection thru my laptop. my network says i have...
If nothing was changed in the router after connecting your PS3, possible that the devices are not syncing properly. Do a power cycle. Turn of all of your devices including the router and the modem. Wait for about a minute and turn them on in this order. Modem, wait for the lights to stabilize, then the rotuer, wait for power become solid gree. then turne the Laptop and PS3. See if this will help.
Dec 28, 2009 | NetGear RangeMax WPN824 Router
Power light and internet light flash every few seconds no internet access..
If the powerlight and the internet light is flashing then this is problem with the router or might be with the Power supply, If ur Model no: DG834Gv4 then call netgear to get the replacement for Powersupply(if ur product is under warranty) or else get the replacement of the router
-- but if it is not under warranty
-- then try with different power supply,
-- and if that won't help you
-- go for a new router.
If ur issue will resolve rate this...
Regards
TecKC
Dec 24, 2009 | NetGear DG834G Router
Can't access configuration for Wgr614 v5 Netgear Wireless router
Since you cannot ping the router, first thing to do here is to reset the router by pressing the reset button of the router for 30 seconds while power is On and then after the reset power off the router for 5 seconds and then when the router is already power On try to ping the IP of the router using a computer that is wired to it if still cannot be ping better contact Netgear support if the router is still underw arranty and have it replace...
Dec 22, 2008 | NetGear WGR614 Wireless Router
Wireless router says its working laptop says no its not
Your sister was accessing the wireless access point at school which is connected to the Internet/WEB access via a router and the school's broadband service provider.
For you to access the Internet using your wireless adapter on your laptop, you need your own wireless access point and connect it to a broadband ADSL or cable modem and then connect it to an Internet Service Provider. Some Internet Service Providers (cable and ADSL) can supply a combined modem/router/wireless Access point.
If you already have a broadband modem all you need is a wireless access point/router. You only need to configure the wireless access point and your wireless adapter so they will communicate with each other. Folow the instructions in the manuals.
Dec 07, 2008 | NetGear WGR614 Wireless Router
No dsl/ internet lights
Contact your ISP. There are some companies that deactivate your internet connection after inactivity for a period of time. They have to reset the D-Slam.
They will also have you power cycle your modem.
Jul 04, 2008 | NetGear DG834G Router
NetGear WGR614 Wireless Router Logo
60 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
