Question about SmartDisk (USBFLB100) 100 GB Hard Drive
USBFLB 100 Firelite
My Smart Disk 100GB has worked fine up till now. I plug it in and the drive seems to be powered. You can hear it and feel it drawing power but the blue light does not flash. It cannot be seen by the computer. This seems to be a recent occurence. Can someone assist me in accessing the drive or perhaps suggest an alternative for getting the data off the drive???
Thanks you in advance
  • 7937 Dec 21, 2008
    I have this same problem I need help
  • Anonymous Jan 24, 2009
    Same problem. If I keep fiddling with it (unplugging, bendingthe cord, begging) it eventually reads again but this sometimes takes 15minutes and is very annoying.
fwadley
  • 482 Answers
SOURCE: Firelite 60 GB Hard drive
Hard drive has went bad on you. Get a new one.
Posted on Nov 26, 2007
Beni S-P
  • 1006 Answers
SOURCE: Firelite USBFLB 160 won't mount
Problem is just external...First try in another pc,if it still wont work so just buy new external and put that hdd in new external...
Posted on Feb 17, 2008
bob_computer
  • 3153 Answers
SOURCE: Firelite usbflb40-c USB device exceeded power limits of hub port
I devised these simple steps that tend to remedy quite a few issues with most portable / external hard drives (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply
Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again.
If you checked and fixed anything there and still have issues carry on reading.
Go to your control panel and then administrative tools, select Computer Management.
Now select Disk Management and expand the window.
Your drive should be listed here, if not then you need to check your computer hardware has not got any issues before proceeding.
If your drive is listed and says healthy then right click on it an select Properties, click Tools and then Error Checking, Check now, tick the two boxes and then Start.
This will attempt to fix most minor / common errors on the drive. It may also ask you to restart which is fine. Allow it to finish its work or you could corrupt the drive. If all went well you should be able to use it normally again.
If you drive was listed but did NOT say healthy then right click and select Format. Choose NTFS as the file system and do not tick any boxes you do NOT want quick format. Again start and let it do its thing. When it is done restart your computer and you should be good to go.
If you still have problems with the drive you might want to look at other areas.
Posted on Aug 23, 2009
  • 33 Answers
SOURCE: Smartdisk Firelite 120 GB wont delete
Try to reformat the external hd thru the disk utility.
Posted on Sep 07, 2009
citroenchris
  • 600 Answers
SOURCE: MY Apple computer all of a sudden is not
Try going to utilities in the applications folder, in utilities select disk utility and see if the drive shows up, if so select repair disk after selecting the SmartDisk. If not showing select your hard drive and run repair permissions and see if it helps. Failing this you need a 3rd party disk repair solution like DiskWarrior. The information is still there!
Posted on Aug 10, 2010
Why does windows media player not recognize my firelite smart disc as a device. my computer recognizes it
Try rebooting your computer with the Smart Disk plugged in. You can also try moving all the contents of the Smart disk to your computer and access from there.
Aug 14, 2015 | SmartDisk FireLite 40 GB Hard Drive
I bought a verbatim 320 model. The blue light flashes on and off but the usb never loads. I can hear the drive wanted to boot but it just flashes on and off. I'ts able to work in my computer if I keep...
It seems that the disk-drive is "dying".
If it works, at least a bit, copy all the files from it onto your C: drive, or burn the files to DVD-writable disk(s).
Then, exercise the warranty to get it repaired/replaced.
Nov 01, 2010 | Verbatim 160GB USB FireLite: The "drive...
Computer repeatedly requests restart when smartdisk plugged in
try to scan your smart disk to another computer, your hard disk just hit by a trojan virus
Jun 28, 2010 | SmartDisk (DHXF250F) 250 GB Hard Drive
Firelite 49 GB is no longer recognized by my PS3
hi,
it's cause when you formatted the disk, you choose to use ntfs file system and ps3 can only read fat32.
when you format a hard disk or eaven a usb drive you can choose wich fort to use.
there are different tipe, most common are fat, fat32, and ntfs.
most actula operating system uses ntfs, but fat32 is still he more compatible.
reformat your hard drive as follow:
got to "my computer" on your desktop, right click on your hard drive and choose format.
a window should pop up.
under file system chose fat32.
leave untouched all other fields.
you could perform a quick format, but i suggest a full complete format, so leave all untouched and wait till end.
now it should work.
regards,
Paolo.
Jun 04, 2010 | Verbatim SmartDisk Firelite Portable USB...
How do I open a smartdisk firelite model # USBFLB40
Go ti My computer icon, right click on it and click on explore. Should be show your new drive. If this is the case, right click the new HD in click on explore to see what is in there. My PC Doctor NJ
Mar 26, 2010 | FireLite (USBFLB80) Hard Drive
Sep 03, 2009 | SmartDisk FireLite USBFLB120 120 GB USB...
Seagate 100GB Hard Drive for notebook SMART failure
Solution #1 is grossly incorrect. The S.M.A.R.T. mechanism is software/application/drive content agnostic. It is a firmware-based predictive failure feature. If the S.M.A.R.T. test returns a certain bit, then the drive is degrading and in need of replacement. If the disk is under warranty, then it generally qualifies for free replacement. If it is not under warranty, then you can run diagnostics such as http://www.santools.com/smart/unix/manual which can sometimes identify the specifics. Sometimes the problem is transient, like the disk was powered on/off too many times in a short amount of time, or the temperature is too high.
May 25, 2008 | Computers & Internet
Hard drive swap and repair
use a back up service for that...you can find one through this link, called Mozy @ home
May 05, 2008 | Dell Latitude D600 Notebook
Smartdisk Firelite usbflb80 stopped working
My Smartdisk Firelite 80 gig Mini-Drive will not power up when plugged into the front or rear USB Ports (Windows XP Pro System). Last used successfully on 4-Apr-08 with no issues. Any suggestions?
Feb 22, 2008 | FireLite (USBFLB80) Hard Drive
Feb 16, 2008 | FireLite (USBFLB80) Hard Drive
SmartDisk (USBFLB100) 100 GB Hard Drive Logo
122 people viewed this question
Top SmartDisk Computers & Internet Experts
Sunday Ojelabi
Sunday Ojelabi
Alun Cox
Are you a SmartDisk Computer and Internet Expert? Answer questions, earn points and help others
