Kenmore 300 top load washer stoped after wash and has not drained water. when push starting there is nothing not even a sound.
  • Dereknterri Jan 22, 2009
    Mine just quit yesterday and is a Kenmore 300 as well. When you start the washer it just has a slight buzz sound. It will not drain either. Model # 28332700 Please tell me what I can do.
    Thanks
  • 370 Answers
You have a broken lid switch. IF you get me the model # i can get you the part number. There is three different ones. ( This is a very common problem) Part is about 35 bucks. I replaced three this week.
Posted on Nov 21, 2008
Kenmore Series 70 Washing Machine - won't drain water
WHAT IS WRONG WITH YOUR WASHING MACHINE?
small_11_21.jpg For a detailed Washing Machine illustration, click below.
redarrow.gif Top Load Maytag Style
redarrow.gif Top Load Whirlpool Style
redarrow.gif Top Load GE Style
redarrow.gif Front Load Maytag Style
redarrow.gif Front Load Frigidaire/GE/Kenmore Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Some problems that can occur with your top-loading washing machine are:
There's an error code on the digital display
It doesn't work at all
It won't drain
It doesn't spin
It doesn't agitate
It's noisy
It leaks
It's off balance
There's no hot water
There's no cold water
It's slow to fill
There's no water at all
The clothes are wet after spinning
The cycle doesn't advance
There's no delicate or regular spin or agitate
It's overfilling
It's underfilling
The water temperature is incorrect
Hope this may help;
DON'T FORGET TO RATE:
Aug 10, 2008 | Washing Machines
How do I fix my top loading Kenmore washer?
If the lid is locking then you have a control board issue and it will need to be replaced. Here is a link to that part. http://bit.ly/1L1fNqO
Sep 07, 2015 | Kenmore Washing Machines
KENMORE OASIS WASHER DISPLAYS Ld CODE AND WILL NOT DRAIN WARER FROM TUB
I have the kenmoe Oasis he and out of no where this machine wont work. You push the start button and select and that is it 'Nothing" you have to unplug it and start over again but the same thing will happen "nothing" and plus the water wont drain! I feel this is a rip off machine. house wife
Dec 08, 2010 | Kenmore Oasis HE 27082 Top Load Washer
22432 won't spin or drain
CHECK THE LID SWITCH THE PART THAT PUSHES THE SWITCH DOWN MAY BE WORN ENOUGH TO CAUSE THIS PROBLEM. WITH THE LID OPEN START THE WASHER IN THE SPIN CYCLE AND PUSH THE SWITCH WITH A POPSICKEL STICK AND SEE IF THIS PROBLEM STILL HAPPENS
Aug 30, 2009 | Kenmore 22422 Top Load Washer
Washer won't drain.
Sounds like the pump is clogged or stripped out. It's mounted on the front of the motor in the middle of the bottom. There's only 2 clips and hoses that hold it on. These are known for stripping out in the middle. They are just plastic, but fairly easy to fix.
Mar 14, 2009 | Kenmore 24032\24036 Top Load Washer
WASHING MACHING
you may have the drain hose too low or too far into the drain in the house. the drain hose has to be higher than the water level in the washer, otherwise the water will just drain out.
Jun 27, 2008 | Kenmore 24032\24036 Top Load Washer
KENMORE 80 SERIES
Open and close lid, listen for 'clicking' sound. If no 'clicking' sound, replace lid switch. If this washer has a hidden lid switch, check the lid hinge screws and make sure they are screwed in tight.
Jun 01, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
102 people viewed this question
Top Washing Machines Experts
