Question about Audio Technica ATW-T52 Microphone
Change the frequency
I have a mic and want to change the frequency to match my base unit
  • 165 Answers
Hello firstable you need to know at how many ohms is the base unit then in microphone change the impedance transformer to match the low or high frecuency you want......saludos
Posted on Nov 20, 2008
I cant get my mic to sink
I assume you are talking about the RF A/B lights. If they do not come on, check the frequency to make certain the transmitter matches that receiver. If the frequencies do match, then the system will need to be repaired.
Jul 26, 2014 | Shure UT2 / 58 / PG58 Professional...
Headphones not working
have to make sure the transmitter frequency matches the headphone reciever frequency.. like a wireless telephone.. the base has to match the handset the same frequency..say 2.7 mghz or so as an example..if it dont it wont work,. they arent compatable.. this may also be able to be done at the dealer..they might be able to change the headset out..
Dec 23, 2013 | Honda Odyssey Cars & Trucks
I purchased 6 receivers of this model, I need to get the mics...Even if I got them, is it posible for them to work, in other other words Can I adjust them to the receivers' frequencies? And if so, would...
Normally the mics and receivers are sold as a unit but replacement mics can be bought separately.
However the ATW-R11 has been discontinued so may now be hard to find.
This model has 20 available frequencies so you should be able to change frequencies okay.
NOTE - you will require a license for these frequencies
Aug 26, 2010 | Audio Technica ATW-R11 Microphone
My yamaha did not come with the optomizer mic
You can, and the results might be better than not optimizing, but they might be worse.
The optimizing process listens for resonant frequencies in the room (what pitch "rings" longer in your room) as well as damped frequencies (what pitch sounds "dead" in your room)
To do this, it needs a mic that's matched to the unit.
Different mics have different frequency response curves, so your friend's mic might think (for example) that 2500hz is really hot, but the yamaha mic would think it's normal.
Certainly won't hurt to try, but if you don't like the way things sound after optimizing, then just reset your yamaha to the default EQ.
Sep 16, 2009 | Yamaha YSP-800 System
HELP WITH MOTOROLA CM340 (SOFTWARE)
If everyone is on the same frequency, you would be able to hear the others by taking your hand mic off the hang-up clip. This puts your radio in open squelch mode where you hear all traffic on the frequency. If the other drivers are on a different frequency, you would need to have the radio reprogrammed to match their frequency.
Jun 08, 2009 | Motorola Radio Communications
Two diffrent units with two diffrent frequincys . i wantto change
I hate to be the bearer of bad news but those units are fixed frequencies and cannot be changed. You either have to find a mic that matches your receiver or vice-versa. The freeway 200 series comes in 3 freqs. two of witch you have with the addition of 170.245. Maybe you can find someone who has a damaged mic but still has the receiver with the freq. that you need for your mic.
Apr 11, 2009 | Audio Technica Audio-Technica ATW-T202...
All 4 mics wil transmitt through channel a,
Sounds like all of your mics are using the same frequency. What you can do is change crystals in each unit to change frequencies, this will allow each mic to use its own receiver.
Mar 31, 2009 | Pyle Music
It appears that my mike on one unit does not work.
Check your programming by holding in the PTT button while turning on the radio. The first announced number is your frequency. Press the MONITOR button, and then it will announce your code. Press the MONITOR button again finish. Then shut the radio off and back on for normal operations.
If the numbers on your radios do not match, you can use your PTT button to change the number it has announced. Press the MONITOR button to lock in your new setting after setting the frequency and/or code.
Final thought, check your mic hole on the face of the radio to be certain is does not have debris or tape over it.
Mar 02, 2009 | Motorola MU21CV (1 Channel) 2-Way Radio
Utilizing two microphones
No, when you buy multiple wireless mics you have to select different channels per unit if you want to use them on the same stage.
hope this helps
thanks for your rating
Jan 09, 2008 | AKG (WMS40DIV444US54) Microphone
314 people viewed this question
Top Audio Technica Audio Players & Recorders Experts
 Grubhead
Grubhead
Greg Cann
Greg Cann
Clif Roberts
Are you an Audio Technica Audio Player and Recorder Expert? Answer questions, earn points and help others
