Panafax Uf 4100 not redialing
Hey guys i am unable to manually configure my Panafax Uf 4100 to automatically redial
I do not have the manual and its not connected to the network
any help would be great thanks
  • Gaandax Nov 20, 2008
    Thanks worked!!!!!!!!
    Genius:
  • 2,120 Answers
Press the following keys
Function
7
monitor key slowly 4 times
set
clear 2 times
enter 0-15 times redials......I recommend 5 redial tries
set
stop
unplug power cord and replug.
Posted on Nov 20, 2008
Automatic redial phone option
On most cell phones, to redial the last phone number dialed, press the green phone icon when the keypad is displayed on the screen. You can only redial the last number dialed. To obtain a copy of the user manual, follow this link and download the pdf. http://www.gsmarc.com/huawei/ascend-g610/manual/
Nov 14, 2013 | Huawei Cell Phones
Automatic redial malfunction
It's been a long time since I have used Panasonic analog phones, but the redial function in them used to be mechanical. It dialed 15 times with a 45 second pause between attempts. The key was, it expected you to pick up the handset, cancelling the redial if you got an answer.
If you got an answer and didn't do anything, it hung up and redialed again until you picked up the handset!
Could that be what your system is doing?
Carl
Sep 14, 2009 | Panasonic Lands Phones
What is error code 634
Error Code 634 indicates a call that was placed did not go through:
"Redial was not successful due to no response from
the called station or wrong number dialled.
Note: If busy tone was not detected, the machine will
only redial once
Sep 03, 2009 | Panasonic Panafax UF-595 Plain Paper Laser...
We can't send faxes.
call the fax number from a regular to check for fax tones.
plug in a regular phone to check for a dial-tone.
Feb 02, 2009 | Panasonic Panafax UF-585 Plain Paper Laser...
PANAFAX UF-6000
error code 634 means that you have reached your limit of redials
Jul 29, 2008 | Panasonic PANAFAX UF-6000 Fax
GETTING COM AS 634 INSTEAD OF OK STATUS WHAT IS THE REASON
This is what the code means:
Redial was not successful due to no response from the called station or wrong number dialed.
Note
: If busy tone was not detected, the machine will only redial once.
So the your fax machine is getting no response from the fax you're calling.
Hope that helps...
Jun 13, 2008 | Panasonic Panafax UF-585 Plain Paper Laser...
Owners Manuals are missing after the office remodel
Redial is used by pressing the redial button to access the stored numbers, each press brings up another number. To dial the number you want hit the # key. i.e. to dial a number you called 3 phone call ago you press 'redial', then 'redial', then 'redial' followed by '#'.
Apr 14, 2008 | NEC Dterm DTP 16D-1 Corded Phone
Incomplete info code 634 how to fix
That codes says:
"Redial count over with no response
or busy tone was not detected.
Note:
U.S.A. and Canadian models
will redial only once if a busy
tone is not detected."
The number you're dialing was first busy. When it went to redial, it detected no phone signal on the other end. If it happens to only 1 or 2 customers, then it's something to do with their lines and you can't fix that.
If it happens often, then get your phone lines checked out by your phone company, make sure your fax is not sharing the line with another other device and make sure it is not a digital line.
Other than that, you're looking at having to replace the main board in the fax. Which basically means it's time for a new fax machine.
Jan 02, 2008 | Panasonic Panafax UF-595 Plain Paper Laser...
Redial
Go into the admin mode or user mode to reset the default settings. Procedure should be in the op manual.
Nov 15, 2007 | Minolta MF1600E Plain Paper Laser Fax
166 people viewed this question
jasbo
jasbo
