Question about Sanyo 09KHS51 Ductless Mini Split Air Conditioner
Sanyo mini split wall unit blower vibration
Already broke 1 blower wheel after 1 year . Replaced wheel and motor . Now 2nd one begining to make noise after a few months.Gets quiet after pushing on corner, as if case has a twist.No real way to secure it any differently.
  • 125 Answers
SOURCE: Hello We just installed a Sanyo KHS1271 mini-split
The condensate drain line was not properly installed. Make them pull the wall unit and correct the problem.
Be persistant until you are satisfied they have the problem corrected. Do not pay any additional money. If they do not correct the problem then report them online to the state board of heating and air. Fill out their requested complaint form and follow thru with a second complaint if you do not get total satisfaction from the contractor that installed the unit.
Hope this helps.
Posted on Sep 23, 2011
  • 207 Answers
SOURCE: procedure to replace motor in split system wall unit
indoor unit or outdoor unit i think ur talking about the indoor unit it is a real pain they dont make those technician friendly but make sure u order one from the factory cause its an oddball but if ur going to attempt it then take the front cover off there will be phillips screws on bottom sometimes they have lil pieces over them to cover them up when u have the cover off on the right side u have 3 circuit boards 2 have to be removed and make sure u label where they go and at this time u should be able to see the motor but even when u get to it its still a pain to get in and out there is a set screw holding the squirrell cage to the shaft and ull have to get to the screw thru the fan blades and once u get the set screws out u just have to wiggle and jiggle til it comes out now some models dont have set screws so jus look it might not have any and to put it back in jus go in reverse make sure u cut power to unit before u start touching any of the internal parts ( circuit boards etc...) hope this helps good luck
Posted on Feb 26, 2010
  • 7 Answers
SOURCE: Appears to leak up in the wall unit
I agree with bobotfel, adding that the oil is an indicator, not the problem itself.
Oil circulates along with refrigerant, as a mist. Thus is oil is present, a leak is indicated.
The fact that you unit held pressure for several weeks is not surprising. There would be, at a guess, 50-100 pounds of pressure in the tubing when the unit is not running, which could take quite some time to lead down. This is a break for you, as the pressure in the lines would prevent air and--worse--moisture from entering.
If your lines or fittings are not damaged, then bobotfel's 2-wrench solution is probably the end of your problem.
Posted on Mar 28, 2010
  • 674 Answers
SOURCE: SANYO SPLIT TYPE AIR CONDITIONER LEAKING
The leakage is probably from condensation and there should be some sort of drain for it. You should check to see if it is clogged or partially clogged. Also since you say it does it when it hasn't operated for a while you may want to check out where the lines pass through the wall and make sure that it is sealed up there so you don't get leakage from out side.
Posted on May 04, 2010
  • 1156 Answers
SOURCE: when replacing the sanyo circut board do you need
Hi,am sorry about your sanyo AC problem. But it's not a new complain about sanyo AC's not working properly..
Summing upall the parts for your sanyo AC and replacing all damaged part,calculating the cost of purchasing all the replacement,I don't think it's worth the purchase.
What i would advice is this, You can try out another product Sony,panasonic etc,as many as they are instead of using your time and money to fix up the sanyo AC that your not even sure after fixing one problem,another will not come again.
Save your money , strength and time and go replace with a new working one.there are not to expensive,Compared to using close to the amount of getting the old one fixed.
You can get new AC's from eBay.com,and amazon,and any other store close to your area..
I think that will do..
Try see..
It's just and advise..
Take care...
Posted on Jun 14, 2011
How can I fix a vibrating sound on a ecox mini split A.C
IT depends on how old the unit is and the conditions in your area but in split systems the motor is connected to a blower that produces the air flow. This blower is cylindrical in shape with a number of bars that produce the air flow. Over time this blower builds up with debris from the air in you building ( cooking fat--smoke -moisture- etc and is like what collects on the filter. This is what unbalances the blower and has to be removed first. Look up under the opening where the air comes out of and you will see the blower and you will be able to see if it has a build up on the blades. There are ac cleaning products on the market that you can spray in while the unit is operation but be prepared to have to catch the dirty air and bits that will come out. If you have no experience it may be best to get an ac mechanic to come and clean the unit for you.
Jul 17, 2013 | Heating & Cooling
I have a sanyo split system and one of the inside units creates ice around the coils. the filters are clean and there's nothing blocking the air around it. What can it be?
There are reasons for.
1. Dusty indoor coil and blower wheel - Clean it.
2. Less speed of blower motor- Replace capacitor/motor
3. Short of gas- Find leak and rectify.
Thanks.
Jun 29, 2011 | Sanyo Split System Air Conditioner
Furnace blower motor vibration
Check for a loose set screw on the motor shaft for the blower wheel.
Check the blower wheel for a missing balance weight.
Check the blower wheel for a dust buildup in the blades.
Check the blower wheel for a broken fin blade.
Check the blower motor shaft for excessive play.(more than 1/4 inch of play).
Check mounting screws on the blower housing.
Jan 04, 2010 | Ruud Heating & Cooling
Evaporator vibrates and a noise and air gets hotter
When was the last time you cleaned the washable filter located behind the front flipup door of the unit? All mini-split systems are notorius for having dust build up on the blower vanes and as it runs it pulls humidity out of the air causing that dust to become like a past e
and changes the angle of attack on the blower cage. Check your filter and take some compressed air and blow it out real good and see if that helps.
Feb 01, 2009 | Fujitsu 24C1 Air Conditioner
York P3HU Gas furnace blower making grinding noise and vibration
If the wheel is rubbing on the housing obviously that's no good. Yes that is one solid piece, it needs replaced. Not an extremely difficult job, toughest part likely getting the wheel off the shaft. Sand exposed shaft and use some lubricant. Before removing motor mark on the housing where the wires are located/ direction they point. Do not forget to tighten set screw upon reassembly. Good Luck!!
Mar 28, 2017 | Heating & Cooling
York P3HU Gas Furnace Blower wheel makes noise and vibrates
yes you have a bad blower wheel the fins are crimped to the disks, if you can take the blower assembly out just watch the wiring and take the motor out of the center of housing away from blower wheel and when taking out the wheel remember the diriction of the wheel
Dec 11, 2008 | Carrier 38CKC042 Air Conditioner
Blower motor vibration in a/c unit
You already checked to see if the blower wheel is out of balance by noticing that the a/c unit vibrates. There is nothing else that can vibrate that badly.
Go buy a new blower wheel.
Jul 20, 2008 | Heating & Cooling
PROBLEM
is this a heat pump, mini split?
Feb 20, 2008 | AmcorAire UCHW-H24AF2 Split System Air...
Sanyo 09KHS51 Ductless Mini Split Air Conditioner Logo
394 people viewed this question
Top Sanyo Heating & Cooling Experts
Dennis Boxerman
Tim Whalen
Chuck
Are you a Sanyo Heating and Cooling Expert? Answer questions, earn points and help others
