Question about Bosch Nexxt WTMC 3300 Electric Dryer
My dryer will not tumble nor will it heat, we have replaced the thermador sensor but will not run. lights flash and can hear a clicking noise, sounds like a relay of somekind going on and off. Any suggestions? we checked the voltage and it is fine. Thanks for your time.
    Novelist:
  • 163 Answers
I am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Dec 26, 2008
Dryer is tumbling but no heat - when I reset it shuts off after about 10 min and the Drying, Cool Down, and Extended Tumble lights are all flashing.
Janet McDonald,
I understand that you are having trouble with your dryer not heating and not running a full cycle and shutting off with the Drying, Cool Down, and Extended Tumble lights flashing. What I suggest is to give your appliance a hard reset. You will do this by either unplugging it or cutting the power off at the circuit breaker for 3-5 minutes. After the 3-5 minutes, bring power back and try to start a cycle. If it does not complete the cycle and shuts off with the lights flashing, I suggest to either contact the manufacturer or a local appliance technician. This way you will be able to locate the cause of this issue and have it resolved.
-Best Regards-
Jan 14, 2014 | Frigidaire AEQ6700FE Affinity Electric...
Kitchenaid prestige dryer will not tumble
I fixed one that would not run last Halloween. A Kenmore very similar to a kitchen-aid dryer:
4 Wheel dryer DE-mystatified
Jul 08, 2012 | Dryers
It's run but there's no heat
The gas dryer has a spark ignitor that starts the burner to heat up. Upon switching on the dryer you should hear the ignitor clicking to light the burner. If you do not hear the clicking noise the ignitor needs to ne replaced
Mar 27, 2010 | Whirlpool LGR5636L Gas Dryer
My dryer heats up but does not tumble. I replaced
Sounds like worn tub back bearing.
take the belt off and spin the tub by hand to see if it is binding.
check that the pulley isnt loose on the tub back and also the motor pulley, feel if the motor spins free.
Finally check the tub itself for objects poking through or lodged in the outer tank.
Good luck
Mar 18, 2010 | Dryers
The dryer will not tumble
do you hear any humming noise? does the heat come on?....no noise. most likely is a thermal fuse....small white fuse usually with two blue wires. humming means broken belt, bad motor or something stuck in blower wheel.
Jun 11, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Dryer heats but won't tumble
Assuming, the timer is ok and that you can hear the the dryer motor running, it sounds like a broken belt. These kind of failures generally occur suddenly - one day it works, the next day it doesn't.
May 03, 2009 | Dryers
Beko tumble dryer not drying. drum goes round but it doesn't get hot. Model DRCS68
go into service mode and reset
to do this move to delicates turn on dryer and keep
pressed down cancel button for about ten seconds release
then all lights should flash when you press cancel again machine will go through test mode , then just turn machine off
it is now reset, this worked for min a drcs68w
Apr 23, 2008 | Dryers
My Dryer Heats but won't tumble
do you hear a humming noise? and is air coming out the rear if so the belt has broke if not the motor has gone bad let me know what you find
Jan 08, 2008 | Whirlpool GEQ9800P Electric Dryer
Maytag electric dryer model #MDE 4916AYW
If your hearing a buzzing noise, motor.. If it sounds like the motor is running, could be a belt.
Jan 07, 2008 | Dryers
Bosch Nexxt WTMC 3300 Electric Dryer Logo
125 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
