Question about Poulan Pro 22" Self Propelled High Wheel Mower
Replacing a rope
Cannot coil the right way please help oh the rope
    President:
  • Poulan Master
  • 1,388 Answers
Replacing the rope is not difficult but tricky. Remove the starter cover and place it on your workbench with the plastic rewind spool visible and remove the old rope noting how it was tied. The rope is sold in various sizes from # 3 to # 6.5. Most mowers use a #4.5 length of about 6 to 7 feet. You may not need this much but more is better. Now practice inserting the rope thru the hole where it comes out into the hole where it ties. Once you can do this you are ready to wind. The spool winds when you pull the rope, that why it recoils when you let go of the rope. With that in mind, turn (wind) the spool in the same direction that it turns when you pull the rope. It should be getting tighter as you turn. Keep winding in the direction that it turns when you pull the rope untill it will not go anymore. It should be very tight. Now unwind one complete turn and align the hole of the spool to the hole in the housing and hold it there while you insert the rope from outside hole into the spool and tie knot. After the knot is tied slowly let rope rewind into the spool untill it stops on its own. You are done. You should have plenty of extra rope left to extend out to the handlebar. Enjoy
Posted on Dec 05, 2008
How do I replace the starter coil rope on a PW0872400 power washer
There is a shroud that the rope goes into and under that shroud is a pulley the rope coils around. Take the shroud off by removing the bolts and screws, Pull it away from the engine, it should slide off the flywheel/crank shaft. When you have it removed, there are tabs that hold the pulley in, you have to bend those back and take the pulley out. Be advised that there is a very long, flat coiled spring that causes the pulley to rewind the cord. This spring is hard to deal with and can uncoil rapidly and cause serious injury. When you have the pulley out and uncoiled the spring, you can change the rope, make sure you thread it through the housing first and then into the pulley and knot the end. Reassembly is troublesome because getting the spring and pulley the right tension to retract the rope is not easy. Check youtube for how to videos.
Sep 16, 2016 | Garden
How do you fix a pull start
-Take the handle off the rope. You want to only have one knot in one end of the rope. (Of course, if the rope's already broken, you can skip this step ....)
-Get the reel and lay it facedown.
-Get the coil, and begin carefully winding it up so that it fits inside the grooved edge on the reel. BE PATIENT - this will take time.
-On the inside of the coil, there should be a little hook on the end of the coil. That hook matches one inside the pullstart cover when you put the two pieces together. The trick is to get the hook on the reel to catch the hook on the pullstart cover. CAREFULLY put the reel and coil inside the cover, and ***** the bolt in for a moment to hold it in place.
-Turn the pullstart reel clockwise until you feel the hooks catch each other. Feel some resistance? Good, that's what you want.
-Take the bolt back out, and reassemble the starter pawl assembly inside the pullstart, then put the bolt back in and tighten it.
You should now have a complete assembly, minus the pull rope. -Now, looking down into the pullstart, notice there is a hole in the reel off to one side. This is where your rope threads through. Grab the reel, and crank it around about .... four or five times, and try to get the hole in the reel lined up as close as possible with the outer hole in the pullstart cover. -Take your rope (you DID take the handle off first, right? Oh yeah, it broke off ...), and thread it through the reel, then through the outer hole in the cover. This will be a little tricky, as you need to be holding the reel so it doesn't unwind ...
-SLOWLY let the reel start to retract, but don't let it go all the way. Does it look like it's drawing the rope all the way back in? If so, great! If not, pull the rope back out, crank the reel around another turn, and try again.
-Once you have the reel set to where it will retract the rope all the way, thread on your handle and tie it off. You're done!
Apr 16, 2016 | Motorcycles
Ingnition coil
I don't recall an ignition coil on a two stroke engine....only a capacitor and a magneto. oh...and maybe a set of points....but wait...now I think I do recall a coil that is attached to the end of the spark plug wire, inside the case cover. Totally replaceable, but if your not getting spark....first check the plug for fire and proper gap.....and if no fire, or spark from the plug......replace it....if still no fire.....check for rust build up on the magneto....it will be apparent....rusty covered spinning object under the case cover....and if no rust is present, locate the points and flash a light on the set to check for charred surfaces on the connector tips....then if everything mentioned is all ok but still no spark....replace the coil. Good luck and remember that the spark generated by the motor will not be a fun thing to experience, so don't hold the spark plug with your bare hand and pull the starter rope.....Good luck...hope I helped in some small way to remedy your problem...It will serve you well to explain your problem in more detail if you want to actually get great advise with your problems....good day...:-)
Mar 26, 2015 | Garden
Cord rewind assembly
If you place the chain saw on a work bench with the bar and chain pointing at you. We will call the side with the chain and bar the left and the side where you gas and oil the saw the right side. Now on the right side just behind the oil filler cap is the starter rope and assembly . There are four screws that holds this assembly to the saw. Remove these 4 screws while carefully watching and lifting this assembly from the saw. turn the assembly over and if you can see and grab the old starter rope . Grasp it and pull out on the rope a few times so you can see how it works, play with it a bit, so that when you replace the old rope with a new you will be familiar with the action.You can find starter rope at local chain saw or hardware stores, estimate the length you will need. Re-thread the new rope in opposite direction that you saw the old rope function being careful to duplicate the knot at the end of the rope which will be inside the assembly, threaded in as you saw the old one come out. So look carefully. Play with it a bit. Familiarize yourself with how the two holes line up and thread through the spool and the knot is tied. Now make sure the end of the rope coming out of the assembly has the recoil action. Tie on the handle being sure to take only enough re-coil that there is no slack in the rope and handle end. Replace the assembly and check the action. Have fun! Alvin
Sep 30, 2013 | Husqvarna Garden
How to replace pull start rope on briggs and stratton xlt 50
wind the xpring on the pull start leave 1 turn useing a wire push it throughthe hole in top of srring and through the hole on the pull starter make sure you tie a good knot in the rope oh yes you can put a screwdriver through the pull start to keep it from unwinding
Jul 26, 2012 | Garden
Replace starter cord
hello sir, i'm guessing the rope is broken , first you'll need a c-clamp large enough to clamp the spooler, needle-nose pliers,a small tipped screwdriver and a new length of rope.the safest way is to remove the rewind assembly cover leaving the spooler in place in its housing. try to remove the old rope with neddle nose pliers ans small tipped screwdriver.next hand spin the spooler to achieve spring tension until stops back off enough to line holes up, place c-clamp to hold it in place,now try to fish the new rope into the hole in the knot recess,trying to guide it to the exit hole in the cover, ( it's easier to feed the rope if you singe the end of the rope with a bic lighter and form to a point )and with a small knot at the other end,pull the rope all the way until you can seat the knot into the knot recess.next tie a loop knot into the other end of the rope,so the end wont be recoiled all the way into the housing.with tesion on the rope gently remove the c-clamp and let the rope be drawed in.if it draws all the way to the loop knot, check to see if the spooler is full if so,( not too full where rope is binding ) pull the rope about a foot and re clamp the spooler and install the pull handle, if rope is too long you may have to cut to length. if it doesn't draw all the way to the loop knot and the spooler is not full than you may need to add anoyher revolution to the spring tension in the same fashion as described above.there are eisier ways but that evolves removal of the spooler and repacking the reciol spring.( not for the novice ). hope this helps,MrFixIt,oh could you please rate this solution,thank you.``
Feb 11, 2012 | Garden
I have a Ranch King Push Mower. I can't figure out how to get to the coil rope to fix it. I took the top off, but I still coulnd't get to the coil rope. Can you help please? Thank you!
The starter/recoil unit should be bolted above the flywheel. Can you just remove the bolts holding it in place and lift it off....or are there rivets there that won't allow it's removal?
Aug 24, 2010 | Garden
I nee to replace starter rope on tiller...
O really, u have a easy task here. Remove that pull rope coil housing and get it on the bench. Don't take any thing apart from here, that coil spring inside is a whole different religion test. Cut the knot and remove the old rope if it already hasn't broke, but get the old rope in the trash. Mark the rope hole some how in the coil housing against the hole in the housing where the rope comes in from the outside to get a line back through it all. Use braided nylon the same size as the old rope. Twist the coil back up enough to take up all of the new rope and still have some tension, line up your marks and clamp with c-clamp or vise grips to hold your coil tension. Tie your new rope to the handle and thread the other end from the outside through the holes till u see the end of the rope in the knot hole in your coil. grab with some needle nose, pull r up through and tie your knot. Make sure with a tug she's going to hold and release the clamp. Your back in business pal.
Never give in to the repair shop buzzards. ballping
Jul 21, 2010 | Mtd Products Yard Machines 158CC Tiller
How do I put in a new pull string
Hi
Please check the bellow link…
http://www.kichline.com/chuck/fixit/mowers/rope.html
Unscrew the coil housing for the rope using a socket set or screwdriver. Do not tip the mower over on its side when working on it because this can often cause oil and gas to leak out. Check out the coil wheel. Depending on where the rope broke, you might have some rope left on the coil wheel. You can feed the old rope back through its hole and retie the pull handle if you have enough rope to pull start the mower. Next, replace the housing and then screw it back in place. If you do not have enough rope, you will need to replace it with a new one. You can take a wrench and loosen the bolt that holds this in place. When you pull the wheel off, in most cases it will include the winding spring that coils the rope automatically.
Loosen the bolt that holds the coil pulley in place. When you take off the coil pulley, the coil spring will come off with it in most cases. Cut off the old rope using a knife. To remember which way the rope was coiled, make an arrow with a marker.Pull the new rope through the hole and tie a knot about the same size as the old rope because you do not want the new knot to catch on something when the coil pulley coils and uncoil. Wrap the new rope in the direction of the arrow you drew. Next, bolt the coil pulley back in place. To make sure it is working properly, unplug the spark plug- this allows you to pull on the rope to make sure it coils and uncoils correctly.
Pull the end of the rope through the hole in the housing. Tie the old pull handle to the end of the new rope. If the rope is too long, you might need to cut off the extra length and discard it. Place the house into its spot and screw or bolt it back on. Finally, put the spark plug wire back into place.
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Jul 09, 2010 | Garden
How do you replace spring on a poulan chainsaw
A Poulan "P4018WT Gas Saw Type 1" IPL follows (may not be your saw):
http://www.ordertree.com/modelinfo/PWE/P4018WT-Gas-Saw-Type-1/75.P4018WT-Gas-Saw-Type-1.1.59.1.html
If yours is not a "Type 1" it can be found here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
If the spring is unwound:
Recoil Spring Rewind
I invert and secure the starter housing and rewind the spring large coil to small (need eye protection and both hands). I am right handed so I tension the spring enough to insert it inside the previous coil while holding what has already been installed with my left about 180° from my right hand. The tension will hold the spring in the housing once completely rewound. Then bend slightly the inner most part to engage the starter spool. The video explains how to tension the spring.
R² Starter Rope by SmallEng.com
http://www.youtube.com/watch?v=eRyy3MlsjVo
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Apr 23, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan Pro 22" Self Propelled High Wheel Mower Logo
133 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
roeb
Are you a Poulan Garden Expert? Answer questions, earn points and help others
