Question about Procom ML300TBA Heater
Procom ML200TBA It sounds like one of you out there might be able to help. I bought a ventless ProCom ML200TBA for my shed. I planned to supply LP gas from a 20 lb gas grill tank. I'm connecting to the heater with a hose/regulator that I have from a defunct propane heater. Gas flows freely from the open end. But when I connect it to the regulator in the heater, the pilot won't light. Any ideas would be appreciated. Gary
  • Gary Booth Sep 18, 2007
    Thank you for your help. In fact you were right on. The regulator I had tried to use was from a fan forced propane heater, way too much pressure. That excess pressure had pressed a tiny plunger device upward into the heater regulator inlet. Presumably some safety feature to protect people like me from ourselves. This prevented the heater regulator from damage but also prevented it from lighting, fortunately. I switched to the proper much lower pressure regulator and the unit has worked fine since. Thanks again, Gary.
  • 1,420 Answers
Propane appliances usually run on 10-11 inches of water column, this is about 1/2 pound of pressure. If the regulator you have is not rated for delivering gas at that rate, you will need to find one that does. If your regulator is rated for more than the 11 inches, most likely you could have damaged the appliance regulator that came with the heater. Check the propane pressure specified by the heater manufacture against the rated supply of your regulator and see if they match. Make sure the heater is rated for Propane and NOT Natural Gas. Check to see if the gas valve on the appliance is in the operate position and all valves are open. Bleed off the air in the gas line by holding down the pilot switch and keep attempting to light the pilot. It could take you a few minutes. If you hear and smell gas but the unit will still not light, don't chance at getting hurt, call a technician. Look to make sure there are no safety switch that may have triggered off not allowing the gas valve to operate. And make sure there is no obstruction in the heater?s gas valve blocking off the supply of gas. Always exercise caution when it comes to gas and if you are uncomfortable, call a qualified gas technician.
Posted on Sep 17, 2007
I have a procom ventless fireplace heater and the pilot light will not stay lit
Sounds lie you need to replace the bimetallic strip by the pilot light. If that is bad the main gas nor the pilot will stay on.
Jan 03, 2016 | Procom Heating & Cooling
Procom pilot light wont light
Make sure the gas valve is on. The thermocouple may need to be cleaned in order for the pilot to stay lit.
Nov 26, 2013 | Procom Heating & Cooling
I have a charmglow Cgn300TB ventless gas heater and I need to replace the blower....... can't find one!!! Help!
Harbor freight sells the blower motor on internet
charmglow has been bought and sold by Home Depot. It has been
a total pain in the *** trying to track down this blower motor.
the new Company is procom, www.usaprocom.com
go to harbor freight and type in procom and the blower motor will pop up.
ggrobe@aol.com
Oct 28, 2010 | Heating & Cooling
I have a ProCom Ventless Fireplace. LP Sometime
that shouldnt matter u probably have a runner tube where the gas runs from burner to burner sometimes they get clogged or spiders can build webs in them ur best bet is to turn the gas off take apart and clean tat should solve ur problem
Feb 26, 2010 | Procom ML300TBA Heater
Heater parts
You can contact Master Parts at 800-446-1446. They are the parts distributor for ProCom. I hope this helps you...
Jan 05, 2010 | Procom MN100HPA Heater
We are trying to change the thermacouple on a Procom Ventless Gas Fireplace and we can't seem to get to it. Any suggestions?
get it how
screwed back in valve?
nuts seized on?
carefull not to crossthred it, its brass and easily done, go with fingers untill you know it lined up ok
Nov 27, 2009 | Procom 10K BTU, Vent Free, 2 Plaque...
Procom MN300HPA ventless heater conversion
You need to first get a regulator which will go between the propane tank and the burner. You will need to know the burner capacity in BTU/HR and the pressure required. All of this can be found on the furnace specification plate or on the gas valve. It is a no brainer Circut!
Ray
Nov 06, 2008 | Heating & Cooling
Heating & Cooling Logo
618 people viewed this question
Top Procom Heating & Cooling Experts
Paul Carew
john h
Bryan Wilson
Are you a Procom Heating and Cooling Expert? Answer questions, earn points and help others
