Question about Kenmore 30 in. 32384 / 32385 / 32389 Gas Cooktop
Is there a flame adjustment on Kenmore 32385
Flame does not seem intense enough on burner
    Novelist:
  • 222 Answers
Try to clean the injector at the bottom of burner base by using a small niddle then after this use a vaccium in the same place.tnx
Posted on Dec 02, 2008
  • gerbee gomez Dec 02, 2008
    try to clean the injector at the bottom of burner base by using a small niddle then after this use a vaccium in the same place.tnx
A gas ring does not remain lit after lighting on one of the burners on my Borsch brushed steel gas hob
Seems like one of the thermocouples has failed or it may just be dirty. There should be 2 "prongs" sticking up toward the burner. 1 is for the ignition and causes the spark to jump to the burner and light it. The other is a thermocouple which senses the heat from the flame and operates a magnetic device on the gascock to keep the gas flowing. If the thermocouple is faulty, damaged, dirty, it may not sense the heat and therefore, the flame will keep going out. Make sure the end of it is clean and the burner is positioned properly on its base. The thermocouple is usually a steel rod sticking up. This can be easily cleaned with a bit of steel wool or scourer. Do NOT scrape or scour the ignition prong as this is made from porcelain and can break very easily. It is usually white in colour, with a little metal cap or stud on the end. sometimes , the knob wears and you cant push it down far enough to lock the magnet when the flame is on. Pull the knob off and try stuffing a little bit of paper down the hole in the knob which goes onto the gascock shaft.. This will allow you to push the shaft down further and thus ensure the magnet is locking onto the gascock. If you are unsure, try a knob from one of the other burners that you are not having trouble with and see if that works, if it does, then you know its the knob, Cheers, Steve
Jan 05, 2015 | Cooktops
Does model XFG371LVQ Whirlpool stove have air adjustment for top burners?
Remove the front panel to find where the gas injectors enter the burner tubes you will see they are cut away and have a screw holding an outer ring which is adjustable, open them up more to get more air in .
May 16, 2014 | Whirlpool Stove / Oven / Range Cooktop -...
My Neff T67S76NO hob has a Wok burner problem, I think. The inner ring flames are fine but the outer ring can't be turned above half on before the flames start to go ragged. The more it's turned up th
it sounds to me that u need to reduce pressure although u say pressure is correct try reducing pressure and see what happens i presume u use bottle gas L P G?............in any case the flame shud not ever lift of burner and flame doesn't need to touch pan to cook hope this helps
Jan 07, 2014 | Cooktops
Flame height on my 36 " 6 burner Viking Range Top
remove the knob, the center shaft is hollow, slide in a small blade screw driver to adjust the flame cheers
Dec 11, 2013 | Viking VGRT360-6B 36 in. Gas Cooktop
The gass burners seem to not give as much flame as they used to.
Your problem could be or probably is with the regulator...not enough gas pressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101
Jan 18, 2011 | Jenn-Air JGC8536 Gas Cooktop
Gas stove burner will not turn on
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Apr 29, 2010 | Gaggenau 23 in. KG 260 Gas Cooktop
The flame is too high on my GE Profile gas cooktop
I had the same issue on my jgp975 and sadly I had to purchase a different unit. I use simmer frequently and I made the assumption that low was simmer. Wrong. I believe a true simmer is 450 btu and my unit did not go that low. I had to check the fine print/specs page and on some units the manufacturer had to be called. I did replace with another ge profile that did have the low setting.
Apr 06, 2010 | GE 36 in.JGP970 Gas Cooktop
Ge Monogram Gas Cooktop - won't boil water - burners seem like they are starved for gas
Bret, lets give this a try. 1st look at the regulator. There is an arrow on it that has to point towards the cooktop. Put is on backwards and very little gas flow. I always advise this first as I have seen people tell me it is correct and when I got out there it was reversed. 2nd was this used as a live demo unit on Propane? If you are on natural gas, this will also happen. The 3rd thing I also check for in something in the gas line on the cooktop side. I had a unit that got some packing in the line and at 5 wc for natural gas, it doesn't take much to restrict. Hope this helps.
Aug 09, 2008 | GE Cooktops
Kenmore 30 in. 32384 / 32385 / 32389 Gas Cooktop Logo
166 people viewed this question
Top Kenmore Cooktops Experts
Dan Webster
Dan Webster
jdthefixer
mcgsp
Level 1 Expert
Are you a Kenmore Cooktop Expert? Answer questions, earn points and help others
