Question about JVC Cybercam GR-DVL520 Mini DV Digital Camcorder
JVC GR-DVL520 Problems
Hi there this camera is giving me grief. I'm getting unit in safeguard mode, eject and reinsert tape. I've done this and even try another tape, still no luck. This camera is just not working. I have tapes which was recorded in LP mode, I cannot view them cos the recorder decided one day to change it from LP to SP. Now I cannot change this.
    President:
  • 4,402 Answers
Try tapping it on the side.
-only, only, only use the more expensive JVC tapes. They keep their tension far better than cheaper brands. Also, they won't rub off their oxide coatings on the heads as easily, avoiding the 'clogging' of the heads (which thereby requires constant cleaning-further damaging the heads).
-when and if you do get E- errors do a complete rewind or fast forward to the end of the tape in order to pull out tape slack. Then remove battery and tape for a while. If still screwed, then yes, sharply tap (not hard!) on the closed tape door. That may reposition those tiny switches that I mentioned earlier and get you going again.
-NEVER, EVER, EVER, leave tapes in the machine when not in use....it creates problems for the heads and the mechanisms.
-Don't leave the battery on the camera when not in use for extended periods of time. It can create problems with respect to resetting the computer controlled logic.
-there are little switches and interlocks that provide electrical feedback about the mechanical status of things to the main processor of the camera (ie. tape/no tape in camera, door open/closed etc). Over time, the mechanics get out of adjustment because of usage, humidity and certainly rough handling. So: treat the mechanisms very, very, very delicately. Don't use/store the camera in humid conditions, hot conditions or very cold conditions. Certainly don't leave it in your car---ever!
-get the camera "cleaned and ajusted" regularly to avoid these problems. (I know...more $$$$)
-I keep bags of dessicant in an insulated camera bag with the camera to maintain dryness and optimal temperatures during storage.
Posted on Dec 20, 2007
Keep getting E03 error indication. Ejecting and reinsertion of the tape does not seem to be fixing the problem, also says unit in safeguard mode. What do I do to remedy this?
where your battery goes in,on the side , theres a little hole should say reset,get a niddle and push it and after you reset it ,it should work,make sure its on when you do it .if my info is of any help to you please leave me a comment ,thankyou.
Sep 02, 2009 | JVC Cybercam GR-DVL520 Mini DV Digital...
My JVC GR-D77OU Mini DV Digital Camcorder is giving me the next messages: eject en reinsert tape. unit in safeguard mode. After ejectirn and reinserting the video tape it still does the samething. I have...
Remove the battery and or the power supply (plug), leave it out for a few minutes, then reattach. This should solve your problem.
Let me know if this helps....
Jan 03, 2009 | JVC GR-D370 Mini DV Digital Camcorder
Unit stuck in safeguard mode
I can't find e setup for sony
camcorder
Dec 30, 2008 | JVC GR-D270 Mini DV Digital Camcorder
Jvc digital video camera mini dv gr-d244u
I have had the same problem...usually had success by taking off the battery, putting it back on, turning the power off and on, etc.  It has always gone back in eventually.  I also tried re-charging the battery and replacing.  Could this be an old battery problem?  Mine is 4.5 years old.
Jan 06, 2008 | Panasonic Palmcorder PV-GS9 Mini DV...
Safegaurd mode
Unfortunately this is a repair issue. There are several failures that can occur, none of which will be resolved without service, that create this safeguard situation. Often the fpc cable which carries sensor information to the micro has been injured and that requires repair. Good luck, magic seadog
Aug 07, 2007 | JVC GR-D240 Mini DV Digital Camcorder
JVC Cybercam GR-DVL520 Mini DV Digital Camcorder Logo
136 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Steven Wander
Steven Wander
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
