Question about Sony Playstation 3 (PS3) Console
PS3 won't connect to TV with component video.
After switching my connection from component video to HDM, I I tried to switch it back to component video but the TV doesn't detect the PS3 it just has a blank screen.
  • 5 more comments
  • Anonymous Dec 12, 2008
    I have the same problem!
  • Anonymous Dec 29, 2008
    MY PSĀ£ only seem sto work with the HDMI connection, great in the loung om the Plasma but its deemed abit antisocial for me to take over that TV as a games console ! Help Please !
  • sologhost Jan 13, 2009
    i have the same problem. i made the mistake of buying new cords and everything
  • Anonymous Jan 16, 2009
    I Have the same problem
  • Anonymous Jan 20, 2009
  • Maximusceo Jan 20, 2009
    Console will only play through HDMI connection!
  • Anonymous Jan 26, 2009
    i have the same problem what is the deal to i have to reset it or something
You need to connect the PS3 to the television with both connectors (HDMI and Component). Then in the display settings change it from HDMI to component and during the 30 seconds that the screen goes black you need to disconnect your HDMI cable from your playstation. Then switch to the input that the component cable is connected to on your television (ie. AV1, AV2, etc). From here you will see the countdown for the test and you can continue with these settings.
Posted on Feb 01, 2009
I connected my Playstation 3 on HDMI setting on my friends TV but now his TV wont work so now I'm at my house with my tv wich doesnt have HDMI so I need to switch it back to component without a TV
Posted on Oct 12, 2009
Not getting outout from the PS3 to the TV
Hold the power button on PS3 to reset. When switching from hdmi or s video the ps3 needs to be reset to acknowledge the different video connection. Wont change anything on ur system just video feed. Lots of info on utube re
Oct 03, 2012 | Sony Playstation 3 (PS3) Console
I am trying to connect my ps3 to this TV. i have tried with AV ables and through HDMI but it does not seem to work. is there a problem with compatability?
PS3 outputs hi definition video through HDMI ie 1080p. Your tv will not support that resolution. Because its a HD ready one ie 1080i. If you wnat to connect the PS3 through the hdmi then you have to down convert the video output resolution of PS3 to 1080i. for that you have to connect the PS3 to any FULL HD tv and go to the HDMI video setup and down convert the resolution to 1080i. After that you can connect the PS3 to you tv. Surely you will get the video.
There is one more way to get the video in you tv. connect the PS3's component video output to the component video input of you tv and the audio output to the corresponding component audio input . Select component video input on the tv. You need a component video cable and a stereo RCA cable for that.
Aug 29, 2011 | LG 42PC1DV 42 in. EDTV-Ready Plasma...
Connecting Ps3 with philips tv (full hd) when i got hd cable in, and click to switch so the ps3 uses hd to show things and i than switch over to the channel i plugin the hdmi cabel it gives blac kscreen
If it's the first time using your PS3, use the composite cables that came with it. Turn on the PS3 go to video settings and switch the input to HDMI. After you've switched to HDMI, turn the PS3 off and connect your HDMI cable, go back to video settings and change the resolution to 1080p. If this isn't the first time you've used HDMI for your PS3, make sure your T.V. is on the correct input. If the T.V. is on the correct input, try switching the HDMI cable to a different input. If that doesn't work try using a different HDMI cable, testing different HDMI connections if you're still getting the black screen. If none of those work then it's probably a problem with the PS3, but just to make sure try plugging something else with HDMI to see if that works. If another HDMI device works, then it's your PS3, if it doesn't then it could be a problem with your HDMI connections on the T.V.
May 04, 2011 | Philips 52 In. LCD HDTV
How do i connect my ps3 to my tv
You should have 2 options with your PS3 system that are included, and a couple more if you buy extra accessories. First, (and the best option) is to use the HDMI cable that came with your PS3. Simply plug it into the back of the PS3 and into one of the available HDMI slots on the TV (preferrably "HDMI 1", power up the PS3 with the switch in the back, then press the power button on the front. It should recognize that you've connected the PS3 to an HDMI cable and you just have to switch the TV to the "HDMI 1 input" with the remote. Done.
Next option (included with the PS3) is the RCA (A/V) cable which is the red/white/YELLOW cable. Connect these wires to the PS3 and the TV keeping with the color code and find the "Video 1" input with the remote. This time you may need to switch on the power of the PS3 in the back but press and HOLD the power button on the front until you hear 2 consecutive beeps which will switch the PS3 back to the factory setting of the A/V cable.
There are 2 other options using accessories for "Component Video" and "Coaxial" (same as a cable/satellite box) but the process is essentially the same. These cables are not usually included in a new PS3 console and will have to be purchased separate.
Also, in order from best picture to not-so-great picture would be: HDMI (Best), Component, A/V (RCA), and Coaxial (not-so-great). Good luck and enjoy your PS3, it has so much you can do, without having to pay extra like another popular console out there, like free blue-ray compatibility, free online game play, some free DLC for certain games, and now they're updating all the PS3's to support 3D GAMES AND MOVIES!!! :D
Dec 19, 2010 | Mintek DTV-263 26 in. LCD Television
Component Cable problem
Ok there can be a quick solution to this problem if you have ever used a hdmi cable this could have caused the problem. try to do a front reset turn off the ps3 with the switch in the back then hold the front power on switch while still holding it turn on the back switch stll hold it and wait till it beeps twice on the second beep release this should sole the problem. if not reply back.
Jan 26, 2009 | Sony Playstation 3 (PS3) Console
Connecting ps3 to a standard tv
I think that you should have a button on the remote which lets you switch to the auxilliary connection of the TV (it won't switch automatically). Try putting it on AV1 AV2 or AUX or such modes you have to refer to your TV manual to see how to switch exactly to the Video Line in Connection.
This should solve your problem :)
Cheers :)
Jan 07, 2009 | Sony Playstation 3 (PS3) Console
PS3 - tv says no signal
You need to change the resolution output on your PS3 to match the capabilities of your TV. If your TV is not HD you can't leave the PS3's video output on HD. SCART is for european television connections. Have you tried using component cables? Have you tried changing your tv's source to Video 1 or Component 1 or HDMI or anything that might work? Good luck!!
Sep 30, 2008 | Sony Playstation 3 (PS3) Console
How to Connect HDMI Components with AVR 3805 as Hub
In reference to the comment you added to our chat session:
Just connect your receiver to your TV using the same cable your receiver is currently using to connect to your TV, be it Composite, S-Video, or Component. Just switch your TV to that input when you need to set-up something on the receiver.
Jul 09, 2008 | Denon AVR-3805 Receiver
PS3 conection cables
Suggest using HDMI or Component Video if you can. They provide the best picture quality. Should be able to use RCAs if need to.
Try switching the TV Mode. TV may have multiple modes if you have multiple connections.
Mar 24, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
1,968 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
