Question about Kenmore 62602 Electric Dryer
My Kenmore dryer turns on as soon as the timer is set .
I don't have to push the Start button
  • ev_linda Nov 22, 2008
    I disconnected the Start button to test it and found that the contacts were dirty.
  • 24 Answers
So... are you saying it now works ok?
Gary
Posted on Nov 23, 2008
  • 24 Answers
Two possibilities:
1) Least likely cause. Start button is not opening when released. Don't know how far you wish to go with this but it will require some troubleshooting.
2) Most likely cause. Motor start switch has a set of contacts that close when the dryer starts and this set of contacts "seals" around the push button. If this is the case, a new switch is in order. Switch is normally replaceable without replacing the motor.
Other option is use "as is".
Posted on Nov 20, 2008
Dryer stops but the timer continues on
Fixed! The "push to start" button was stuck. Must have been some dust. I pushed the knob a few times and that's all it took. Works fine now.
Dec 12, 2009 | Kenmore Dryers
Kenmore Dryer 70 Series. Push switch in and just a little clicking noise. No motion. Took top & front panel off, belt appears to be fine. Suggestions Please??
set timer push button in for dryer to start dryer did not start, timer is working and door light is on,what could be the problem
Oct 17, 2009 | Kenmore 60172 Electric Commercial Dryer
Starts automatically when I set the timer
This could be a problem with the start button switch (it should click when pressed/released) or with the switch on the motor.
May 20, 2009 | Dryers
Dryer won't start
Check your door switch and wires to see if they are damaged first.You may have a bad Start Switch.If it is a 2 wire switch you can tape them together and then plug in dryer ,if it starts,replace the Start switch. Please Rate this!
Jun 12, 2008 | Kenmore Dryers
Kenmore Dryer
The start button works like a push-on switch that engages the timer switch. It's all one unit. It isn't engaging because the internal lever the engages the switch is either broken or worn out. The start timer/switch will need to be replaced.
Jul 09, 2007 | Fisher and Paykel DG05 Gas Dryer
My Dryer Starts, then stops as soon as I release the button.
Its possible the dryer heat selector is at fault. If the timer inside does not move to the end of the heat cycle you may have further problems. Depending on how old the dryer and how long it has taken to dry garments, you may want to check that the motor has not gone bad causing an electrical overload. Faulty timers will cause extended drying times eventually putting a strain on the motor's bearings and electrical windings. You may want to get a replacement or get a repair estimate to repalce the belt, motor, drum rollers and heating coil components.
May 12, 2007 | Kenmore 63932 Electric Dryer
Kenmore 62602 Electric Dryer Logo
253 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
