Question about Sony SDP-EP9ES Receiver
SDP EP9ES Will not show on display "Dolby Digital"
When I use my DVD player that is Dolby Digital and DTS the Sony will not correctly switch over to the correct sound field. I am using movies that are encoded "Dolby Digital or DTS. The screen on the Sony unit shows "Stereo PCM". The correct soundfield switch does happen when using our DVI connected cable box and a show comes on that is encoded as Dolby Digital. I even bought a new DVD player and hooked it up with the same results. I have also tried several of my DVD's with the same results.
5 Suggested Answers
otacon
  • 1950 Answers
SOURCE: No Audio
Your receiver is the Denon AVR 2105 and not the Sony STR-DG510 5.1 Channels Receiver?
Posted on Jan 20, 2008
SOURCE: Sony SDP-EP9ES
It is a preamplifier with sound processing which is sometimes referred to as pre pro... There is a simple solution to lack of DTS, the unit has 5 analog bypas inputs, bypass as they do not go through units Digital Signal Processing circuitry and DD processor.
If you have a DVD/BD player that has five (or more) analog outpusts you plug them in into your preamp and have the player decode DTS to analog signal. If the player has five analog outputs it mostly like has the on-board decoder. Other than this you can use a stand-analog DTS decoder in the same manner but it sounds like a cumbersome and costly alternative. Hope this helps.
Posted on Jan 21, 2009
mlapres
  • 757 Answers
SOURCE: Sony PCM 48 Issue
As long as you continue to have both HDMI and optical outputs connected at same time from the cable box, it will probably always choose the default as HDMI. If you do not want to change any connections then the best thing to do in this case is to always leave the cable box turned on. Otherwise, disconnect the HDMI and connect it to the TV by component video.
Posted on Jun 18, 2009
mlapres
  • 757 Answers
SOURCE: how can i get the dts sound field to work.
If you are playing media that has both dolby digital audio and dts audio, your player and your receiver will decode the first audio codec listed first by default unless you select it otherwise yourself. If your remote or receiver has an A.F.D. (auto format decode) button, press it until your display shows that the sound source is dolby digital or DTS, whichever sound mode it was you wanted when you started your DVD.
Posted on Dec 12, 2009
Is there a way to read Blue ray disc from Europe on a sony BDP-S1200?
No! Sony has kindly locked there BDP range of BluRay players to the region country they were made for only and not multi region.
Jan 18, 2015 | Sony BDP-S1200 Blu-ray Disc Player - 1080p...
Unlock Sony BDP-S1200
Have you been playing cd etc from different countries. The cd units in this country will lock you out after about three tries, that is the law.
Dec 19, 2014 | Sony BDP-S1200 Blu-ray Disc Player - 1080p...
How to unlock regional code of philips HTB3510 3d blueray player?
Check current region code
Open the Philips HOME Screen
Type on your remote: 8520
This will display all of the current settings for your player.
Example: Region_Code: DVD(2) BD(B)Change region code
Turn on player with no disk inserted
Press "Open/Close" on the remote control until the tray is open
Press 8689310 - 0 means all region
Press 8689311 - 1 means region 1,
Press 8689312 - 2 means region 2,
Press 8689313 - 3 means region 3,
Press 8689314 - 4 means region 4,
Press 8689315 - 5 means region 5,
Press 8689316 - 6 means region 6.
Now the front Buttons might not work!
Go to SETUP and click on RESET FACTORY SETTINGS
Wait until the player restarts and now you can play all DVD regions
Oct 08, 2014 | Philips HTB3510 5.1 3D Home Theater System...
How to make aSAMSUNG HT-F6500W region free (hack-code) as I am an expat
1) Switch Player off then On (this is to clean-boot firmware).
2) Wait until main menu appears
3) Open Disc Tray and Close Disc Tray (May not be necessary)
4) As soon as "No Disc" is displayed quickly press REPEAT on
remote quickly use the following code for your current
region:
Region 1: Press - 2,9,3,3,4
Region 2: Press - 5,7,5,3,8
Region 3: Press - 5,6,7,3,2
Region 4: Press - 7,6,8,8,4
Region 5: Press - 5,3,8,1,4
Region 6: Press - 2,4,4,6,2
5) Your current Region will appear in the top-right corner
6) Quickly Press "9" before it disappears (It should replace
the code with a "9" in the cThere isn`t currently a region hack for Blue-Ray Disksorner)
7) Switch Player Off and then On again.
Note that REPEAT is part of the code so one smooth press of
6 keys is required.
Dec 24, 2013 | Samsung HT-F6500W/ZA Home Theater System -...
Onkyo HT-S3400 not showing DTS-HD Master Audio
Hello, with the source playing press the display button on the remote. What format do you see? Thank you, CB
Apr 05, 2017 | Onkyo 5.1-Channel Home Theater Package...
How can i get the dts sound field to work. Shouldn't it automatically switch to that sound field. I have a samsung bluray dvd that hooked up to it.  The dolby pro logic and pro logic 2 indicator...
Dec 12, 2009 | Sony STR-DE597 Receiver
Not showing DTS MASTEr OR DG True HD
In the menu is an option for switching master and true hd on. Standard its of and played als normal dts/dolby.
also: check the input (blu ray?): maybe it is set to only output no high def signals, so the amlifier doest recieve hd sound..
Igor
Dec 14, 2008 | Audio Players & Recorders
Sony SDP-EP9ES
Apr 26, 2008 | Sony SDP-EP9ES Receiver
Problem with Dolby Digital mode
If it is a new DVD that may be a problem, as signal changes may be frustrating this old machine... but it is likely the cabling from the DVD player to the reciever. Are you on the right channels/settings? is the optical cable and digital cable recieving digital output from your DVD player? Try changing those settings and you should be in good shape Thanks! good luck!
Jul 22, 2007 | Yamaha RX-V3300 Receiver
61 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
