Question about Electronics - Others
My lamp keeps shutting off
I have a magnifying lamp floor model, it keeps shutting off, I opened it up and there is a loose wire that has a ring on the end of it, I do believe it is the ground wire and don't know what to hook it to when I put the elec unit back in, it is a Jim Long Super Silent ________ Limited machiac? itss 110 V tw 105 thats all I can see.
  • 102 Answers
Just put that ground wire under any nut that it will reach to. Just be sure that there's no paint that will inhibit grounding
Posted on Dec 04, 2008
Hello my name is Devin, I have a wd-65735 model and I just purchased it off of a friend and braught it home. He had told us from laying it on its side while bringing it home it said in the guide to let it...
Caveat: I am not a tech, I just read through the Mitsubishi service manual, and have worked on different model TV that I have owned (older model of this one) I am a little unclear on the second set of lights but I think the combination *may* indicate that the lamp fan is not starting (there are two fans though), if the blinking red is the status light. It is possible the connector for that got jostled during the trip, something fell into it from being on the side (wire or loose something) and is blocking it from spinning now, or a module unseated a bit,and is loose, or the lamp is no longer seated correctly (though the lamp light does not appear to be on) or none of these. :) These are just guesses.
Be careful if you open it up, due to potential for shock. Wear gloves, and power it down first (then unplug). Reseat any fan connectors.
Google: I used "wd-65735 status lights" to find a service pdf , it's for V39 chassis (several models)
From page 24 of Service Manual :
3. Error Code Operational Check Note: The TV must be in "Shut Down" and not have been switched Off, to perform the Error Code Opera- tional Check. When the TV is switched Off, the code automatically resets to "12" No Error.
Pressing the front panel "INPUT" and "MENU" buttons at the same time, and holding for 5 seconds, activates the Error Code Mode. The "TIMER LED" flashes denoting a two digit Error Code, or indicating no problem has occurred since the last Initialization.
Note: The front panel buttons must be used, NOT those on the Remote Control.
  • ThenumberofflashesindicatesthevalueoftheMSD(tensdigit)oftheErrorCode.
  • Theflashingthenpausesforapproximately1/2second.
  • TheLEDthenflashesindicatingthevalueoftheLSD(onesdigit)oftheErrorCode.
  • The Error Code is repeated a total of 5 times. Example: If the Error Code is "23", the LED will flash two times, pause, and then flash three times.
Page 24
MODELS: WD-60735 / WD-60C8 / WD-65735 / WD-65736 / WD-65835 / WD-65C8 / WD-73735 / WD-73736 / WD-73835 / WD-73C8
4. Error Codes
The Error Code designations indicating malfunction, or no malfunction, are listed below:
ERROR CODES page25image3968
Code
Description
Most Likely Cause
12
No Error found
17
Communication loss, TV Micro - Engine (3.3V-ENG-SDA & SCL)
Engine Failure
18
Engine will not accept data (ASIC-READY signal from Engine is not detected).
Loss of 12V from PWB-POWER (Loose PE or PE2 connector); Bad Color Wheel (Loose J6 or J7 connector); Engine Failure
32
Lamp cover is open.
Lamp Cover Switch; Loose CD connector
34
Lamp turns Off while the TV is playing. Lamp failure
(Lamp Enable signal from engine is lost)
Lamp Cartridge Failure
36
Exhaust Fan failed.
Loose J4 connector
37
Engine (DMD) fan failed.
Loose J5 connector
38
Lamp temperature abnormally high.
Poor Air Circulation; Loose J3 connector
39
DMD temperature abnormally high.
41
Standby Supply Short is detected. (5VS or 3.3VS)
PWB-MAIN Failure
42
Sirocco fan failed (Lamp fan).
Loose J8 connector
44
Check for disconnected DVI cable between PWB-DM and Engine. (Engine pulls DVI pin 14 Low)
DVI Cable unplugged
48
PON-SHORT 3.3V switched supply short
PWB-MAIN Failure
57
Ballast communication problem (ballast to chassis)
Loss of 340V from PWB-POWER (PL or CJ1 connector); Loose FB or CJ3 connector; Ballast Failure
61
No LAMP-EN output from the engine to the ballast
66
Lamp did not turn on at P-ON sequence
(No Lamp inserted)
(Disconnected cable between ballast and lamp) (Lamp-Enable goes to DM but not to Ballast)
Loose CJ4 connector;
No Lamp Inserted;
HV connection or lead wire to lamp; Lamp Cartridge Failure
Code 34(1) - Lamp Enable is generated to activate the Lamp
Code 57(2) - Lamp Enable is generated during P-ON sequence, but no Lamplit signal is received from the Ballast. Code61(3) -NoLampEnableisreceivedattheDMandBallast.
Code 66 (4) - Lamp enable is received at the DM but not at the Ballast.
4. Error Code Log
The Error Code Log - may be helpful to retrieve the code for an error the occurred in the past. To access the Error Code Log: Press <MENU> <3-5-6-4>
Oct 27, 2014 | Televison & Video
My dodge Daytona cuts off while stopped
fuel pump fuel filter or the pick up module on the distributor
Jul 27, 2013 | Cars & Trucks
Keeps going off every 15 minutes then showing no signal
Please check if the fan filter is clogged or the lamp heat is too much. If so the lamp can shut off, so use a good cooling fan to see if the shut down stops, if not the projector power or the lamp circuit must be checked for a loose connection., or possible power supply load breakdown.
Sep 29, 2010 | Office Equipment & Supplies
Zanussi tc7103w condenser dryer-water tank light keeps coming on when tank is empty or nearly empty-have found small plastic float and spring on floor behind dryer-where do they fit?
I had this problem. If you look at the valve on the plastic water tank, you will see that those parts are the same. They fit inside the tumble dryer to shut off the water from flowing onto the floor when the water tank is removed. The white hollow cylinders in the tumble dryer and the water tank push each other open. If you study the water valve on the tank you will see how it is put together. It is all held in place by a little 9mm O ring at the back of the valve. The ring gets tired after a while and pops off. The valve then falls apart and you find the cylinder and spring on the floor and the O ring still inside the dryer. I bought an O ring kit and reassembled the valve inside the dryer using a new ring. You will have to pull the dryer out, turn it upside down and remove the floor to do this
Sep 23, 2010 | Dryers
MWhere is the noise elimantor for the radio sometimes when I am driving and hit a bump the sound of the engine comes into the radio speakers I have to shut the radio off it is so loud
Hello! Engine noise is removed via shielded cable...The shields are then grounded to the chassis...They are loose or corroded at the contact point...Rather than hunt for its location...You can ground it to the floor pan...If your vehicle is equipped with the Premium sound system...Pins #3 and #7 on the 8 pin radio connector are the shields...Splice two runs of 10 gauge Green wire to each of these pins and connect both ends to a ring connector...Solder connections...Bolt ring connector to the floor pan...Insure contact point is bare metal...
Guru..............Saailer
Aug 27, 2010 | 2003 Ford Mustang
How is the floormat on the drivers side attached to the floor rug? There seems to be two metal rings, one in the floor rug and one in the flloor mat. They are not snaps, just rings How is the mat attached...
There is a small plastic hook attached to the floor that goes through the metal ring on the floormat to keep it in place. the hook's open side should face the back of the car, so just pull the mat towards the drivers seat and it should come loose. No clips or anything, just that one hook and ring.
Feb 13, 2010 | 2000 Toyota ECHO
Lamp keeps going out and it makes a ringing sound and then shuts down
Ringng sounds? Checkk fans. Verify the TV has good airflow and the vents are not covered in dust. What model
Jun 24, 2009 | Televison & Video
My 87 honda accord starts when it feels like it, usually acts up when hot or wet outside, can shoot starting fluid in engine and it will start then stall, if keep shooting starting fluid it will eventually...
This problem is the main efi relay located on driver side way up under dash it says main relay right on it! I usually can open them up and resolder the poor solder joints that have small rings around it (may need magnifying glass to see the solder ring burns)
Mar 29, 2009 | 1987 Honda Accord
My screen keeps showing card cover open error.
I had the same problem after a little plastic trigger thing fell out of the hole above where it says push to eject. After poking around for a while I took the camera apart (remove 7 screws) which made it much easier to see, with a magnifying glass and lamp, what the problem was. A damaged wire that needed to be connected to something. Only the very end of the wire was visible, inside a small white plastic box thing. The plastic box thing eventually fell apart with my attempts to put in bits of wire of varying shapes. When it came loose I was left with a short stiff bit of wire. I took a strand of copper wire (from an old piece of electrical wire), twisted it so I had a small loop at one end, looped it over the end of the stiff bit of wire, and then curved the rest of the wire (about 3 - 4 cm long) so it was resting on a silver piece of metal just below where the white plastic box had been. Put the cover back on and the camera worked. Needless to say, it won't let me know if I've left the cover off, but then it won't work unless the cover is on, so it doesn't seem to matter. Saved about $100.
Nov 17, 2006 | Olympus FE-130 Digital Camera
Electronics - Others Logo
61 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
