Question about Reddy Heater RLP100 Portable Forced Air Propane Heater with Variable Heat Ouput
Can not get the bricks to light on my empire corcho
Model # r-15 wall propane heater..empire corcho
i get the pilot light to light but when i try to get 1 brick or 2 bricks or all 3 bricks to light ...the flame goes out i cleaned the bricks with air cleaner but to no change????
i think it might be the part the knob is on that switches it from 1 to 2 to 3 bricks not sure what it is called maybe a regulator of some sort.... anyone have ever had this happen and what can be done thanks bill
  • 1 more comment
  • Anonymous Jan 13, 2009
    Have the same problem. Took a piece of sandpaper and cleaned the thermocouple seemed to help a little. Also try taking a broom straw and clean gas jet for the pilot.
  • michael shemwell Jan 04, 2013
    this happen to me and it was the gas regulator thats between heater and propane tank enough gas was getting by for pilot lite to stay lit but when i turn the knob to get 3 bricks going it wood go out and the only time this wood happen is when it was very cold outside the regulator was freezing up so when it gets real cold i put a drop lite next to regulator and that keeps it from freezing up
  • Kyle Matthews Jan 07, 2014
    i have a 5 brick gas heater, it will only burn on all 5 bricks it suppost to burn 1 2 3 4 or 5 any ideas.
I have the same htr in Mich. & have worked on gas htrs.for many years.
Does the flame go out when you let go of the button to lite it?
If it does, then the thermocouple is bad.
If the flame stays on, but goes out when you turn the dial,
the gas regulator is bad.
Probably a little more expensive to buy new then to fix it.
Michael.
Posted on Nov 22, 2009
Burner for corcho wall moont heater model number ck30t3lt
Search Results
    SunStar Corcho Vent-Free Natural Gas Infrared Heater with ...
    www.efireplacestore.com > ... > SunStar Heating Products Space Heaters
    SunStar Corcho Vent-Free Natural Gas Infrared Heater with Manual Controls ... For added convenience, you can mount this heater on a wall or have it stand on ...
    Tech Video: Wall Heater Maintenance - YouTube
    ? 3:33
    https://www.youtube.com/watch?v=8eglHvyNV3U
    Oct 19, 2010 - Uploaded by FMIPRODUCTS
    How to clean the Vent-Free Wall Heater burner's & pilot. ... Fix Mr Heater Vent Free Pilot Problems - Part ...
    EMPIRE CORCHO UNVENTED GAS HEAT
Dec 14, 2015 | Heating & Cooling
I have an Empire Corcho model CH-15 that is at least 15 years old. I have not used it much until past 2 years. It just started emitting a strong smell and a white powder is laying on the heater, above the...
Since it hasn't been used in at least 15 years, what you're seeing is the dust, dirt and spider webs that are being burned up by the heater. The strong smell is because of the clogged burners. Best suggestion is turn it OFF let it cool completely and thoroughly clean the unit. It may need to be dismantled some so that you can reach and clean everything. A shop vac with a house and brush attachment works well to accomplish this. Pay particular attention to the burner(s) and vacuum them several times. Dry clean everything you possibly can. Then reassemble the heater and relight the pilot and give it a try.
In closing, I must say, having been in the hearth business for 15 years, I' am totally shocked, that after 2 years of neglect, that a 15 year old gas heater would even light.
Apr 07, 2011 | Stoves Heating & Cooling
I have an empire corcho model 15-1. It will not light with the ignition button what are the possible problems? LP gas is to the unit.
ignition out of postion , it needs cleaning , end of ignition brunt off or too short, blocked pilot, ignition shorting out on heater causing short spark
Nov 28, 2010 | Reddy Heater RLP100 Portable Forced Air...
I have a Empire Corcho radiant nature gas space heater that the middle brick panel flairs when on. When the other two bricks light they burn normal (ie no flair or flames except slight flame as bricks heat...
Problem sounds like the incoming gas pressure is too high or the burner below the middle brick has debris or trash clogging some of the openings. Recommended next step is to remove all power / natural gas to the space heater and check all burners for debris or blockage. If burners are clear have your natural gas provider test the incoming gas pressure to ensure it is correct for that appliance.
Dec 13, 2017 | Heating & Cooling
HOW TO LIGHT PILOT ON EMPIRE CORCHO WALL HEATER MODEL R 15
I have tried to light my empire wall furnace by pressing the button and I have the gas on and it won't light
Oct 17, 2009 | Reddy Heater RLP100 Portable Forced Air...
Glo Warm propane heater started to go out. I blew out the pilot with air compressor. It is staying on, but the middle burner in back of the pilot light is flaming a little above the brick. The other...
sounds like when you blew heater out with air compressor you moved brick so flame isn't hitting bottom of brick like they should. You should try and put brick back on top of flame so that you don't get to much heat on the refractory of the heater.The refractory will take the heat for awhile then refractory will start to break down. Then you will either have to install new refractory or replace heater
Jan 17, 2009 | Desa International GWP20T GLOWARM Wall...
Pilot light won't stay lit
Look for dust and lint. Look for them in places where gas should be freely flowing. I had a similar problem with an Empire Corcho wall-mounted propane ceramic catalyst heater. First it was the pilot light, then the #2 ceramic mantle. After horsing around with the gas lines and pressure regulators and trying to re-aim the pilot, it all turned out to be dust and lint in the gas passages. A little dust bunny in the brass pilot tube gave me a pilot light the shape and color of a banana. One puff of compressed air, and I got back my razor-sharp pilot. And some dust in the chimney of the #2 burner kept it burning blue/yellow and blistering paint off the upper surfaces of the heater. A bit of cleaning with a shop-vac put that right. "Passive" heaters are very much prone to this sort of problem because they rely on convection currents (i.e. LOW velocity) to get the job done. Convection currents are notorious dust collectors, as in COBWEB CITY.
Aug 23, 2008 | Heating & Cooling
Heating & Cooling Logo
798 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
