Question about Hotpoint HSS25GFP Side by Side Refrigerator
Hotpoint SXS won't freeze
I have a Hotpoint refrigerator that I bought from the previous home owner, it is now 6 years old. About a year ago, the motor went from humming to almost a clangy sound, at times. Now it won't run, period. I can leave the freezer door open for 20 minutes and it still will not run. Now every 2 weeks or so, I must unplug my fridge for a day to defrost the ice around the evaporator coil. I have been told by co-workers that it could be my thermostat, but that wouldn't explain the clangy noise I use to hear when it was running, would it? I don't want to have to invest in a new refigerator if at all possible. Am I in luck?
  • Jeff Allensworth Dec 18, 2006
    Being the holidays and being hectic around here I haven't got a chance to try your solution. I'm hoping early this week I can. I'm sure I'll need to unplug the refer this week to defrost it.
  • Jeff Allensworth Dec 21, 2006
    After I unplugged the refrigerator and took off the back lower panel, I was cleaning the dust off with a vaccuum and noticed that the fan had dog hair wrapped around the stem. After I cleaned that off, everything started to work. I clean the coils on the bottom of the refrig but never thought about taking the back off. I would not have either unless I received your info. and I thank you very much.
The fan in the freezer starts to run then shuts off repeatedly. If it does start and run it makes a howling sound like whoo-whoo-whoo. Is it the motor or some control?
Posted on Nov 24, 2008
    President:
  • 878 Answers
Igoinsane67, If you are up to doing some tests I think you might be alright. One of your issues sounds like a defrost problem. The defrost heaters probably have failed. This is quite common on these models. The clunking you are hearing from the compresser is probably a broken valve spring and the valve hammers against the inside of the compresser when it shuts off. This is more annoying than trouble. Get youself a jumper wire with some alligator clips attached to the ends. On the back of the refer, under a metal panel there is a motherboard. In the lower left hand corner of the board you will see a 3 pronged blue harness. Here the board should be marked comp. Defr. Line. First test the compressor by taking the jumer wire and jump line to compresser. This will send 120 volts directly to the compresser and it should start and run. Unplug the refer first then attach the jumper and plug the refer back in for this test. Next test the heaters. Take the jumper and jump line to defr. This is sending 120 volts to the heaters. On the inside of the refer, remove the evaporator cover. The heater should be glowing. If not you probably have bad heaters. Your part number for the heater is WR51X10055. Again unplug the refer before jumping the terminals so you don't arch. You can leave the harness on but pulled down a little to get the clips on. Catriver..post back.
Posted on Dec 15, 2006
How old is the Hotpoint Refrigerator model #: CTX14AYBNRWW? Is it at least 10 years old?
Hello;
My name is peter. I am a retired field service refrigeration technician.
All too often people purchase new appliances when the component that failed is about $30.00.
A refrigerator especially a Hotpoint should last you 25-30 years if maintained.
I once had a service call where I had thought the service order was not right. I arrived at the customers home. The unit was 33 years old. I was pleased when I had the repair part on my truck and helped this elder women.
Your unit date is on a label in the fresh food section on the upper inside wall.
I do work part time locally. Give me a call. 443-306-1362.
Glen Burnie, MD.
Mar 12, 2015 | Hotpoint Refrigerators
How to replace defrost timer
a bad defrost timer can be checked with a multi meter
Sep 08, 2014 | Whirlpool Refrigerators
Zdis15
check hot gas valve to make sure it is not bypassing when in freeze mode this will not let the evaporator plate get cold enough. need to check refrigerant pressers.
Jun 07, 2013 | Kitchen Appliances - Others
The ice maker stopped working a year after we purchased. I was told the motor went bad and I need a new one...the spring on the door is broken too...what to do? Will Whirlpool fix it since my home owner...
Yes seeing how your unit is only a year old your unit would still be under warranty if you bought the extension as long as you bought the unit new and not from a second hand or scratch and dent type of business in which if you did then you would have to call them for the warranty. If you bought the unit at lowes on the other hand there is only a one year warranty on the unit so it depends exactly how long ago you purchased the unit and from where. If you have any further questions message me back Thanks Rick
Aug 12, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
I bought Family Tree Maker V-6 years ago, and used it on my previous desktop computers, I just installed it on my current HP Desktop having Windows 7 as my OS. The problem is that whenever I open the...
Register it again. Even trough you already did this, porting the software from its program files folder does not always works fine. Windows' register has these registration saved, and your new PC doesn't.
Apr 06, 2011 | Broderbund Family Tree Maker 11 (382648)...
HOTPOINT/GE REFRIGERATOR NOT DEFROSTING
I have the same problem. A lot of people in forums are telling me it could be the defrost heater. Anyone know how to test it?
Jul 28, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Hotpoint sxs compressor stays running.
Fasnipe, it sounds like you are starting to lose the gas in the unit. Fairly soon, you'll see that the unit will fail to keep things cold. If it is less than 5 years old, you may have a warranty. If more, I suggest you get in a technician when the problem begins to impact the ability to keep food. You cannot fix this yourself.
Jan 24, 2008 | Hotpoint HSS25GFP Side by Side...
Noisy compressor
Is a Hotpoint refrig?? Ge (who makes hotpoint) is having trouble with the freezer fan howling. Check out posts on Ge SxS PSS models. Some say its the main board, i disagree.
Dec 02, 2007 | Hotpoint HSM25GFRSA
Hotpoint HSS25GFP Side by Side Refrigerator Logo
173 people viewed this question
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
Sal De
Steve Allison
Steve Allison
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
