Question about Riccar R552
I have a Riccar 552 and when I wind a bobbin the needle runs
When winding a bobbin, I have to remove the needle because it runs constantly. When I try to loosen the knob as the directions say the needle still moves.
SOURCE: RICCAR MODEL 210B
Well I own a riccar aerostar 210B and the needle won't move. It is run and sounds great the motor runs when I run the bobbin.. can anyone HELP? thank you
Posted on Nov 17, 2008
SOURCE: looping underneath
I watched a 'You Tube' demo that showed ........if you loosen or tighten the very small screw at the base of the bobbin this gives you the correct tension & stops the looping under the fabric........I didn't even know this screw existed ! It is trial & era at first re the correct tension but you do get there.... the art is to do it in small mini stages.....like you hardly move it ! Thanks to 'You Tube' I can now get on and finish my drapes !
Posted on Nov 24, 2009
  • 3 Answers
SOURCE: The bobbin winder will not spin
You model is the same as mine. The bobbin is wound by a plastic gear behind the hand wheel. It probably broke like mine did some years ago. Check with your local repair shop or order it online.
Posted on Feb 28, 2010
  • 92 Answers
SOURCE: looking for hook gear for
The gear is #53741 and is available at most sewing dealers. The part is also available wholesale at sewing machine services in Canada. Also fits riccar, eatons and babylock machines, so a babylock dealer could help. You will have to beg a repair book or photocopy same to ger mounting and setting instructions. We charge about 60 to install and time the part ONLY.
Derek
Posted on Jan 18, 2011
Tally Girl
  • 1133 Answers
SOURCE: The bobbin in the Riccar 9900 will not rotate in
Do you mean that the rotary hook is not rotating fully around the bobbin case to form a stitch?
This could be due to a gear failure in the drive to the rotary hook, usually within the free arm area.
tally_girl_41.jpg It doesn't look like your model has a removable cover plate on the free arm to access this from the top. But there is usually a gear in the freearm area and this can wear or have teeth broken, which prevents the drive of the rotary hook happening.
I would suggest that you contact a local repair shop and ask what they charge to open up the machine, diagnose and quote on the repair to see if worth fixing it.
Posted on Jul 05, 2011
How to wind a bobbin for a 250 electronic Viking Husqvarna machine
Make sure that the presser foot is raised if you are winding a bobbin with the top thread threaded through the needle. Place the bobbin on the spool spindle with the mark (a stylized H) outwards. Bring the bobbin spindle down. Next pull the thread from the needle under the presser foot to the thread guide on the right. Bring the thread above the bobbin and wrap the thread around the bobbin several times. Cut off the excess thread on the thread knife and step on the foot control to wind the bobbin. When the bobbin winding is finished, remove the bobbin from the spindle. Cut the thread to separate the bobbin thread from the needle thread. Move the bobbin spindle up.
Sewingpartsonline.com has a link to the manual for the Husqvarna Viking 250 on the machine specific parts page (under Manuals), http://www.sewingpartsonline.com/viking-250-sewing-machine-parts.aspx . The direct link to the manual is http://manuals.husqvarnaviking.com/VSM/Husqvarna%20Viking/HVManual.nsf/5bc6115484660075c12575d2003f80e3/ecf97dd171581582852575ed00755e7a/$FILE/Viking%20210,%20230,%20250%20%20x.PDF . The bobbin winding steps are on page 12. There is also a method for winding a bobbin with a different thread from the top thread. See the manual.
I hope this helps.
May 28, 2017 | Husqvarna Sewing Machines
My riccar 1900 won't thread; needle to bobbin
First make sure the bobbin-winding spindle (located on top of your machine) has been pushed back to the left for sewing.
If it is not in the correct position, the needle will not go down and pick-up your bobbin thread.
Next make sure your needle is inserted correctly, with the flat side facing back.
Also, make sure your bobbin is in correctly
the upper tension disks of your machine are threaded correctly.
Make sure the presser foot is up when seating the thread through the upper tension.
Turn the handwheel towards you only and hold the needle thread lightly.
If this doesn't help solve your problem, the machine may have a timing problem.
Jan 18, 2016 | Riccar Sewing Machines
Code 88 starts flashing as well as all the stitching lights on the panel when I try to thread the bobbin. I can sew, that is NOT the problem, threading the bobbin is. What is Code 88? I am not interested...
Turn your machine off and leave it off. Remove all bobbins - in the machine & from the pin. Remove all thread - from threaded machine and bobbin thread path. Clip the machine thread at the spool and pull the needle thread towards yourself. Clip bobbin thread at spool and close to bobbin, then pull towards you through thread guides. This keeps the tension where it belongs. Move the bobbin winding shaft from normal sewing back to winding bobbin a couple times. It should click in place when moved to the winding position. Check to see if there is any thread that has slipped under the bottom of the bobbin and wound itself around & under the bottom of the shaft. Carefully unwind to clear. If the shaft does not easily move back to the sewing position it is probably stuck in the winding position. Don't force it, but try to get it out of the winding position. Leave it to the left in the normal sewing position (unclicked). Check to see if there is any thread caught anywhere along the path from spool to the winding pin. Pay close attention to the first thread guide and the two discs the thread slips between that control tension. Hand wind the wheel on the right towards you to raise and lower the needle a couple of times. Stop with needle in highest position. Do NOT wind hand wheel backwards (away from you). Make sure the bobbin pin is not in the winding position. Now turn on your machine. Needle should jump to default position. Move the stitch length and stitch width guides to the far right, then far left, to attain the green lights. Press the reverse stitch button to raise lower and raise the needle. It will stop in the highest position. If you still have the error code - make sure the bobbin winding pin is NOT in the winding position. Remove the needle. Lower the presser foot and run the machine without any thread a bit. If the needle bar does not go up and down most likely the bobbin pin is stuck in the winding position. If the code has cleared use your manual to carefully wind a new bobbin. Make sure you are using a 15J bobbin which this machine requires. It will not work with just any bobbin. Next, raise the presser foot then carefully thread the machine. If you don't have a manual you can download one from the Singer website. You might consider cleaning the entire machine paying special attention to the hook area and feed dogs while the power is off. If you find a lot of lint do this more frequently to prevent buildup. Take special care when replacing the bobbin care. Hope this helps. If not call Singer. It may take some time but you should be able to reach someone to help you troubleshoot. If this is an older machine I recommend taking it for repair yourself instead of sending to Singer
reference: http://www.amazon.com/Singer-7466-Electronic-Sewing-Machine/forum/Fx3BSOY0VA78VQ4/-/1?_encoding=UTF8&asin=B000B91B3K
Mar 28, 2015 | Sewing Machines
Why always in bobbin-winding mode?
bobbin winder still engaged. try moving it.
Aug 14, 2014 | Sewing Machines
When I wind a bobbin, it makes a screeching noise and the needle goes up and down. What step am I missing ?
On the right side is a big wheel and in the middle a smaller one. You need to unlock the smaller wheel so that the needle mechanism does not run when re-winding a bobbin. You need to use both hands to do it. Hold the bigger wheel and then loosen the inner wheel anti clock wise. Once you have finished loading your bobbin you need to tighten the inner wheel again for the machine to be fully functional again.
Jan 12, 2014 | Singer 7436 - INGENUITY
I only want to know if the wheel must be loosened to wind the bobbin and if so with direction, to the front or backwards and press and turn or pull and turn.thanks
Which make and model sewing machine do you have?
None of my sewing machines need the wheel to be loosened for bobbin winding. The Singer Touch & Sew bobbins are filled in place. Use the handwheel to get the needle into the highest position (just turn the wheel). Wrap the top thread around the screw that holds the presser foot; open the slide plate part way and press the bobbin wind button. Hold the top thread and then begin winding by stepping on the foot pedal.. The thread should break after a few winds.
The Kenmore and the Husqvarna Vikings both get wound at the top. Place bobbin on winding pin. With the needle up and metal presser foot in place thread the top thread up to the bobbin (through the guides) and up through the hole in the bobbin. Slide the bobbin winding switch over towards the bobbin. Hold the thread tightly and begin winding (step on the foot control). After a few winds are on the bobbin, cut the thread that you were holding flush with the top of the bobbin. Continue winding the bobbin. (The newest Viking in the group has a computer screen; on that one, do not press OK until done winding the bobbin.)
However, if the handwheel is not turning and the needle is down, first find out why it isn't turning properly. This could indicate a tangle of thread somewhere in the system. (The older Husqvarna sewing machine in my home has a non-functional handwheel. The machine will still sew but you have to use the needle up/down switch that forces the needle to stop in the up position before you run out of bobbin.)
Please add a comment with the specifics of your sewing machine and I'll be glad to add additional information.
I hope this helps.
Feb 28, 2012 | Sewing Machines
I wound a new bobbin and now I can't get it on the bobbin winding spindle. I have the exact same problem with a husqvarna 400
When you wind a bobbin on a Husqvarna and you leave the machine threaded to wind the bobbin through the needle, you must take the thread down below the foot (a metal foot only) before you take the thread up to the bobbin winder. If you take the thread directly from the needle it creates too much tension on the thread and crushes the center of the bobbin so that either you can't get the bobbin off the spindle or in some cases it damages the bobbin completely.
Some threads, the kind that can stretch slightly when pulled, shouldn't be wound through the needle at all. Instead go through the first guilde and then straight down to the little metal "button like" guide and then to the bobbin. It will create much less tension on the thread and wind it much better.
Oct 11, 2009 | Husqvarna Designer I
Bobbin won't come off the winding spindle
Your bobbin was basically crushed slightly, to remove it simply take the thread off the bobbin and it will come off very easily.
Electrical problem?
Neither the needle up/down or the LED for the stitch selector will work if the bobbin winding pin/holder is pushed to the right (meaning pushed into the winding position). If you accidentally left the winding pin/holder pushed over, you will lose the functions of both the LEAD and the needle up/down button! (Neither of these functions can work while in bobbin winding mode!)
Nov 04, 2008 | Janome 4623 Mechanical Sewing Machine
Bobbin Winding
How do I wet wind a 2 inchs long bobbin using varnish.
Thanks
Gholam
Jun 16, 2008 | PfaFF Creative 7570
Riccar R552 Logo
Top Riccar Sewing Machines Experts
Tally Girl
Tally Girl
Joseph Mueller
Joseph Mueller
Are you a Riccar Sewing Machine Expert? Answer questions, earn points and help others
