Question about JVC RX-9010V Receiver
JVC receiver shows power, but won't turn on
I checked for a fuse, can't find; I was pumping Public Enemy loud, after that tune, the receiver just stopped. The usual symptom is that the receiver will shut down and say overload, this time it just shut down. I can turn it on, but it just shows lights on the function button, but that's the extent. There is no display, no sound, shows power but that is it. Then it just shuts down.......Help
  • 1 more comment
  • Proshooter Sep 22, 2008
    My JVC receiver started doing the exact smae thing about a month ago. On the front the red power light is illuminated (when it's turned off to show it's plugged in). After turning it on it starts to light up the display but after less than 2 seconds powers off. I have'nt taken the time to pull it out and open it up, but would like to know if someone figures out a fix short of just replacing the whole thing. Thanks.
  • Anonymous Dec 18, 2008
    yeah mine does same now recon a transformer or summut has decided to get lazy da bugger
  • Evan Ballantyne
    Evan Ballantyne Sep 19, 2018
    Did you fix it
Power will not turn on pleas help
Posted on Sep 19, 2018
  • 29 Answers
Your receiver have a bad channel, maybe is a couple of damage
transistor.
Your need indentificate and change the transistors.
Posted on Jan 04, 2010
Fujitsu,
The above describes my same issue w/ my JVC RX-9010 receiver.
How do you determine if a transistor is bad? What equipment besides an analog multimeter would I need? I am out of work so replacing this is not an option. I can solder as well so if I can ID the transistor I gather I can repair this cheaply? Many Thanks!
Posted on May 12, 2010
SOURCE:
Loud drilling noise when coffee switch is turned on - rather than the usual purring noise - and no coffee delivery either
How old is your machine ? and what maintenance have you done over time such as replacing the shower curtain located at the pourring end of the hot water ? I had too very loud noise coming occasionnally from the stainless steel rack holding the cup while coffee is delivered. If your ground coffee is too fine it will stop flow during making a shot. Is water coming out when no coffee is placed in the portafilter.The water pump on this machine is a cheap pump that has to be replaced over time. Mine is 7 years old and has delivered four cups of expresso everyday of the year, and still working.3841c994-fb4b-459f-8d1f-710e0aafc3c0.jpg 2ead4f70-37c6-4236-a9c2-992dba149c4c.jpg
May 29, 2014 | Rancilio Silvia Espresso Machine
Is tomorrow a public holiday the 10 of decamber
Holidays vary from country to country and culture to culture. You'll have to tell us where you are before we can tell you whether any given day is a holiday or not.
Dec 09, 2013 | Funko Pop Rock Public Enemy Chuck D Vinyl...
Cant find the fuel injection relay on 91 Geo storm
the 91 cars , typically have 3 fuses that must be good.
to get fueling.
why do you need to find a non existent relay.?
state the symptoms, and stop guessing.
3 fuses that make the ECU operate
then the ECU drives the inector, directly.
the full schematic is in the FSM and here
alldata dot com.
or in most public libraries, in the e-sources , directory, click Autorepair (free too)
my comment is to a USA person, unstated. that.
Sep 27, 2013 | 1991 Geo Storm
Kitchen Aid Imperial 21 has loud motor noise duing wash cycle
loud motor noises during the wash cycle usually come from a water pump. Either the water pump will stop working soon, or it will keep working for a while longer, and the unit will stop cleaning. Sometimes the pump will stop making the noise for a while before it stops.
Jan 29, 2012 | KitchenAid Dishwashers
I HAVE A 95 CRYSLER CONCORDE, CHECK ENGINE LIGHT CAME ON, WE DIAGNOSED IT IT SAID THE UPSTREAM 02 SENSOR, WE REPLACED THAT, EGR VALVE, FUEL FILTER. THE CHECK ENGINE LIGHT STILL COMES ON, WE DRIVE IT AND...
Check for a restricted CAT, usually it will glow red. A restricted muffler can also create a similar symptom. One way to test, is to disconnect the exhaust forward of the cat and see if it performs the same. Be careful you don't break off bolts. Be carefull you aren't creating a fire hazard.
Jun 16, 2011 | Chrysler Concorde Cars & Trucks
Rough idle and stumble through acceleration. The fuel filter, Pressure regulator, Throttle body and tps have all been replaced as well as a full tune up. The fuel pump runs 90% of the time and other times...
You need to check the fuel pressure to the throttle body. If the fuel pump is nearly worn out, it will display similar symptoms. Did you read out any codes on the computer before starting this repair? Good luck!
Jul 17, 2010 | 1988 Jeep Cherokee
Whats the symptoms for defective water pump in GMC Sierra 1/2 pick up ?
The symptoms would be the car overheating and not cooling down, Also in some cases the water pump will leak. With a overheating problem its always a good idea to check the thermostat before jumping to water pump. Hope this helped =)
Mar 04, 2010 | 2000 GMC Sierra
Replace fuses No power on no standbyby power LED Just nothing
Are you trying to say it's blowing fuses? Stop wasting fuses and risking a fire.
Disconnect the speakers, see what happens. If it keeps blowing fuses it needs a real pro to look at it. Internet doesn't help.
Feb 25, 2010 | Teac AG-V8060 Receiver
How to i stop my Whirlpool Gold from leaking water from the bottom? (Fridge on Top, Freezer on Bottom)
This water is accumulated during the automatic defrost cycle, which occurs every 24-hours. A fan is supposed to pull air over it to evaporate it.
Clean all the dust and lint accumulation from under the unit, remove the condensation collection pan and clean it, and make sure the bottom fan is running.
I can't emphasize strongly enough how much of an enemy the accumulation of dirt and dust under a refrigerator can be its worst enemy. It can make the refrigerator exhibit symptoms of much more serious problems. Sometimes a good cleaning can have it operating like new with no real 'repairs' whatsoever.
Aug 22, 2009 | Whirlpool GB2SHDXTS Stainless Steel
Main Fuel Pump
Fuses mean short somewhere.Fuse is always live it feeds relay but in tank pump [ fuse#4or#6 i forget anyway visa versa ] is not live until this.Relay clicks once when key tuned to on and once more when key turned to crank engine it is under dash by glove box and loud enough for someone with ear at this spot to hear.In tank pump should not be live until engine starts to crank.
Aug 03, 2008 | 1984 Volvo 240 Series
JVC RX-9010V Receiver Logo
1,585 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
stynger007
Level 1 Expert
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
