Question about Tappan 30IN ELEC IGNa Oven
Can I still light an oven even if the electric pilot doesnt work
The plug on my stove/ oven had a short & I'm trying to get power cord. Since Thanksgiving is close @ hand I was curious if you can still light the oven the old fashion way. I've tried it but I don't smell any gas & it won't turn on. I have Kenmore model # 1197478210 pilot free ignition.
  • 24 Answers
Looks like your oven has a "glow" coil. That being the case, you will not be able to light the oven without power. It has to glow to open the valve, and there is no override for this. Sorry.
About the cord, you could install a plug on the cord, or simply replace the cord. (I realize you say you are trying to get one). Other than this, turkey on the grill is always good.
Mr Boo
Posted on Nov 20, 2008
Creda Solarplus (48906) top oven and grill not working
Electric stoves do not have pilot lights or igniters it could be the power control board has failed .
Mar 12, 2016 | Creda Ovens
No power after self cleaning
Nothing Works, or the Oven / Range / Stovetop Works Only At Certain Times:
1.Home breaker flipped or the fuse blown?Possibly an electrical surge has flipped the breaker. Check your breaker or fuse box and replace or reset as necessary.
2.Power cord plugged in?Grab the plug and wiggle to determine a good connection.
3.Power cord damage?Damaged rubber with wires showing through or the wire is being pinched can cause issues. Electrical tape is acceptable for covering damaged wires.
4.Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
6.Even a bad relay door switch will hinder your oven from operating.
If your oven has internal fuses, a wiring or component problem could have caused a fuse to blow. A blown fuse is an indication that a component has shorted or failed, and the problem will need to be corrected. Most ovens that use fuses will have an indication of the circuits that are affected by a particular fuse. If an oven fuse has blown, then you should inspect the oven element and the associated wiring to determine the cause before replacing the fuse.
Dec 14, 2013 | LG LWD3081ST Electric Double Oven
My oven is not lighting and it doesn't even smell like it is getting gas to it. I do not see any pilot light lit but even when I try to light it there is nothing yet the stove works fine. Any idean of what...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
Jun 02, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
SF 3000 EWWO how to light pilot
You can raise the top lid of the stove to light the pilot lights for the top burners.
The oven is controlled by a electric glowbar ignitor.
Make sure the cord is plugged into a electrical outlet.
If it is and the oven does not work the glowbar ignitor must be replaced.
Jan 16, 2010 | Ovens
1937 anitque American Stove came with Magic chef cook book and Loraine thermostatic temperature regulator. Having problems getting Oven pilot light to light. Have checked thoroughly for leaks but have...
Nov 22, 2009 | Ovens
Oven pilot glows when oven is turned on but the burner does not light it plugged? or is it a part
Try to do this
Good luck!!!
Jul 08, 2009 | GE Ovens
Pilot light
It was an electric ignition
Thank you
Nov 11, 2008 | Frigidaire FGB24S5A Gas Single Oven
Burners on gas stove work but oven and broiler not working
Most ovens, unless they have an electric igniter (does it go tick tick tick when plugged in and turned on? If so, it has an electic ignition.) have a pilot light. In order to keep gas from flowing out, and to prevent a possible explosion when the pilot light has gotten put out, they have an electric thermocouple on them that shuts off the gas when it gets cold. Plug the cord back in, and relight your pilot light by holding the lighter (I recommend a fireplace match or bbq lighter, not a cigarette lighter to prevent singed knuckle hairs!) over the thermocouple for a couple of minutes.
Nov 19, 2007 | Maytag CWG3100A Gas Single Oven
Faulty bake or broil element
The solution to this problem depends on whether the oven is electric or gas. Electric oven. If your electric oven's bake or broil element isn't working properly, either it isn't receiving electric power or the element or the oven control may need to be replaced. In many cases, the wiring to the elements can be burnt or broken. 1) Be sure the controls are set on the proper setting. 2) Be sure the stove is plugged in and/or check the circuit breaker or fuse that serves that circuit. 3) Call an appliance repairperson or replace the element yourself as follows. 4) Unplug the oven and let any hot parts cool. 5) Unscrew the mounting screws that secure the element bracket to the oven and pull out the element far enough to access its terminals. Note which wires are attached to each of the terminals, then disconnect the wires (pull off the wire clips or unscrew the wires). 6) Take the element to a parts dealer, along with your oven's model and serial number, and buy a replacement (preferably the manufacturer's suggested replacement part). 7) Reverse the process to reinstall. Gas oven. When a gas oven doesn't get hot, it generally means that it isn't receiving gas, the gas valve isn't distributing gas to the oven burner, or the ignition system -- either an electronic ignition or pilot light -- isn't working properly. A common problem with ovens that have a pilot light is that the pilot light has gone out. NOTE: Gas ranges younger than 10 years old have a sophisticated fault code system that governs their ignition. Always call an approved warranty service provider to handle problems with these ranges. Here's how to troubleshoot your range: 1) Be sure the controls are set on the proper setting. 2) Be sure the stove is plugged in and/or check the circuit breaker or fuse that serves that circuit. 3) Check the gas valve to be sure the gas supply is turned on (also make sure the house's main gas valve is turned on). 4) On a stove with a pilot light, make sure the pilot light is burning. If it isn't, re-light as discussed HERE, or in your owner's manual. 5) Adjust the pilot flame (older stoves only). 6) Turn off the gas and unplug the stove (or turn off its circuit at the electrical panel). 7) Clean out the oven burner ports, using a stiff wire. 8) Plug in the stove (or turn on its circuit) and turn the gas back on. Re-light the pilot (if it has one). 9) If the oven still doesn't work, call an appliance repairperson.
Jan 18, 2006 | Jenn-Air JJW8530C Expressions Collection...
Tappan 30IN ELEC IGNa Oven Logo
115 people viewed this question
Top Tappan Ovens Experts
Dan Webster
Dan Webster
Craig Butler
Craig Butler
Are you a Tappan Oven Expert? Answer questions, earn points and help others
