Question about Philips Magnavox 20MT133S 20" TV
There are red, green, and blue lines running across the screentop
There are some very annoying lines that appeared about four weeks ago running across the top of my screen
  • 121 Answers
Bad feedback electrolytics vertical circuit.
Posted on Dec 02, 2008
I bought an LCD Samsung 3 years ago and about a year ago a thick black line appeared in the middle of the screen. Can this be fixed at home?
check if the lines appear on different inputs or source like hdmi,av,pc, if it happens on a different source then theres a problem with the lcd screen it needs to be fix.
Dec 26, 2014 | Samsung Televison & Video
I have a ln-s3238d that i got a couple years ago. Last month it started getting a line of pixels running across the top of the screen. over the last month that problem has gron to four lines on top and...
Hi andrew, its not a big problem.. Decent TV. but the pixels are DEAD. that means you have to recover them by fixing the LCD. this would cost you around £40-60 for a 32 inch TV. hope this helps!
Nov 05, 2010 | Samsung LN-S3238D 32 in. LCD HDTV
About two months ago my flat panel plasma tv
Most like likely, this is a panel issue and it will be too cost to fix.
Other things you can try, reseating the ribbon cables on the buffer boards located running across either the top or bottom or both. If that doesn't do it, replace those boards and still no luck. Panel is bad.
Feb 16, 2010 | LG DU-42PX12XC 42 in. Plasma HDTV
Shade difference in lg lcd diaplay
Based on your description, it appears that the monitor is faulty. Since it is only a week old, you should have no problem exchanging it.
Aug 22, 2009 | LG L1915S 19" LCD Monitor
Insignia 32" TV Thin line across screen 1-2" from top
This is usually caused by bad capacitors in the vertical circuit. If you have an electronics background you should be able to find the defective ones with an ESR tester .
Dec 16, 2008 | Insignia NS- 27" TV27 TV
Horizontal lines across the top 3 inches of picture
Hi
what line started? from Left to right? or from top to bottom?
Thanks!
Nov 28, 2008 | Philips 32PT6441/37 32" TV
APPROXIMATELY 3" GRAY LINE ACROSS THE TOP OF MY TV
Do you happen to have a cable box? (reset cable box also by unpluging it). is that line also showing on dvd player on different input?
Jul 01, 2008 | Toshiba 50HM67 50" HDTV
Horizontal lines on Screen
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Feb 14, 2008 | Gateway FPD2275W LCD Monitor
Samsung TV Model HL-R5067W
go here they are adjusting speed of the color wheel
Feb 12, 2008 | Samsung HLR5067WX 50" Rear Projection HDTV
Vertical lines across the screen
Change ballast and lamp at same time. Ballast #75006507 lamp #23311153
Sep 11, 2007 | Toshiba 46HM95 46" HDTV
Philips Magnavox 20MT133S 20" TV Logo
119 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
