Question about Canon ZR200 Mini DV Digital Camcorder
Wont accept DV tape..
I tried rewinding a tape to view playback. and prompt "eject tape" appeared. i ejected the tape and when i tried to re-insert it would humm and then let out 2 beeps and then do nothing. i have tried various tapes and all act the same. otherwise the camera operates as usual it just tells me there is no tape!
  • ricky svitek Dec 15, 2006
    please help! it is my girlfriends camera and i would be in big trouble!
Try removing the battery and the ac adapter for about five minutes or more. The camcorder may be "locked up" and may need to be "rebooted". It worked for me.
Posted on May 29, 2007
I have the same problem, but i did nothing wrong to prompt this problem at all. It was sitting on my desk, it worked, then it didn't. go here.... http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=227&modelid=11004&keycode=2112&id=14483
Posted on Apr 03, 2007
WHEN INSERT THE VHS TAPE TO VCR IT EJECTS BACK... WHAT MAY BE THE PROBLEM?
Hi, depending on the age, chances r that some components r worn out or the eye sensor needs cleaning or sdjusting.....
Jun 21, 2014 | Panasonic Televison & Video
VHS tape is running at high speed when insert it to VCR. no playback..buttons doesnot work.
Check if the fast forward button is more inside than the rest of the buttons. May be its stuck in the ff position. After all they were just micro switches below the plastic buttons strip. The specific ff micro switch may be stuck, if I were you I would try some switch cleaning spray to loosen it. But be prepared that the control ic is busted.
Tape will not eject / Battery full
while the eject process is trying to happen remove the battery and replace it. keep initiating the eject process and removing the battery and it should finally eject. If you attempt to use the camera again put in a new tape so you don't lose a tape that contains footage you may want to save.
Dec 07, 2008 | Canon ZR100 Mini DV Digital Camcorder
Eject error R
Use different tape. Is the tape still attached to the feed spool, or has it become separated ?
Jul 11, 2017 | Samsung VP-D361 Mini DV Digital Camcorder
Eject tape message
We get the eject message and then it will not eject tape.  Any suggestions
Mar 04, 2008 | Canon GL1 Mini DV Digital Camcorder
JVC-GR-D371U
Dirty video head! Playback newly opened blank tape for five minutes, after that eject, reinsert, playback then eject again five times, these will serve as your video head cleaner, never use "video head cleaning cassette tape" for it will only damage your camera. Most camera has built in video head cleaner installed inside and activates only when you insert, initial play/rec, and ejects a tape. If the problem is still there you need pro fix then.[:0)
Sep 25, 2007 | JVC GR-D370 Mini DV Digital Camcorder
Canon Gl2
Sep 18, 2007 | Canon GL2 Mini DV Digital Camcorder
Cleaning the camera
hi, just insert a brand new dv tape and let it record for 10 min.. rewind back to 5 min and start playing and do a repeated ff and rw you can see the black lines slowly going off.. all the best my friend sreejith
Jul 08, 2007 | JVC Cybercam GR-DVP7 Mini DV Digital...
Playback & Ejection Problem
Hi, You usually get an EJECT TAPE when the camcorder has found an internal problem and either the videocassette or the camera itself has developed a problem. In you case, it looks like you tape has a problem. Daniel
Sep 04, 2005 | Canon ZR25MC Mini DV Digital Camcorder
Canon ZR200 Mini DV Digital Camcorder Logo
291 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
