Question about HP PSC 1610 All-In-One InkJet Printer
The glass from the printer hp psc 1610 all in one is broken
I need to be able to remove the glass from the printer te replace it with another one but I do not want to force it open. I some one knows how to remove the cover with out braking it. The glas is gone but the printer funtion ok.
  • 962 Answers
There are 4 hex head screws on the top of the printer casing. remove these and you will remove the entire top casing. the glass is underneath.
Posted on Nov 22, 2008
Wide black vertical bands on copies
Remove scanner glass, refix CCD cable & try. If problem persists replace CCD ribbon cable..
CCD snap shot:
Jan 28, 2013 | HP PSC 1610 All-In-One InkJet Printer
Psc 1610 all in one scans with black lines down the middle
Open flat bed, remove scan camera, clean internal reflector glasses with ear buds to clean dust on it, as well as clean flat bed glass with galss cleaner both sides fix it back, check copy & scan...
Feb 01, 2012 | HP PSC 1610 All-In-One InkJet Printer
How do I use the scanner on my HP PSC 1610 printer
open the scanner place the document face down on the glass, go to the control panel on the printer and press scan , this one method, the other is open the click on start menu, move up to accessories, after that move to scanner etc, and you are done
Apr 15, 2010 | HP PSC 1610 All-In-One InkJet Printer
HP PSC 1610 cartridge alignment failure. now what?
after alignment process it asks to put the alignment sheet on the scanner glass .. are you putting it rite way ??? try putting it other way round.. it should be facing down also
Oct 20, 2009 | HP PSC 1610 All-In-One InkJet Printer
My psc 1610 scanner function is not working, the output was totally in black while scanning a document
My HP Psc 1610 all in one can print & copy but can't scan. I already installed the driver for Windows 7
Jul 09, 2009 | HP PSC 1610 All-In-One InkJet Printer
Broken glass in an HP scan, copy, fax machine.
Take it into a glass shop and have them cut you a new piece, this is usually cheaper then acquiring a factory part.
Hope this helps.
Ed
Apr 30, 2009 | HP PSC 1610 All-In-One InkJet Printer
How do you take the scanner glass out of the Hp psc 1610?
How to remove the glass panel from the PSC-1610:
  1. Pop the button template piece off.
  2. Use a Torx T-10 driver to remove the screw at the bottom of the button piece.
  3. Lift the button piece away and let it hang by the cable bundle.
  4. Remove all 7 T-10 screws.
  5. On the back, gently pop the 3 plastic tab holds.
  6. The glass panel should lift off.
Mar 18, 2009 | HP PSC 1610 All-In-One InkJet Printer
Need help with HP PSC 1610
You need a USB printer cable. You can get that at any computer store
Sep 25, 2008 | HP PSC 1610 All-In-One InkJet Printer
HP PSC 1610 - multiple lines in scans and copies, prints OK
Try a sky scan (No paper on glass and lid up) watch the scanner to see if it is smooth or a somepoint jumpy. If not smooth, you will have to open it up and 1 of two things, dirty and needs lubracation, silicone grease is best vasoline will work. OR 2 the drive belt is loose because the spring tensioner is broken or the belt is dammaged. Good luck
Aug 28, 2007 | HP PSC 1610 All-In-One InkJet Printer
HP PSC 1610 All-In-One InkJet Printer Logo
46 people viewed this question
Seeker5211
Seeker5211
