Question about Coldtech CFD1R Stainless Steel Refrigerator
Fridge temp is high, there'a a clicking
We have a Coldtech refrigerator in our concession trailer. The temp is high. When we plug it in, it clicks off and on like the compressor is trying to come on, Any ideas or suggestions? It's not even a year old. Today is Wednesday and we need it to be operational by Thurs. night. No one can get here before Friday and that just won't work. Please help. Thanks!
Doug's Cowgirl
  • 24 Answers
If the sound you are hearing is a noise like the old clickers we used to hold in our hands, it is probably the overload. If so, doubt you might get it fixed by Friday. The sound is probably the Klixon overload and it "clicks" to open the circuit because too much current is being drawn. Reasons for this:
1) Compressor is locked and is pulling LRA locked rotor current.
2) Starting mechanism is not operating correctly. (better this than locked pump)
Starting relay is probably solid state and changing this may fix the problem. But, further testing is going to be necessary.
Sorry, but it is not going to be something you can easily do.
If the clicking is something different, like the defrost timer. Easy fix.
However, I am afraid you have something more serious. Warranty should handle any of this. Compressor should have a 5 yr. warranty. But that does not help getting it going right away.
Posted on Nov 20, 2008
I have a kitchenaid Superb refrigerator KSCS25INSS01 and the temps are warmer than normal.
I have a similar problem, I have the same model number, mine is too cold in the the refrigerator but has the same " whirring/click noise" .I have removed the back cover and observed the condenser fan motor cycling on and off in 10 second or so intervals. the compressor is not trying to start so my guess is the control board is bad. I was hoping you have solved your problem before I buy a $250.00 part or a new "Frig" this one is 8 years old.
Lil help?
Nov 05, 2012 | KitchenAid KSRS25IL Side by Side...
Trailer is plugged in and refrigerator is on auto. Refrigerator works. But when you unplug the trailer the gas side will not light. And when the trailer is plugged in and the refrigerator is set to gas,...
In order for your fridge to work when your trailer is not pluged in you need a 12 volt power source, You might have a bad battery or your positive or negative cables are not connected properly. Or a bad connection in the back of the fridge. Check the fuse?
Sep 29, 2010 | Dometic RM2652 Refrigerator
GE Profile Arctica ice dispenser switch quits working
I came across this problem recently , and found the main control board was bad . Check this site first , to see if it can be covered under warranty .
http://www.scribd.com/doc/13371507/Ge-Motherboard-Concession-Letter
It was covered under warranty , at the previous customers residence .
Nov 20, 2009 | GE Profile¿ Arctica® Energy...
Freezer not cooling, fan blowing, fridge also not
If there is no frost , on the inside rear freezer wall ,
http://www.scribd.com/doc/13371507/Ge-Motherboard-Concession-Letter .
If there is frost , reply back with complete model number .
Nov 08, 2009 | GE PSS25MGN Side by Side Refrigerator
Clicking sound and warm temps
Sounds like the compressor is frozen and won;t turn. a slight chance that it starter relay is bad, you will need to get a repairman to check it out.
Jul 26, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
GE fridge has loud clicking noise; model freezer on bottom.
The problem is the main control board on back of refrig . Relay bad and clicking . Have to replace the complete board .
Jul 23, 2009 | GE GBS18KBM Bottom Freezer Refrigerator
Just bought a 1999 camer and we cant get fridge to turn on
If you like I will help you repair your Dometic Model Number RM2852 or click on HERE=> ALL THE ANSWERS FOR DOMETIC CAN BE FOUND BY CLICKING HERE
Thanks, Sea Breeze
Jul 11, 2009 | Dometic RM2852 Refrigerator
Bottom freezer temperature rises as high as 35 degrees and drops only to a low of 15 degrees continually. ongoing for a month now. french doors fridge now has temp. fluxes within this past week. temp. goes...
check the defrost thermostat , and any temp sensor that can determine the freezer temperature.
If this fridge temperature is electronically controlled, the freezer control board must also be tested.
Click here to get all parts and diagrams for this fridge.
Regards.
Jul 09, 2009 | GE Profile PFS22MBW French Door...
Coldtech CFD1R Stainless Steel Refrigerator Logo
129 people viewed this question
Top Coldtech Refrigerators Experts
billconfused
Randy Justice
ray gallant
Are you a Coldtech Refrigerator Expert? Answer questions, earn points and help others
