Question about IBM ThinkPad T41 Notebook
Battery not recharging.
I have a IBM T41 thinkpad. The battery is not staying charged. I believe I have a bad AC adapter b/c when I borrow a friend's adapter, it works fine. Am I assuming correctly that I need a new adapter?
Thanks
  • IBM Master
  • 4,338 Answers
If your unit works with your friend's adapter , then it is your AC adapter. You can do a Google search and find it on the web. Also Targus makes a good universal kit that will work.
Hope this helps, If it does, please rate it.
If I could be of further assistance, let me know.
Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Nov 20, 2008
Look on the charger itself & it will have the correct output voltage & polarity stamped on the charger. Then get a volt meter to verify if the correct output voltage is present. If the volt meter reads less than what is stamped on the charger, then I would recommend replacing the charger at that point.
My ibm thinkpad t41 not charging,bought a universal charger for it by battery light not coming on wen plugged to laptop
Seems the laptop connector has been disturbed, pull, tugged on. A connection most likely is loose in the machine(motherboard) or could be a defect in
manufacturing. If new return it or ask the manufacturer for a repair/replace.
They will most likely suspect customer damage.
http://www.chargerbuy.com/replacement-ibm-thinkpad-t41-ac-adapter-16v-4-5a.html
Oct 28, 2012 | Computers & Internet
I reinstalled XP on IBM T41, now battery won't charge. Could this be Driver Problem
Sounds like you need a new battery.
It's not just a battery in a case, it also has a small circuit board inside to control the charging etc, if that's faulty it won't charge, or if it has dead cells in it won't charge.
Feb 08, 2012 | IBM ThinkPad T41 Notebook
My i b m will not turn on with ac but will work with battery
possible problems: charge port has been damaged or it simply wont work (common ibm problems)...
Solution: go to the local repair shop to repair or change the ac port.
good luck!
Mar 23, 2010 | IBM ThinkPad T41 Notebook
IBM Thinkpad won't work with adapter and won't recharge battery
Well he shorted out the regulator inside that tells the unit the battery needs to be recharged in witch transfers it to AC current, on this unit the rugulator is implemented in the motherboard and that wold not be practical ether to replace unless you find one for parts on www.ebay.com for cheap and do it yourself that would be the only way that would cost you less money- thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Apr 30, 2009 | IBM ThinkPad R51 Notebook
My ibm laptop contionusly beeps and says power scource is battery,when i press esc, it boots normally and shuts down in about 15 mins to half an hour
Either:
A. Bad battery
Or
B Bad power supply.
Sounds like the battery isnt charging correctly , the beeping is warning you it is running out of power.
Take the battery out , and boot normally with the ac adapter.
Does it work?
If yes, Get new battery. about 70-90 dollars.
If no. Get new ac adapter. 20-40 dollars.
links to parts
http://www.nextag.com/ibm-a21m-battery/search-html
http://www.nextag.com/serv/main/buyer/OutPDir.jsp?search=ibm+a21m+ac+adapter&x=0&y=0
http://www.laptopuniverse.com/product/02K6496-Laptop-Notebook-Power-Supply-AC-Adapter-For-IBM-Lenovo-Thinkpad-A21M-16V-60W-Part-02K6496/LU/36124/productDetails.html
Mar 03, 2009 | IBM ThinkPad A21m 2628 Notebook
IBM ThinkPad T41 (9 Cell Battery)
It can over charge it.
it happens alot with laptops.
Feb 04, 2009 | IBM ThinkPad T41 Notebook
Ibm thinkpad no power with ac power adapter but works with battery
If prior to this it works intermittently with the AC adapter, it means the connection from the adapter power unit to the motherboard was lost and this is a typical problem with the Thinkpad. It needs a re-soldering job and not something that one can do without a proper repair manual on how to open the laptop. Try googling your problem and find out if someone has the same experience and managed to resolder by him/herself.
Oct 18, 2008 | IBM ThinkPad T41 Notebook
IBM Thinkpad T22 Battery
pls first check your adapter may be problem with your adapter.
thank you
Sep 28, 2008 | IBM ThinkPad T22 2647 Notebook
IBM Thinkpad doesn't start
Visit Lenova's troubleshooting page at
http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-4YQJZX
I assume you have verified the battery and AC adapter with another machine or a voltmeter.
If none of the above get it going, you most likely have motherboard issues, possibly a blown fuse.
Or possibly a keyboard Power On switch problem.
Good luck.
Apr 28, 2008 | IBM ThinkPad T41 Notebook
IBM Thinkpad T30 no power
I agree with you and have a link for adapters http://www.google.com/products?q=IBM+ThinkPad+T30+2366+adapter&hl=en&rls=com.microsoft:en-us&um=1&sa=X&oi=froogle&ct=title
Aug 02, 2007 | IBM ThinkPad T30 2366 Notebook
IBM ThinkPad T41 Notebook Logo
111 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
