Question about Alpine CDA-9851 CD Player
Cd player won't open
I have a alpine cda-9851 that won't open to accept cd's. also, the tilt option cannot be selected in menu. just makes a beeping noise and displays the words "open" but won't do it.
  • 1 more comment
  • tyler2686 Nov 23, 2008
    has tilt option in menu but will not allow you to open so you can insert cd
  • xr6stylin Dec 03, 2008
    Displays OPEN but won't open or eject CD...
    Tried resetting but that did nothing.
  • glennbonds May 01, 2009
    same problem here. push button, screen says open but does not open. It wiggles a little then stops.
Let the radio cool down its to tight installed
Posted on Jan 06, 2009
Try disconnecting the car battery for a few minutes, the unit may reset when you re-connect the battery. Worth a try.
Posted on Nov 21, 2008
I need to know how to adjust the clock on a alpine cda 9851 car reciever
Press the menu button until you see SETUP and the clock should appear. To adjust just turn the knob.
Mar 20, 2010 | Alpine CDA-9851 CD Player
I got a Alpine cda-9851 cd player today. I popped the face plate off to see where the cd goes in, but theres not a slot for it! Do i have to have a 6 disk changer for it?
this is a motorized deck. just press the eject button and it should open. the eject button should be on the lower right hand corner of the face.
Dec 10, 2009 | Alpine CDA-9851 CD Player
How do you make the aux work
its going to be in the menue , it has to be "turned on" like the sub out put on those older alpine cda 7949's..... have the owners manual?
Nov 23, 2009 | Alpine CDA-9851 CD Player
My cda-9851 wont open to accept cd's and all it says when i press the open button is open and nothing happens but everything else works i just have to listen to the same cd all the time
i had the same problem couple of years ago take it to northfield or your local dealer cost 120 or you can force it open by pulling hard on it when u press the open button
Jul 16, 2009 | Alpine CDA-9851 CD Player
Alpine CDA-9851 CD player
i/c on or off. set it too off
Jun 28, 2009 | Alpine CDA-9851 CD Player
Won't open
120 to get it fixed or you can pull on it after you press open HARD
Aug 30, 2008 | Alpine CDA-9851 CD Player
How Can I change Time In my CD Player
Go into settings in from the menu button. using the fowrad and backward keys find the clock setting. The hours should be blinking on the clock. change using the scroll and press the scroll to change to minures. just press menu to return to the menu then go to return. Problem solved.
Nov 28, 2007 | Alpine CDA-9851 CD Player
How to install an alpine cda 9851
you go to a stereo shop..(walmart autozone etc should also do) buy a mounting kit and a wire harness adapter. The wire colors on the adapter match the wire colors of most aftermarket decks. MAtch the wire colors and connect...make sure to tape wires well as if they touch you rick damage to your deck.. install the mount kit plug in your cd player and slide it in and you are good to go..
Aug 21, 2007 | Alpine CDA-9851 CD Player
Alpine CDA-9851 CD Player Logo
211 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
