Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
While cleaning the print nozzles on my Epson R220 photo printer I received a message stating parts inside your printer are at the end of their service life
SOURCE: service life has ended on my epson stylus r320 photo printer
I have had a R300M for a while now and had a few cartridges in it. (Mostly Compatible Cartridges not OEM) Recently a message came up on the screen 'parts inside your printer are at the end of their life' and the printer refused to work!
After searching the web it appears to be a waste ink counter, but I could not find any info on resetting it.
Tried pressing different combinations of buttons on the printer and success. (Found Ink counter reset)
Press and hold 'stop' 'maintenance'(ink button) and 'power' buttons for about 10 seconds,(while printer is on) a message will come up on the screen saying counter is reset and to turn off.
Thats it, turned my printer back on, and all works fine again.
I hope this helps R300/R300M owners out!
(Also I have email into Epson Support, can't wait to hear what they say the problem is for the fix!)
Good Luck,
Steve H.  :-)
Posted on Jan 06, 2008
SOURCE: EPSON PRINTER R22O
display This massages Parts inside your printer are near the end of their service life.
See your printer documentation.
Posted on Apr 28, 2008
SOURCE: Epson Sylus Photo RX600
press the on, stop, color & b&w buttons at same time and hold them down for awhile......seams to reset everything....good luck
Posted on Sep 15, 2008
Inky
  • 691 Answers
SOURCE: Epson Stylus Photo R220 InkJet Problem
The erroris an ink overflow protection error and is fairly easy to rectify. Youneed to clean the waste ink pads in the bottom of the printer and thenuse some software to reset the internal counter. You can download allthis stuff from the link below:
http://www.tradebit.com/filedetail.php/834175-epson-stylus-photo-r200-r210-rescue-and
A waste ink tank, does not stop the ink counter incrementing each timeink is used. All it will save you is the time taken to replacethe ink pads - which you can wash out and reuse anyway.
Posted on Nov 10, 2008
  • 5269 Answers
SOURCE: Epson RX700 printer, end of service life message
This usually means that the waste ink absorbers are full. If your printer is under warranty, you can get them dealt with and the counter reset at an Epson Customer Care center. If your printer is out of warranty, you should consider if it is worth the fix. You can get this done by Epson or an independent printer repair person. (They might sell the parts for a dyi job.)
Once that is done, you can get a reset utility from the following URL: http://www.epson.com/cgi-bin/Store/support/InkPadsForm.jsp . If you execute the reset without the pad replacement, you will get ink smearing on your documents after a while.
I hope this helps.
Posted on Jan 29, 2010
I have feint lines across photos and have done head clean. Epson Stylus photo R220.
Well, here's your problem: that's a six year-old printer. I used to have it and and 2007 I replaced it with an Epson Stylus Photo RX595 AIO because like the R220, the RX595 has the ability to print directly onto inkjet printable CD's/DVD's. Your printheads/nozzles are shot and all the cleaning in the world will not fix them and it's certainly won't be cost effective to have repaired when you can get a current model for less than the repair price. Mine went after two years. Honestly, it's amazing that this printer lasted as long as it has. Six years has to be some kind of record.
Here are the current CD/DVD printing models from Epson.
http://www.epson.com/cgi-bin/Store/CDLanding.jsp
Apr 28, 2011 | Epson Stylus Photo R220 InkJet Printer
My printer is leaving horizontal streaks across
When I had the same problem, I found out, that Epson did not like Generic Ink. As soon as I replaced it with Genuine Epson Ink, it was fine.
Make sure you do Maintenance, Nozzle Check and Head Cleaning. You might be clogged?
Good Luck.
Nov 05, 2009 | Epson Stylus Photo R220 InkJet Printer
My epson r220 printer is printing yellow horizontal lines across the paper why!!!
it maybe because your printers nozzle might be dirty. try to perform some cleaning cycles about 3 would be more effective......
Sep 10, 2009 | Epson Stylus Photo R220 InkJet Printer
Epson r220 prints black lines through photos ect anything I print
The problem caused by waste ink at bottom plate arround head sprayer. Clean it. Turn off printer. Move head to center. Put wet tissue (with warm/hot water) upper head cleaning pad. Move head to right (parking position). wait for 10 minutes. Repeat it for 2-3 times. Check nozzle.
May 30, 2009 | Epson Stylus Photo R220 InkJet Printer
Epson R220
Hi
You need to clean the printheads or the nozzle check.
If you go to the printer properties you will see the options to do this.
Sophia
Jan 06, 2009 | Epson Stylus Photo R220 InkJet Printer
Epsom R220 printing wrong colours
Print a nozzle check pattern then clean the heads until nozzle check pattern returns to normal. If you are using cheap **** compatible inks, throw them out and get some genuine stuff to run in the cleaning routine. Cheap **** compatible ink makes the situation worse when cleaning.
Nov 08, 2008 | Epson Stylus Photo R220 InkJet Printer
Epson stylus c62 plenty of ink; prints too light
Hi-
Have you tried cleaning the nozzles? press the ink button for 3 seconds or do a clean print head from printer utility.
Hope this helps
Nov 04, 2008 | Epson Stylus Photo R220 InkJet Printer
this sounds like ur both cartridges are empty...
Jul 28, 2008 | Epson Stylus 880 InkJet Color Printer
Printer Cannot print pictures uniformly
Your printer a thourough head cleaning it will cost a lot of ink, some part of the head are dried or clug, after head cleaning check nozzle again.
Dec 18, 2007 | Epson Stylus Photo R220 InkJet Printer
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
13 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
