Question about Crosley CDE6000 Electric Dryer
Dryer shuts off and won't restart until it cools off
I have a Crosley model CDE22B6VC electric dryer. It will run for about 10 to 15 minutes then shut off. Once the dryer has cooled down it can be restarted but then it will run only for another 10 to 15 minutes. I recently cleaned all the duct work and exhaust from the front of the dryer thought the outside vent and there is plenty of air flow through the exhaust so I know it is not blocked. Could the high limit thermostat or the thermostat control be the problem?
    Genius:
  • 1,028 Answers
More likely a bad motor ..excessive lint build up in dryer will reduce air flow through motor causing it to overheat problem is by the time the lint problem is found and corrected motor is already gone
Posted on Nov 20, 2008
It will run good for a while on hot heat and then shuts off for abut 5 mins but it doent shut off on cold cyc
why does my roper electric dryer shut off after five or ten minutes of running fine. then wait five or ten minutes, restart and it runs fine for another five or ten minutes, and so on....
Dec 29, 2012 | Roper REX4634KQ Electric Dryer
Speed Queen Heavy duty Dryer appears to shut down because of over heating. We have had this dryer for quite awhile and the kids are all gone now so we actually don't use it as much. It doesn't...
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Aug 14, 2011 | Speed Queen AES28AWF Electric Dryer
My Whirlpool Dryer Model #LER5636KQ0 stops running after about 5 minutes. I have checked the lint screen and lines all the way out of the house, there is no lint build up. I even let it run without the...
If you are absolutely sure that the vent is perfectly clear, then the device that shuts off unit due to overheating is going off prematurely. Go to attached site for part involved and get a new one. Search Over 2 1 Million Appliance Parts
Aug 27, 2017 | Whirlpool LER5636P Electric Dryer
CHANGE ELEMENT IN CDE22B6VC ELECTRIC DRYER
http://www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
Dec 23, 2010 | Crosley Dryers
Dryer gets hot and shuts off after five minutes,
Check your vent tube to make sure it is clear. It is probably getting to hot because there is no ventilation to the outside. When you have the front off, check all the way from the lint filter to the outsid of the house.
Mar 23, 2009 | Frigidaire FEQ332E Electric Dryer
Kenmore Dryer model #66912690 The dryer stops
replace motor drive,,,defective motor...onthejob
Feb 08, 2009 | Kenmore 62602 Electric Dryer
Whirlpool LER8620 electric dryer, shuts off at random. When it
Whirlpool Dryer Won Start
Sounds to me like a thermal fuse. The link gives you multiple scenarios and you can even order replacement parts. I have used it myself with success on washers and dryers. Good luck!
Sep 13, 2017 | Whirlpool LER7646E Dryer
Dryer shuts off
motor overheating ..doesit "groan" when start button pressed ? If so bad motor ..possible excess lint due to poor exhaust system caused lint build up around motor causing overheating and motor damage .new motor only fix
May 02, 2008 | Kenmore 62602 Electric Dryer
Crosley CDE6000 Electric Dryer Logo
228 people viewed this question
Top Crosley Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
charles
Are you a Crosley Dryer Expert? Answer questions, earn points and help others
