Question about HP Photosmart 2410 All-In-One InkJet Printer
Cartiage has error and it keeps hanging up.
I turn it on and the cartiage makes a funny sound and then it keeps on running and then it won't print for me at all.i tryied to unplug it and then waiting for 30 seconds but nothing happens with it,so please tell me what to do with it now.
  • 781 Answers
Try the troubleshooting suggested here:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=buu02180&lc=en&dlc=en&cc=us&rule=8331&product=303753
post back with your findings
Posted on Dec 10, 2008
Why is my printer making a funny noise when I hit the print button?
that sound come while printing that sound is formed while cartridge or ink
if you want to clear that sound you should keep some oil to move free edges or you can clean
Feb 09, 2015 | Office Equipment & Supplies
2008 Nissan Quest Reverse Park aid stoped working. First sound got funny and then quit. The switch disable light stays on and won't turn back on
replace the beeper that makes the sound when you are in reverse.the light will also go out after you replace thet beeper.
Sep 16, 2012 | 2008 Nissan Quest
How to avoid the worse cartidges
Check printer cartridge compatibility before unpacking a new print cartridge. Make sure that it is compatible with your printer.
If it is not compatible then it can give error ...........
If you need any kind of technical assistance on printer support then call at-http://www.vtechsquad.com
Aug 30, 2012 | Canon MP270 All-In-One InkJet Printer
Printer
The steps below should help you override the error and make the printer accept the cartridges and allow you to print.
Instructions
    • 1
      Remove and replace the print cartridge. If that doesn't solve the error, move on to Step 2.
    • 2
      Remove the print cartridge from the machine.
      • 3
        Wet the end of a cotton swab with rubbing alcohol.
      • 4
        Wipe the copper colored contacts on the print cartridge with the cotton swab to clean.
      • 5
        Wipe the contacts in the printer where the cartridge sits.
      • 6
        Replace the cartridge and try a test print. If removing residue for a clean connection didn't solve the error, move on to step 7.
      • 7
        Turn off the printer.
      • 8
        Unplug the printer from the power source and leave it unplugged for 15 to 30 minutes. This will reset the printer.
      • 9
        Plug the printer back into the power source and turn it on.
      • 10
        Print a test page.
    Regards,
    Suhail
    May 20, 2012 | Lexmark X1240 All-In-One InkJet Printer
    My printer is low on Magenta ink, so it won't print... even with black and white documents.
    The Nx300 printer needs to have all the colosr and the black with ink in them so that they will print. For the printer will not print unless there is ink in all the cartiages
    Aug 23, 2011 | Epson Stylus NX300 All-In-One InkJet...
    HP Color Laserjet 2605:new magenta cartiage, however the print looks orange not red. Any suggestion? I also ran the clean cartiage utility on the printer with no success.
    Hello sir;As you discript seem like no cyan( blue), why don't make a color chart print out, it will tell you what color missing.
    Apr 22, 2009 | Office Equipment & Supplies
    In pop up window it tells me colour cartridge error remove and check which i have done to no avail. also on comp screen tells me cart error. Have tried to press set up nothing happens. Also have a red...
    Make sure the cartiages are sitting tightly in the printer and isn't loose. There are contacts on the cartiages and if the contacts aren't touching the ones properly in the printer it will show that cartiages aren't there.
    Aug 21, 2008 | HP Office Equipment & Supplies
    Replaced the black ink cartridge and it comes up no printer cartridge.
    As suggested a couple of minutes ago, with a fresh cartridge installed, disconnect power (unplug) and let the unit rest for an hour or so and then reconnect it.
    This may clear an internal error register.
    Apr 21, 2008 | Lexmark X1270 All-In-One InkJet Printer
    Sharp al1217
    I've never seen this model in Australia but could you confirm if its drum or toner either way its just the machine letting you know that it needs changing soon, however we have other models that do the same and run for quite a while before the quality drops off
    Mar 18, 2008 | Sharp AL-1217 Copier
    Paper jam
    i have an hp office jet 5510 and its not print and it keep on saying cartiage is jam , the timeing is all mess up the leg that bring the paper out keep on coming up whilethe cartiage is going across is there a way of reset the print to get back the timeing
    Nov 01, 2007 | HP Officejet 5510 All-In-One Thermal...
    HP Photosmart 2410 All-In-One InkJet Printer Logo
    Seeker5211
    Seeker5211
