A Sharp Note vision XR-41X DLP Projector. A few Bars blinks.
Conected to a Lab To Computer at the end of the presentation showing a Video from Real Player, after it end and ready for the next one, it start to blink filling the screen with verticars bars in a patern of black and white. All buttons got desable except the on/off button. it was a refurbished unit purchased through Ebay, only 90 days waranty witch already expired and they don,t show service center at Puerto Rico.
Does it look like a big and expensive problem or could be afordable.
Where to send for repair, etc?
  • 7 more comments
  • arcelinm Nov 21, 2008
    Ginko solution is not clear. Power cable or computer to projector cable. Projectors button are desable and there is no screen image other than black & white bars. How can I change input/output setting? Does my problem looks like a user or technical problem?
    My Sharp DLP XR-41X projector conected to a Lab Top Computer while presinting a real player movie, after it finished, began to blink showing paralel vertical black & white bars. All buttons except the on/off switch does nothing when I depress them. Unit is refurbished and waranty expired. I live in Puerto Rico and as I know there are no service center locally. I want to know first what the problem most likelly seem to be,if the repair cost worth the investment, and where I can send for repair. I have some knowledge in electronics so that minor repir i could make it so that if some of the guru upther give me some hint I could probably save it. I am a computer oriented person.
    I need more detailed solution and recommendations like: Buy a new one better, it could cost around $ plus shipping back and forth, I can fix it or for X amount I take your and send a good one, etc.
    Thanks
    No one has answer my questions. I am looking for expert advise no for funny answer that lead to nothing. Obviouslly all cable change, source change as a DVD movie from a DVD prayer etc, I have done.
    Pankag Solution was tested long time before I got into thie site problems solving alternative and didn't work.
    Could I hear from some one eslse with reasonable coments and some kind of detail that open my eyes and tell me the true in term of if it is or not worth to continue with this odisy.
    thanks,
    I am looking for response that makes sences and give some kind of detail. Every time that I receive a response is the same response from Pankaj_dic. I don't like to continue receiving the same message again "change the computer cable" because I did that already and don't work.
  • arcelinm Nov 24, 2008
    Could some expert tell me what cause the problem and how to avoid it in the future? Does it a common problem with those projector?
    My problem is not still solved.
    Thanks
  • arcelinm Nov 25, 2008
    I had have some progress but no sure when it happened, but now, the lamp is not blinking any longer but image is not coming out,just the screen is filled with some paraler 2 inches bars down forming like a 36 inches rulers, however by pluging a video player and using the remote control, I could change the source input and I can hear the audio from both from, the projector speaker and from the projector audio ouput to an external amplifier. I also conected my desk top cumputer the projector and a cable from the projector to my computer monitor, and the computer image is perfectly transferred to the monitor.
    Looks to me that is a matter of a total reset, but how to do it. Could some one tell me exactly if there is a hidden button or a matter of holding down a couple of buttons in the control or what. The solution might be close. That what expert are for.
  • 4,234 Answers
The problem here is internal to the projector and is sensitive to heat. This is not completely uncommon. Even the larger more expensive projectors are subject to this type of failure occassionally. This problem is not likely to be resolved without sending the unit to a servicer. There are no servicable parts inside that a user can change that will resolve this easily or cheaply. There are too many possible ways to create more problems that you currently have. I work with these types of systems every day and I'm sorry to have to tell you this, but you should send this in for service. Make a few calls, you shoud be able to resolve this problem for less than the replacement cost.
I'll make a few inquiries to see if I can find a servicer close by.
Dan
Posted on Nov 25, 2008
  • 4,806 Answers
You can rent projectors from Projector123.com anywhere in the U.S or Canada, including Alaska, Hawaii, and Puerto Rico. Just place your order online using our secure server or give them a call at A Sharp Note vision XR-41X DLP Projector. A few Ba - cb_transparent_l.gifA Sharp Note vision XR-41X DLP Projector. A few Ba - space.gif"http://i.fixya.net/uploads/images/spaA Sharp Note vision XR-41X DLP Projector. A few Ba - space.giflt="space.gif" class="h_mi" />arrow.gifspace.gifspace.gifspace.gifspace.gifspace.gifspace.gif888-866-6123cb_transparent_r.gif. this may be easier for you because your not looking at any repair costs (makes sence)
Me being a PC technician, i am suspect of the computers graphics settings to
hope this helps
regards
Posted on Nov 21, 2008
  • Lee Hodgson
    Lee Hodgson Nov 27, 2008
    I'm going to guess you don't see the comb
    artifacts on the computer, that other sources look ok via composite
    cable, and that your AVI files are 23.976 or 25 fps.
    To send these over a composite cable the video has to be telecined
    to 59.94 fields per second. To be displayed by the projector these
    fields are being recombined back into frames. Sometimes the projector
    is combining fields from two different frames -- so you see comb
    artifacts when there is motion. I don't know how you might get around
    this since it appears to be a problem in the projector.
    I think that projector has a VGA input -- have you tried using
    that? That would avoid the whole telecine, inverse telecine issue.
    Brigadier General:
  • 6,966 Answers
Initially, try a reset, unplug from the mains for an extended period. In some models, there is a small reset button recessed in pin hole. If neither works, then the unit has to be opened up. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings should you be considering in performing a DIY (do-it-yourself). If this would be impractical and time is constrained, then purchase of a replacement would be logical. Perhaps you could limit your choices to branded projectors represented in Puerto Rico.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
  • Louie  Role
    Louie Role Nov 25, 2008
    Appreciate the update on the developments so far.
    Much as we hope that there would be an easy fix, unfortunately if no visible reset button, then the choices left would be:
    • DIY;
    • send it in for repairs;
    • purchase of a new unit.
    However, with the above in mind, then it would not matter if you try any combination of buttons while powering up to simulate a reset.
    Genius:
  • 1,252 Answers
CHANGE THE CABLE THAT CONNECTS LAPTOP TO PROJECTOR THEN CHECK
  • 734 Answers
There is sum fault on main control display chip of multimedia projector its need repairing. THANKS
  • futureloginn
    futureloginn Nov 21, 2008
    it costs like aprox. 20 USD
    Genius:
  • 1,550 Answers
This tends to be fault with the board inside projector .
There is some sort of short circuit inside the projector . The cost cant be estimated unless you take to service people . Since it is refurbished one the one or more parts can be damaged.
  • SAM ANDERSON Nov 21, 2008
    • Cable Connection Issue between the Engine/DMD and the Main ECA where the TI DMD Control devices reside
    • Potentially multiple defective DMD pixels (cluster) this is where
      multi pole pixels go bad side by side. When this occurs it cause the
      entire row or column to display as a solid line (off state). If this
      is the case the solution is replacement of the DMD chip itself which is
      costly.
  • 19,396 Answers
Check the cable and try changing input and output settings.
  • 4 more comments
  • Ginko
    Ginko Nov 21, 2008
    First check cables and connectors.
    If it is not a connection problem try shutting down both computer and projector.
    Start the computer first , then start the projector when computer is fully started and logged in, the projector should auto detect the channel.
    Try switching the projector input until you find the signal from the computer.
    If the computer is a laptop you may also have to press the video selection function key on the laptop to switch video to external connection.
  • Ginko
    Ginko Nov 21, 2008
    I mean check the video cable, if you have bars on the screen ensure that it is not just that you have no picture, in that case check video cables and video Input /Output settings on both projector and computer.
    If you see that it is not only a video problem, then there is an internal fault, probably the main board, since there is no signal.
    To find an authorised service centre in Puerto Rico Call Sharp, here is the contact: Sharp: Support.
    A good TV repair ceter can also do the repair.
    I also report my previous solution for better clarity, it was only concerning the video, if the projector is not starting at all see the above.
    Start
    If
  • Ginko
    Ginko Nov 21, 2008
    I will give you instructions on what I would do if I was in your shoes.
    First ensure it is not a video cable or video settings problem.
    Try also connecting the computer using a different kind of cables, and see if the projector restarts working.
    Do this before doing the following.
    Then grab the phone and call sharp at 800-237-4277.
    Ask them price for a repair, it will be surely over $150, probably more, the guy that said 20 USD here does not have a clue.
    As the repair will be expensive ask the cost of a warranty extension, or an extended service plan. This usually costs less than a single repair and cover the projector repairs for one year.
    If a warranty extension is available it will cost aorund $150.
    Buying a new one is still expensive, but will give you up to three years of guaranty cover.
    See a choice of new Sharp DLP projectors here.
    See a choice of other brand projectors here.
    A new projector starts at $400, here you get some suggestions:
    Acer EY.J5601.009 DLP Projector
    InFocus Learn Big IN2102EP DLP projector
    Sharp Educator XR-30X DLP Projector
  • Ginko
    Ginko Nov 21, 2008
    I talk to the wind
  • Ginko
    Ginko Nov 21, 2008
    Did you read my previous comments?
    If you read them , can you explain why they should not be "reasonable comments"?
    I am asking you this because I think you did not receive all my previous comments.
  • Ginko
    Ginko Nov 24, 2008
    If the computer keeps working fine, and only the projector is displaying lines after a while, that is usually because a bad component starts overheating after a while, the projector you bought is defective, and the problem is not the lamp, but some internal IC behaving erratically when the unit overheats.
    I publish below a copy from one of my old comments:
    As
) What feature of Powerpoint 2010 helps in broadcasting slides to remote audience
Dear Anand,
To broadcast your presentation, do the following:
  1. On the Slide Show tab, in the Start Slide Show group, click Broadcast Slide Show.
The Broadcast Slide Show dialog box opens.
  1. Do one of the following:
    • If you want to host your slide show on the service listed under Broadcast Service, skip to the next step.
    • If you want to use some other service to host your slide show, click Change Broadcast Service. Under Choose a broadcast service, select the service that you want to use. For more information about broadcast services, see Choosing a broadcast service.
Note If you do not see the service that you want to use, select Add a new service, and then in the Add Broadcast Service dialog box, enter the network address of the service you want to use and then click Add.
  1. After you select your broadcast service, click Start Broadcast. PowerPoint then creates a URL for your presentation.
PowerPoint creates a unique URL for your slide show.
  1. To send the URL for your presentation to your audience, do one of the following:
    • To send the URL for your presentation by email, click Send in Email.
    • To copy the link, click Copy Link.
  2. When your audience receives the URL for the slide show, click Start Slide Show to begin your broadcast.
The audience follows your slide show in their browser while you present within PowerPoint 2010.
  1. After you finish presenting and are ready to end the broadcast, press ESC to exit Slide Show view and then click End Broadcast.
After you begin broadcasting a slide show, the Broadcast tab appears in the PowerPoint 2010 ribbon.
Regards,
Tech_Comp
Feb 23, 2011 | Microsoft PowerPoint 2010
Tip
How to Rip and Convert 2D DVD to 3D AVI Video DVDFab 2D DVD to 3D Converter is a...
How to Rip and Convert 2D DVD to 3D AVI Video <br /><br />DVDFab <a href="http://dvdto3d.net/index.php/dvd-to-3d-converter/">2D DVD to 3D Converter</a> is a good hand to help out for one to convert a normal DVD, Blu-ray or video in 2D effect to 3D videos in various formats for playback on computer with some specific 3D player software, or on 3D TV. Next, I'll show you how to use 2D to 3D Converter to convert 2D DVD to 3D AVI. Read on. <br /><br /><b><a href="http://dvdto3d.net/index.php/dvd-to-3d-converter/">Rip 2D DVD to 3D AVI</a>&gt;Step 1: Run DVD Ripper, enable "2D to 3D" option</b> <br /><br />Run DVDFab DVD Ripper at first, choose "to AVI" mode. Then import the source DVD: insert DVD disc into DVD drive, click DVD folder icon or image file icon. You'll be asked to specify a region code for the movie, just do it. Then "2D to 3D" option is ready to be selected, just tick the check box to enable 2D to 3D Converter. <br /><br /><img src="565f08d129643cb67ea5f9ad89cfe69f.png" /> <br /><br /><b>Rip 2D DVD to 3D AVI&gt;Step 2: Flexible settings and customization</b> <br /><br />Choose one or more movie titles for conversion, and select audio tracks and subtitles. Specify a profile for movie title. Click "Title Start/End Settings" button to arrange the start and end chapter to select an accurate section for conversion. Go to preview title in real time if you want to make sure that you haven't made any setting flaws. <br /><br />Click "Edit" button to set lots of parameters for conversion, such as bit rate, frame rate, frame resolution, aspect ratio, channel, volume, etc. <br /><br /><img src="e9635043a2cce0d872744094a3020a19.png" /> <br /><br />Click "Video Effect Settings" button, then go to freely set up 3D format, video frame size, visual depth, play region, etc. <br /><br /><img src="e1a9813e35a9b7d3b6e679bfe42e2daa.jpeg" /> <br /><br /><img src="a4f1de2cdff4bd691a215cd3afeb97b4.jpeg" /> <br /><br /><img src="8c871d11a3d7589ee71524130835f59c.jpeg" /> <br /><br /><b>Rip 2D DVD to 3D AVI&gt;Step 3: Begin converting process</b> <br /><br />Click "Start" button if everything is OK. During the process, you'll be updated with detailed progress info and source movie preview. And you can also set your computer to auto shutdown when necessary. <br /><br /><img src="acb6ab56e492b3de06f4e79e26aeb012.png" /> <br /><br /><img src="f51019c37f50807e9f7567a1c129292d.jpeg" /> <br /><br /><img src="d039197644e6b1138289916931cbd368.png" /> <br /><br />OK, done. It's really easy and wonderful, right?
on Jul 05, 2011 | Computers & Internet
Tip
How to Create MKV 3D Video Out of 2D DVD Is this your dream that you have some...
How to Create MKV 3D Video Out of 2D DVD <br /><br />Is this your dream that you have some kind of magic that you can turn a 2D movie to 3D movie with fantastic 3D effect? It comes true now with the powerful tool - DVDFab 2D to 3D Converter. 2D to 3D Converter is the world's first full-featured 2D to 3D conversion app which can convert a normal 2D DVD/Blu-ray/video to 3D video available in various formats including MKV. Next is a step by step tutorial on how to convert 2D DVD to 3D MKV video. <br /><br />Required tool: <a href="http://dvdto3d.net/index.php/dvd-to-3d-converter/">2D DVD to 3D Converter</a> <br /><br /><br /><br /><b>Rip 2D DVD to 3D MKV&gt;Step 1: Trigger "2D to 3D" option</b> <br /><br />Make sure that you have DVDFab installed on your computer. Start it up, navigate to "DVD Ripper --&gt; to MKV" option. Now you're under the mode for ripping DVD to MKV video. Then you need to import the source movie via inserting DVD disc, or clicking DVD folder or image file icon. After the movie is in, check the "2D to 3D" box. OK, now 2D to 3D Converter is ready to work. <br /><br /><img src="af672e6a594b541bf5f963692d36894d.png" /> <br /><br /><b><a href="http://dvdto3d.net/index.php/dvd-to-3d-converter/">Rip 2D DVD to 3D MKV</a>&gt;Step 2: Prepare and set for conversion</b> <br /><br />Choose the title(s) you want to convert, note that the longest movie title is always selected for you in default. Then choose audio and subpicture streams for movie title. If you don't want to convert all content of a title, you can arrange its start and/or end chapter to extract a segment via "Title Start/End Settings" button on the main interface. In the left bottom corner of the UI, is a built-in player for you to preview title in real time. <br /><br />You can further edit the output effect by clicking "Video Effect Settings" button with a pop up where the 3D Format, Video Frame Size, Visual Depth, play region, etc. can be customized freely. <br /><br /><img src="0bbbe88b0753eb76ba11f23da2855899.jpeg" /> <br /><br /><img src="3fd90b43c24d7947ca02c0ac354e06ee.jpeg" /> <br /><br /><img src="b63d63ce97351650d96c9aa590449c64.jpeg" /> <br /><br />You are allowed to change a lot of default parameters of the video and audio if you like. Just click "Edit" button to open Conversion Settings window. <br /><br /><img src="4482442b7124496f79cf237f5dd13ae7.png" /> <br /><br /><b>Rip 2D DVD to 3D MKV&gt;Step 3: Start conversion</b> <br /><br />When you're ready, click "Start" button on the main interface. You can view detailed progress info, preview source movie, and set auto shut-down for your computer. <br /><br /><img src="236f1e5be10ac01a025a9cada3cde20b.png" /> <br /><br /><img src="d4343c7677a8c7fb372484e7eb920ece.jpeg" /> <br /><br /><img src="3ade01772791fec4957934c9ae8d4871.png" /> <br /><br />OK. That's all for this tutorial. Create 3D MKV out of 2D DVD is just so easy.
Why my psp can't download?
So you just got your new PSP and you want to download games but you're not sure what to do or where to go? Well this article will show you how download games to your PSP.
First you will need:
Sony PSP with firmware 1.0 or 1.5
PSP Memory Stick Pro Duo
1. Go to the website and pick the game that you want to download.
2. Download the game to your computer making sure that it will work with the version of firmware that is on your PSP player. Make sure the file ends with PSP
3. Insert the memory Stick into your PSP player
4. Connect the PSP player to your computer via the USB cable
5. Copy the game onto your PSP player making sure to place them under the "PSP", "GAMES" folders on your memory stick. If these folders don't exist on your memory stick you will need to create them.
That's it now you are ready start playing your games.
A LINK FOR FREE GAMES...
http://www.pspmaniaonline.com/
you can also download videos music etc by saving them into the respective folder like in above case..if folder not present create it...
Dec 05, 2010 | Sony PlayStation Portable (PSP) Slim...
I want to use a video from youtube in my 2010 powerpoint presentation. I already have embedded it into my presentation, but it will not play without a connection to the internet. Can you help me make...
if you have a program called real player you can right click the video and click download video to realplayer and go to the my videos folder in my documents and drag it to your powerpoint
if you don't have realplayer but you do have a windows computer you can download a free studio with a lot of other useful tools if you click the link it will bring you to a page that show all its features and you can download it there if you want. http://www.dvdvideosoft.com/free-dvd-video-software.htm at the top it says really big free video downloader download now that's not what im talking about but it might work too.
Nov 28, 2010 | Computers & Internet
Tip
Put music on SD card
1. Start Real Player on desktop
2. Hook PDA to PC
3. Run Real Player on PDA
4. In menu below player select burn/transfer
5. Select Music/All Music
6. Select songs to transfer over
Incidentally you can select mutpile songs at one time if you wish if they are all in a row
7. On the right side the songs will show up
8. Don't worry about "Will Not Fit" this only means desktop real player can't see your PDA or your card isn't plugged in all the way. Make sure it is B4 you begin
9. The songs will show on the right "Ready To Transfer"
10. Once you are done, lower left click START TRANSFER
on Jan 02, 2009 | Palm Tungsten E2 Handheld
I have a sound related problem and do not know how to solve
Can you play audio files even if there's no sound with the Windows Media Player? if so some files of the sound driver is missing, you need to update the sound driver. Or if you can't play, then there's no sound driver only the codec is present without the device driver, the process is more or less the same..but before you follow these steps, put the Motherboard Driver CD on the CD Rom: Right Click on My Computer - Manage - Device Manager - Right click on the Yellow icon - Update Driver - No, Not this time - Next - Install from a list or Specific location - Next - Tick the "Include this Location in the Search - Browse - Go to the CD Rom Directory and search the Driver/Audio folder - and Select the Audio Driver folder - click OK- Next - Finish.. done..... Good luck.. Do let me know if this doesn't solve your problem, i am ready to help you..
Apr 29, 2010 | Computers & Internet
My lab top want go to full screen
When you hover over the playing video, it will display a control bar. To the immediate left of the speaker icon is another icon that will bring the video to full-screen mode. Just click on that and you should be good to go.
Jul 11, 2009 | Compaq Presario CQ60-220US PC Laptop
Music from Windows Media Player does not show on Archos list
I had a similar problem and ended up using Real Player to put music on my Archos.
Nov 12, 2008 | Archos 605 Digital Media Player
My philips gogear 8gb won't come on.
you wil need to get windows media player 11 and update your usb drivers
Mar 26, 2008 | Audio Players & Recorders
1,081 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
