Question about Audiovox VE1020 10.2 in. TV/DVD Combo
AUDIOVOX VE1020 has audio, but no video
My Audiovox under the cabinet LCD TV has audio, but no video. The unit is less than 2 years old and we only use it approx 2 hours a day. We don't swing the screen up flat too often ...maybe twice a week. The screen is black, but it did not fade out. Could it be the bulb? Audiovox wants $135 to fix it. I'm debating on whether I should attempt to fix it myself. HELP!!!
  • dylandad Dec 07, 2007
    have sound no video and no indication of burn/melt of circuitry, plus cannot seem to find the ccfl tubing...any indication of where to find it...harry
  • dennis007 Dec 13, 2007
    Hi Amanda and Paul (fliptop)
    I experienced a similar problem with my Audiovox VE926 under the cabinet tv. After looking at Paul’s picture of the circuit board, I opened up my unit and although it is not exactly the same, the capacitor that Paul is looking at is marked on mine “0.1 j 63”. I assume this is a .1 microfarad capacitor with a 63 volt rating.
    My problem, however, is a component near to this capacitor. On my board there are two identical units with three terminals on one side and one on the other. On Paul’s picture it is about a ½ inch to the right of the blue tape transformer. One of my units is marked DF S2N. One is good and one is fried.
    Any ideas what this is? If you throw your not working out, I would gladly take the circuit board off your hands.
    Dennis in Canada
Ok, here is a bizarro solution that just worked for me. It is a solution to the problem, not a technical fix.
1 Turn unit on
2 Using remote control unit press "DVD" button, upper left.
(When I did this the Audiovox screen appeared)
3 Then using remote control unit press "TV" button, upper left next to DVD button.
(For my unit, this gave me a TV picture)
Strange, huh?
Posted on Jan 14, 2008
I don't know how to rate solution #2 but IT WORKED! Thanks so very much! I was ready to go out and buy another unit! You saved me! It was very bizarre because I didn't accidentally hit a button on the remote.....I walked out of the room and back and the screen was black.
Thank YOU! Theresa
Posted on Feb 04, 2008
Thank you for your response Paul. You have given me enough information to make an educated decision. I guess I'll be handing over another $135 to Audiovox to fix it. I hate to do it, since we already paid over $500 for it 2 years ago. Unfortunately, we are having withdrawals and need our kitchen TV. A new one means more money and ,possibly, more headaches. Thanks again. Happy New Year!
Posted on Dec 27, 2006
Hi amanda - i just had a customer bring in an audiovox ve920 with the same problem. i took it apart and there's a capacitor and possibly a transformer on the circuit board behind the screen that are burned/melted. i contacted audiovox to see if i could get a schematic diagram to attempt to fix it (the capacitor is burned beyond recognition), but they refused and suggested i ship it in for the same $135 charge. i'm going to investigate further to see if i can figure out what kind of capacitor it is and see if i can get one from someplace like shadio rack. as for your question ("could it be the bulb?") i want to let you know that lcd panels have a tube across the bottom that's called a cold-cathode fluorescent light (ccfl), and they do go bad. the ccfl provides backlight to the screen, which means if that were the problem you'd still be able to see something on the screen, it would just be very dim. i don't have my camera with me, but i will bring it tomorrow and possibly upload an image of the bad part. if you decide to take the screen apart, let me know what you find out. regards, paul
Posted on Dec 21, 2006
  • paul trader
    paul trader Dec 22, 2006
    hi again - i've taken a picture of the bad part.
    regards, paul
I need a under cabinet mount
The VE1020 didn't come with a mount. It came with round plastic spacers (16) that were 1/4", 1/2", and 3/4" thick. You could stack these on the mounting screws to get the clearance you needed for under the cabinet mounting. You will note that there are 4 through holes for the mounting screws, one in each corner of the chassis. Sheet rock screws of different lengths will work. You can easily just cut four small blocks of wood or use 3/4" - 1" wood dowel cut to the length you need. Drill a through hole in the dowel. Paint them to match if they will be exposed.
Mar 26, 2014 | Audiovox VE1020 10.2 in. TV/DVD Combo
Can only receive cable channels 2 through 13;
Turn the unit off, push the setup button 3 times. Press the seek left/right to switch between cable / antenna tuner modes. When cable is selected, press the channel up/down to switch between cable modes. When the unit turns back on, it will rescan for channels.
Aug 04, 2009 | Audiovox VE1020 10.2 in. TV/DVD Combo
No picture only sound
The most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty with some type of extended purchase plan, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Jun 28, 2009 | Audiovox Televison & Video
AudioVox VE 1020 BAD DISK
I was able to find a junk unit (screen no good) on eBay -- swaped out the dvd player - everything has worked fine since (except 6 months later I had to swap out the audio card from the same junk unit - and now all OK ever since.)
Nov 10, 2008 | Audiovox VE1020 10.2 in. TV/DVD Combo
Audiovox FPE3206 - Power Light is Blue/ON but Screen is BLACK
I had the same problem, except with a flashlight I could see AUDIOVOX when i turned it on and I could see the video when I put a DVD in. It is hard to see even with a flashlight so you have to look closely. Well, I researched and investigated what might be the problem because I was upset that I had the TV for less than two years. Everyone was saying the inverter was defective. Apparently the inverter is what gives the LCD screen the back light to see the video. So I called audiovox and found that thier part's selection was only a power board and a remote control for this TV. I asked them if they could get me an inverter and they did. With shipping cost it was approximately $150.00. They ensured that I know that there is no refund on this part (which is common for electical parts). So I took a chance on it not being the right part for the problem. I replaced the defective inverter myself and it worked. It solved my problem. The inverter is a circuit board that plugs in and has a few screws to hold it in place. I had to remove the back cover first and a couple of brackets inside the tv to get to the inverter and replace it. There is a quite a few screws so I recommend writing down where each came from for easier reassembly. I hope this helps!
Oct 08, 2008 | Audiovox FPE3206 32 in. LCD Television
Is Audiovox VE1020 HDTV compliant?
Audiovox VE1020 is not a digital set. To see digital broadcast you will need another digital reciever or a long lead to connect to your existing one.
This set does not have very good reviews either.
Hope that helps!
Jun 06, 2008 | Audiovox VE1020 10.2 in. TV/DVD Combo
No video
it's possible while they were fussing that the yellow video cable got jerked or pulled. try a new video rca cable.
May 02, 2008 | Audiovox VE1020 10.2 in. TV/DVD Combo
Image upside down on my Audiovox VE1020
Check the screen position switch, they sometimes get fouled especially if installed in a kitchen.
Apr 07, 2007 | Audiovox VE1020 10.2 in. TV/DVD Combo
Audiovox VE1020 10.2 in. TV/DVD Combo Logo
585 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
