Question about Belkin Computers & Internet
I cannot get the internet on my main computer that has the Belkin Router connected to it, the blue light for internet on Router is now flashing orange. Thank You Peter
  • Belkin Master
  • 4,806 Answers
Disconnect the power suppy from the router for a minute or so, then plug it back in, give it a minute to reset and try again
hope this helps
regards
Posted on Nov 20, 2008
I have a belkin N wireless Modem - router and i try to connect to the internet but i doesnt, all the lights are blue exepct the internet one, that flashes orange...and when i troubleshoot it says that the...
Hi Friend,
Before checking these.please disconnect the Modem from router.Connect the Modem directly to your computer or laptop and check whether you are able to access the internet. If not please check with you Internet Service Provider.
Regards,
Aysaam
Sep 05, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
Hi Friend,
Regards,
Aysaam
Belkin router can't connect to internet
This is part solution, part clarification request: When you say that you installed the setup software on your laptop, setup software for which: the modem, or the belkin router? Also what type of internet service do you have - Cable? DSL? If you are not sure, list your ISP. What operating systems do you have on your laptop and your main computer?
You say that you connected the modem to your main computer - I am assuming that you mean that you connected your modem with a network or ethernet cable (the one with a connector that looks similar to but larger than a telephone's connector) to your computer's ethernet card, or NIC, port. Is anything connected by ethernet cable to the Belkin router? If you have not connected the modem directly to the router, it will not connect to the internet, and anything connecting to the Belkin router will not be able to access the internet as well.
Try this: disconnected the power from your modem, then disconnect power from your router, and disconnect any ethernet cables from computer & modem, or computer and router. Connect an ethernet cable from the modem to the Belkin Router. (Ensure that you have plugged in the ethernet cable on the router into a port that is either set aside from others, or indicates "Internet", WAN, or something similar - it should be marked either with a different color, labled, or both). Now power on your modem. Wait until you see a steady "ready" light, green ethernet light, or the light usually lit for that model indicating it has completed its bootup tests and the internet connection is ready.
Next, ensure the ethernet cable is connected from the modem to correct WAN or "internet" port on the Belkin Router, then power up the router. Once the router boots up completely, plug in a cable from your computer's (main computer) NIC or ethernet card or port, to a port on the Belkin Router (there should be more than one port available, generally numbered "1, 2, 3" and so on - in a group, seperate from the WAN or internet port). Once you are sure you have the cable plugged into one of the correct ports, and if you have windows, restart your main computer.
Now on your main computer, check to see if you have an internet connection. If you do, you can now resume running the router's software setup on your laptop, which sounds as though it was walking you thru the setup process to connect you via wireless connection to the internet. Report back if you have any success, or if you have any further problems, and best of luck! Hope that info helps
May 05, 2010 | Belkin (F5D8231-4) Wireless Router...
My Belkin F5d82334v3 router flashes orange continuously
Contact belkin for the IP address to change your router setting internally. For example: Linksys is 192.168.1.1
Putting this address in your address bar will dial you into your router setting if you have a Linksys router. Each router manufacturer may have a different IP address. Hope this helps! Good Luck!
Mar 15, 2010 | Computers & Internet
So I got this Belkin router (N) and the wireless light just comes on and goes off as it feels what up?
On my Belkin router the wireless light only light up when somebody is actually connected using wireless - it also flashes orange when somebody is trying to connect but failing - my router is a F5D8236uk4
Feb 27, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
I have an N+ wireless router that will not talk to my motorola SB5100 cable modem the modem and internet lights flash amber and the setup assistant does not help.
IF Your ISP is Cable then
Step 1 : Connect Modem - Router - Main Computer *(Wired)
Step 2 : Open RSP By typing 192.168.2.1 On the Address Bar of the Internet Explorer
Step 3 : On the left side under internet WAN Click Connection Type
Step 4 : Leave the password Blank And click Submit
Step 5 : Select the Connection type As Dynamic
Step 6 : Click Next
Step 7 : Leave the Host Name Blank And click Apply Changes
Step 8 : On the Left Click on MAC Address Cloning
Step 9 : Click Clone , Apply Changes
Step 10 : Turn off the Modem And the Router
Step 11 : Turn ON The Modem First, Wait Until All the Lights Are ON
Step 12 : Connect the Power To The Router
Step 13 : Wait for 5 Minutes
Step 14 : If The Lights Are Still Flashing
Step 15 : Connect Modem - Computer
Step 16 : Check if It is getting the Internet
Step 17 : If its Not then Restart the Modem And Try It
Step 18 : Make Sure You are getting the Internet When you Connect Modem - Computer
Step 19 : And after that Connect Modem to the Yellow Port on the Router
Step 20 : Check the Lights After 5 Minutes
If it is Still the Same then call Belkin Tech Support
The number is 1800-223-5546
Nov 07, 2009 | Belkin Computers & Internet
Computers & Internet Logo
46 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
