I have a gas heater Rinnai 1004F and few dyas ago the filter light came on. We cleaned the filter but the filter light has benn blinking since them. I already check the exhaust pipe and nothing. I also noticed that the front of the heater is a small door with a pull sign. Inside there is a tray with a water level mark, what is this for? Are we suppost to fill it with water? Need help!
The tray is if you want to add humidity. You will constantly be filling it. The filter light could indicate a dirty blower or debris slowing down air flow over the heater.
Was this helpful?
Yes
No
Popular Solutions for Rinnai RHFE-1004FA 38,400 BTU
Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater -...
The thermostat seems off as we have the temperature set at 60 degrees and, although the room...
(More)
The thermostat seems off as we have the temperature set at 60 degrees and, although the room temperature on the heater says 58, we are all moving around in short sleeves so it must be in at least the 70s! Is there a way to adjust the thermostat?
I have a Rinnai Energysaver 1001ft it has the outlet at the back for the heater ducts. I, however...
(More)
I have a Rinnai Energysaver 1001ft it has the outlet at the back for the heater ducts. I, however would like to have the heated air to blow from the front vents. How do I achieve this? My email add. is nwidmer@bigpond.net.au thank you Nick Widmer
I would like our Rinnia 1001ft to blow heat out the front grill and not the rear duct how do I...
(More)
I would like our Rinnia 1001ft to blow heat out the front grill and not the rear duct how do I achieve this
rinnai energysaver 1000ft I havent used it before - we just bought this house with it instaled. when...
(More)
rinnai energysaver 1000ft I havent used it before - we just bought this house with it instaled. when I turn it on the fan goes for a minute or so, the ignition fires and the red light turns on, then the whole thing shuts down . any help?
