Question about Sony Playstation 3 (PS3) Console
Cant get a online connection formm router to ps3
I think it might be the configuration problem im trying to hard wire it directly from router to ps3 i have the WRT54G router
Problem is fixed thanks
Posted on Nov 26, 2008
Yes my son got a ps3 for christmas he had been playing online on one of his games and then he tried one day and it says it cant connect but has 100% signal.What do i need to do to fix this problem?thanks
You must first determine if you have been messing around with the configuration on the router, assuming that is connecting your PS3 to the internet, or the PS3 itself. Try this:
http://www.zolved.com/synapse/view_content/19797/Playstation_3__How_to_setup_your_Internet_connection
it all really depends on the router settings itself: if it is a wired or wireless connection it must be of certain range for the PS3 to understand; thus, I must know what router make and model you are using.
Jan 22, 2011 | Sony Playstation 3 (PS3) Console
I cant log in on my ps3 or do anything internet related due to the error code 80130182 what should I do?
This is a common error which won't allwo you to connect online, here are some steps that youc can try that might fix the problem.
• turn off your PS3 and router/modem
• if you are connected thru wireless, try to hook up using hard wire this time
• you have to access your router/modem's homepage and change security key or might as well disable it in the mean time
• turn on the PS3 and your router/modem and go to Settings
• then scroll down to Network Settings and configure your connection it should detect it as wired
• then try to update your system with the latest firmware update under System >> System Update (if it is not updated)
• after that you can generate another security key and and enable security
Hope these steps helps.
May 10, 2010 | Sony Playstation 3 (PS3) Console
I am trying to connect my PS3 online thru Netgear router. It (PS3) is stating can not access.
Does anyone know anything about ps3? Im trying to get online through netgear and it keeps telling me that my cable is not plugged in, but it is..dont know whats going on with it..!
Nov 26, 2009 | NetGear WGR614 Wireless Router
Just wanted to know is there any way to get my ps3 online
try opening a portal from you router to your ps3, the router will shut down all the things it need to in order to play your games more efficiently. If that doesn't work try hard wireing your ps3 to your router. If your getting online on your ps3 wirelessly then try moving your router or your ps3 closer together.
Nov 08, 2009 | Westell Wirespeed VersaLink...
Lost connection when trying to play online
hard wire the ps3 to the router first to see if connection is lost.............if not it's interference between ps3 and router
Aug 01, 2009 | Sony PlayStation 2 (PS2) Console
Can't connect to internet wired or wireless with wbr-2310
Disable the IPV6 and use the IPV4 then try accessing the configuration page of the router and configure the Internet Settings
Jan 27, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
Cant connect ps3 wireless to dlink router
The router should assign an IP address to your PS3 if it isn't manually configured. If you are connecting wirelessly make sure your security setting on your PS3 match your router. If the problem persists disable wireless security on your router and then try to connect with the PS3 with security disabled as well. Sometimes consoles have trouble connecting with WEP or WPA security encryption.
Jan 06, 2009 | D-Link AirPlus DI-524 Wireless Router
80710092
Try changing the ISP from your Network Options menu. Change it to something random. And then try your ISP or 127.0.0.1 Hope this helped.
Jul 09, 2008 | Sony Playstation 3 (PS3) Console
Ps3
Are you going to connect your PS3 wired to your router or wireless?
1. check first if ps3 is working behind rca modem.
2. then connect a pc directly to your linksys router
3. open configuration page of linksys by typing your gateway on your browser. (usually it is by default 192.168.1.1)
4. go to applications and gaming tab
5. you'll find there port forwarding..key in your number there
> i guess your numbers are like 88 and 3764 (something like that)
6. if your trying to connect your playstation wirelessly, you need to know your wireless security (if your router is secured).
> go to wireless tab and look for wireless security
> get your key
7. go back to playstation and try to view your wireless network
> connect and type in your key
Jan 25, 2008 | Linksys Wireless-G WRT54G Router
My ps3 will not connect to my wireless internet
Try setting a static ip address on the PS3:-
First you need to find a Windows wired or wireless device already connected to the network in order to find out the required settings
Windows XP
1. Click start --> (sometimes settings) --> Control Panel --> Network Connections
2. Double click on the active connection which will say connected underneath
3. Click Support
4. Click Details
5. Now the IP Address, Subnet Mask, Default Gateway, Primary DNS and Alternate DNS which are displayed should be noted.
Windows Vista
1. Click Start --> Control Panel --> Network and Sharing Center
2. Click on "View Status" to the right of your connection
4. Click Details
Set these values under "manual settings" in the PS3 but add 1 to the last number for the IP Address as this has to be unique on your network
Jan 04, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
22 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
