Question about GE Microwave Ovens
Microwave starts after plug-in cannot be stopped by control panel
Hi, there:
My neighbor owns a microvave oven
placed above the range.
Model: JVM231BL 002
Serial: VL989405 S
She never used it until yesterday.
As soon as she plugs the microwave into
the outlet, the microwave starts
the fan and the lights.
Both cannot be switched off with
the panel controls.
All other buttons on the control panel
show actions on the display.
Thank you for your help.
Regards
Henning
  • 108 Answers
This seems like a problem with with the door latch circuitry HW. If the unit is still in warranty, call GE customer care. If not, your neighbor will need to buy a new oven. Service on microwave ovens is not cost effective because the replacements are so reasonable and have so many new features.
I have a lot of experience with these units. If the door latch circuitry is in question you may be exposed to dangerous microwave energy. Hope this helps...
Ray
Posted on Nov 20, 2008
Have Kenmore microvave and the vent starts on its own
Actually, that's a feature! If you cook much on the range (stove) beneath the microwave, the heat will cause the microwave bottom to heat up quite a bit (just touch it!), and the microwave will turn on it's exhaust fan in an attempt to save itself from burning up. It will shut off in about 15 minutes after you turn off the source of heat.
But if the fan comes on by itself even when the microwave is cool (or at least not hot), then you probably have a defective fan thermostat. This thermostat is located behind the control console on the inside bottom of the microwave.
Aug 27, 2014 | Kenmore Microwave Ovens
No power checked outlet and power is on
HELLO.
This is the way out of the problem.
The outlet is on power,the power problem is from the microwave.
check on the back of the microvave to locate the fuse that control the supply of power to the microvave.
Change the fuse because it is unable to control power supply.
Then plug the microwave to the outlet.
Thanks .
Sep 19, 2011 | GE JVM1790SK Convection/Microwave Oven
No power to microwave JVM1790SK ...checked outlet and it is live
HELLO.
Since the outlet is live,the power problem is from the microwave.
Thanks .
When the microvave in plugged into outlet it makes a buzzing sound but works ok. When the door in opened the noise stops but starts back up when door is closed.
I just had the same problem with my ge spacemaker microwave model number JVM1490bd. I removed the grill on the top of the microwave with two screws on top. There is one screw that holds the front touch pad on, remove the screw and lift up to remove. The damper assembly is on the upper left, my door was sticking and didn't make the limit switch. I moved the door back and forth making the switch a couple times and that solved the problem.
Jul 16, 2011 | GE JVM1490 Convection/Microwave Oven
Roper microvave model# mhe14xkq has stopped heating and is making a sound like it aiways has only louder--what part do I need
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Apr 23, 2011 | Whirlpool Microwave Ovens
Our Microvave oven build in over the range , Model # JVM1630WB is not heating anymore; the Microvave also makes an unusual noice. Please help with a solution. Do you recommend repair or a complete new...
Hi, Most microwave problems are not worth repairing...espec. one like this that sounds like it will be rather expensive to repair...
heatman101
Nov 25, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I have a Maytag OTR Microwave oven that doesn't work. After I close the door and set the time and start, I see the time countdown, but I don't see the microwave starting. I can get the microwave to start,...
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
See our file on door switches here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Sep 30, 2010 | Maytag Appliances Over-the-Range Microwave...
F7 code on Whirlpool Microwave model GH9185XLT - 1
Power to magnetron
interrupted
12. Replace inverter.
13. Replace all parts and panels before operating.
14. Plug in microwave oven or reconnect power.
15. If problem persists, unplug microwave oven or disconnect power.
16. Replace electronic control.
17. Replace all parts and panels before operating.
18. Plug in microwave oven or reconnect power.
19. If problem persists, unplug microwave oven or disconnect power.
20. Check for reversed plug connection on controls or loose wiring.
21. Replace all parts and panels before operating.
22. Plug in microwave oven or reconnect power.
May 23, 2017 | Whirlpool GH9185XL Microwave Oven
E-Wave over the range microwave has blown main fuse
My Ewave has stopped heating eventho it appears to be running. Is is possible the power has been reduced or does the microwave need to be replaces
Nov 16, 2009 | Microwave Ovens
One year one month old and the magic chef microvave mc0160ub die
Hi this is tech crazy
The above mentioned link will be of great use to you.Just check out with it and do the necessary steps in your microwave oven
http://www.ehow.com/how_112488_diagnose-microwave-oven.html
Hope that it helps you a lot
Please do rate me on the above said solution
Feb 03, 2009 | Magic Chef CMV1000B Microwave Oven
Microwave Ovens Logo
101 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
