Question about HP OfficeJet 4215 All-In-One InkJet Printer
Questions on setting new defaults
How do I set the default for black & white printing only
How do I set the defaulf for the fastest printing speed
How do I set the the default to print at 65%
Thank you
Hank
    Scholar:
  • 78 Answers
Set xerox 7845 to black as default print color
You can always look for answers to your Xerox questions at www.xerox.com/support .
Default the Print Driver to Print in Black and White Only for a Microsoft Windows 7 OS:
The steps below can be used to restrict color printing through the print driver.
NOTE: This solution requires administrative permissions and may require the assistance of a System Administrator.
Open the Printers, Printers and Faxes, or Devices and Printers window. See the Related Items below for additional information.
Right-click on the printer, and then select [Properties] or [Printer Properties].
Click on the [Administration] tab.
Expand the [Configurations] section.
Enable the option for [Black and White ONLY].
Click [OK]. The driver will now have Black and White printing as the default and locked so that the option cannot be changed.
Default the Print Driver to Black and White for a Microsoft Windows OS:
Open the Printers window on the computer.
Right-click on the required printer, and then select [Properties] or [Printer Properties] depending on which operating system is being used.
Click on [Advanced], and select [Printing Defaults].
Click on the [Image Options] tab.
Under Color Correction, select [Xerox Black and White Conversion].
Select any other required driver default settings.
Click on [Apply].
Click [OK] to save the settings.
Close the window.
Default the Print Driver to Black and White for MAC OS:
Launch an application, preferably not your browser, that you can print from, e.g. Microsoft Word
  1. Select File -> Print
    1. Select Xerox Features where it says Copies \& Pages
    2. Select Color Options from the drop down labeled Paper/Output
    3. Select Black and White (Black and white printing on the Xerox 7845 costs less.)
    4. On the Presets drop down, select Save As and enter a name, e.g. "Black and White" if you print to multiple printers, check the All Printers
    5. Click OK to save this preset
Now you can test printing by clicking Ok to the print dialog.
Sep 30, 2013 | Office Equipment & Supplies
Lexmark 3600-4600 stops at 34% when trying to print a test page. Color ink is low, but I only want black in any event.
If your color ink is already empty or not substantial for printing, then you must replace it with a new cartridge. The Lexmark printer will continue to print when there's substantial ink in the cartridges.
If you prefer to print in black and white as your default print setting, please follow the steps below: (make sure your black and color cartridges ink levels are good)
For Windows OS:
1. Go to Control Panel.
2. Open Printers and Faxes.
3. Right-click on Lexmark 3600-4600 Series print object and click on Properties.
4. In the Lexmark 3600-4600 Series Properties window, go to Advanced tab. Click on Printing Defaults.
5. In the Lexmark 3600-4600 Series Printing Preferences window, under Ink Use, select Print using black ink only. Click OK.
6. Click OK button in the Lexmark 3600-4600 Series Properties window to save the changes.
Your printer will print in black and white draft mode the next time you send a print job to the printer.
For Mac OS:
1. With the file (you wish to print) open, go to Print. A window will pop up.
2. Select the Lexmark printer.
3. Expand the arrow pointing down beside printer name if you're not able to see other options for printing. Look for Quality and Media.
4. Under Paper tab, select Print in Black and White.
5. Save this as your default print setting. Click Presets option and choose Save as. You can personalize the name for this default print setting (e.g. Black and White Draft or My Setting).
Select this Preset name every time you print your files/documents.
Aug 31, 2011 | Lexmark X4690 Wireless InkJet Printer
Is there a way for me to set my copier to default print black and white? I know this can be managed by each PC but sometime folks forget so i would like to deafult all print jobs to B/W unless otherwise...
TO SET THE MACHINE FOR BLACK AND WHITE ALLL YOU NEED TO DO IS SELECT BLACK ON THE COPIER PRESS THE UTILITY USER KEY THEN PRESS COPIER BUTTON DEFAULT BUTTON THEN SELECT CUREENT SETTING
THIS WILL DEFAULT THE MACHINE TO COPY IN BLACK TO SET PRINTING IN BLACK YOU CAN SET UP THE DRIVER TO PRINT IN BLACK ONLY
Jun 03, 2011 | Konica Minolta Bizhub 222 Black and White...
I have just installed a new colour and a new black ink cartridge but it will only print in black and white and not colour. Why??
check your settings under the Printer settings... you might have changed it to BLACK & WHITE only.
Make sure that you have the global settings set so that by default the printer uses BEST Quality depending on model.
May 26, 2011 | Office Equipment & Supplies
Can the copy setting be defaulted to black and white document?
You can set it to B+W but it will revert to its default setting the next time you print.
Jun 30, 2009 | Lexmark X1150 All-In-One InkJet Printer
No setting for black and white printing only
The setting isn't on your printer, its in windows.
The next time you print, instead of just clicking "Ok" to send the document to the printer, click "properties." this will look different depending on your OS and whether or not you have printer software installed so I can't give you step by steps but there should be an option here to either set the printing defaults to greyscale or just a straight up black/white dropdown/checkbox. save that as default and you are done.
Jun 03, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Why does the Samsung clp-510 color laser printer keeps defaulting to black and white print out when printing color images?
Well one thing you should do is when your printing something out before you print make sue that you have selected color not black and white because most printers have a default setting to use black and white. Also make sure that you have color ink available to print.
Apr 09, 2009 | Samsung CLP-510 Laser Printer
HP Deskjet, Set to Black & White; but still prints with color!
Bronze, hopefully this is a logical issue: Assuming you're on WinXP > Go to Start>Control Panels>Printers (and faxes).
Find the printer in question in the list (maybe there's only one or 2 listed) and 'Right-click' on the icon > go down to "Printing Preferences" (about second/third down the list).
In here you will be able to set the printers default settings. I'm not 100% familiar with HPs printing dialog, but there maybe a setting there for either 'Black & White' and 'Grayscale' (albeit it should be greyscale, anyway...) if you choose black and white your printing will not have any mid-tone, so if there's a choise, choose 'Grayscale'.
You can set other features here which will become the new default each time you go to print something - personally I set to 'Draft' or 'Fast Draft' mode by default, that way when I just print out rubbish, I am saving "lots" of ink and if I want something in good quality, I change it at time of printing.
Now, there are some programs and files that "remember" you last print settings, so if you've used a colour print setting previously, that file may still pring in colour, even though the new defaults are mono (black & white). So, print using the new defaults and save the file when finished. It's unlikely the case with OpenOffice, but, I don't know. We'll tackle that as we get to it.
So, if that has not cured the problem, please let me know.
**.The best way to acknowledge contribution is to rate it's relevance.**
Feb 05, 2009 | HP Deskjet 3845 InkJet Printer
Setting default
  1. Go to START>PRINTERS AND FAXES
  2. Right-click on your printer and choose "Printing Preferences".
  3. Choose the Color tab and set it to "Print in grayscale"
  4. You can also set it to use the b&w cartridge only for true black & white prints.
Jan 17, 2009 | HP PSC 1600 InkJet Printer
Can I set default printing to black and white for color laser printer?
Yes. Any printer's default options can be set as desired. Open the printer's properties (Start/Control Panel/Printers/right click the printer and left click Properties), and change the setting as you wish, then click OK. Those settings should be used each time you use the print command, unless you change the settings for that particular print job.
Hope this helps, and please rate my advice, good OR bad.
Feb 05, 2008 | Office Equipment & Supplies
HP OfficeJet 4215 All-In-One InkJet Printer Logo
54 people viewed this question
Seeker5211
Seeker5211
