GE JVM1490 Convection/Microwave Oven Logo
Posted on Nov 20, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The interior light on my microwave convection oven doesn't light.
The interior light on my GE microwave convection oven model JVM1490WH01 has stopped working.  Is there a way to replace this without calling a technician.  Where is it located?  How is it accessed?  What is the replacement?
  • harrisllc Feb 15, 2009
    I have a GE Microwave convection oven, model JVM 1790 BK01. Does it have a light inside of it, if so, how do I replace it?
William Miller
Level 3:
  • GE Master 9,179 Answers
  • Posted on Nov 21, 2008
William Miller
GE Master
Level 3:
Answers
9179
Questions
Helped
4480605
Points
21747
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
On an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
4helpful
Model JVM1790SK 01 Where/how do you change the
This is a pretty bad design, sometimes you can just remove the upper grill and access the light assy. If the panel is to tight to work in to change the light,you get to take the whole micowave down and remove the outer wrapper to change the light bulb. This is also not a standard bulb (part #WB25X10019). You may be able to get one from Lowes or Home Depot actually Sears would be a better bet, otherwise you will need to order one from an appliance parts outlet. Hope this helps and sorry I didn't design the thing I just fix them.
1helpful
GE PEB1590 microwave oven. Interior light burned
Remove the screws from around the rear of the oven and slide the cabnet off to the rear. You should be able to access the bulb from here.
WARNING: any time you work on a microwave you have to be careful of the capacitor. Unpluge the microwave and discharge the capacitor with a large screwdriver with a plastic handle.
Be careful.
I have a GE jvm1790 microwave that when its pluged in, the magnatron fan runs with the interior light is on constantly. I can't start either the microwave or convection. Everything stops when the door is...
The megatron tube is not working. The microwave should turn off when the door is opened for safety. If it is still under warranty, return it. If not, you may consider replacing the unit. I know its expensive, but its just taking up cabinet space tonight.
Convection Oven has stopped working
magnetron may be defective . replace d magnetron
I have a GE microwave. Model # JVM1870BF02 and the interior light is not working. I see a circular disc in the roof inside the oven but, can not seem to slide it and remove to replace the light bulb. Can...
THAT DISC ACTUALLY HOUSES THE ANTENNA FOR THE MICROWAVE ENERGY. NO NEED TO GO INTO THAT. TAKE OFF THE FROM GRILL AND IN THE MIDDLE THERE IS A METAL COVER WITH ONE SCREW. TAKE THAT OUT TO ACCESS THE BULB.
Looking fr wiring schematic JVM1490WH01
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
1helpful
Interior Light
The interior oven light can be accessed in the following way:
1.Open door and remove the top grill via the 2 screws along the top edge.
2. In the interior light will be under metal plate with fasten by single screw. The halogen bulb is rated at 120V 20watt. Looks like a G-8 bulb with 8mm pin spacing with o.a.l. 1-5/8" long
Get these bulbs cheap at http://www.1000bulbs.com/120-130-Volt-G8-Base-Halogen-Light-Bulbs/
GE microwave interior light bulb replacement.
Manufacturers used to include access panels in the rear or side so you could easily change the bulb. That exposed the customer to 110V connectors, and that posed a real liability threat, so they stopped using them.
You now must generally remove the outer cover to replace the bulb.
In many over-the-range models, that can mean having to take the oven down from the wall! For safety's sake, that should be a two-person job and it's really helpful if you have your original installation instructions to do this.
Many models use one halogen lamp to illuminate the cooktop and another to illuminate the cavity. You must not touch them with your bare skin as the oils will shorten the bulb life.
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
My GE JVM1790SK
If you or a friend decide to work on it, we have *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your base model number (without the suffix) here: http://tinyurl.com/gv383 You may have a bad door switch. We also have a file on door switches at our site.
Top GE Microwave Ovens Experts
vince
NOEL
NOEL
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
