My notebook shuts down right after powering up
When i press the powerr button it will start then shut down immediately.
Have tried with battery alone and then adapter alone.
  • 1 more comment
  • btmarraffa Dec 06, 2008
    My laptop will go on for a minute and then it shuts down immediately. I cant seem to keep it powered on
  • Anonymous Dec 31, 2008
    When I power up my hp compaq nx6110 laptop notebook it will stay on for about 4 minutes sometimes less, then it turns off. How can I fix this problem. Desperate
  • Masouds Jan 16, 2009
    it shuts down right after turning it on (almost 5 to 10 seconds)
    Masoud Salami
  • 4,338 Answers
This is a protective measure. Your Processor fan is probably not spinning and cooling the unit. You can probably open the fan access on the bottom of the case (on most laptop). If you see the fan,clean it with cannned air and make sure that is spins freely. If it does not spin, you need to replace it.
If I could be of further assistance, let me know.
If not please rate this.
Posted on Nov 20, 2008
  • 109 Answers
Posted on Feb 12, 2010
  • 237 Answers
When you start up, hit the C key while powering up. I am not an expert with Apples, but that is usually what the technicians tell me to do. Please don't rate this comment, I'm just offering a suggestion.
Canon a630 turns on then shuts down
1) press the power button for a moment
2) confirm that memory card is securely closed
3)batteries loaded in wroing directin
4) batteries ARE not the same right type , use only alkaline or NImh
5)insufficiente battery voltage.
6)poot contact between camera and battery terminals.
7) if this DOESNOT resolve the problem you must go to the repair shop service, some short in the SYSCOM and circuit associates are faulty.
God bless you
Sep 22, 2012 | Canon Cameras
The battery and power plug on leds flash orange at the same time. When I press the power button, the HDD and the ON leds come on green for a few seconds then they go off and machine shuts down without...
Your battery probably got wet. If this is the case you are going to have to deal with it by following the procedures you just outlined until you replace it due to the fault in the battery.
Jun 23, 2011 | Toshiba Satellite L455DS5976 Notebook
After charging battery, when I press start, it attempts to start and then immediately shuts down. After recharging the battery a while, and attempting restart, the same thing happens again.
Have you tried to use your computer when power charger is connected to power supply? Then try it to check if your computer does not shut down. If do not shut down it self. You had problem with the battery or with charger not compatible with the battery. Normal problem of shutting down computer is that your battery have no charge, your battery is not compatible with your laptop or ever defective. Tr
Jan 10, 2011 | Averatec 3200 Notebook
Can not get the power button to shut down the computer no matter how long I hold it down and the computer appears to stay in hibernation. Will not reboot or do anything when power is applied and power...
Remove the battery and leave off for about 1 minute. Put the battery back in place and press the power button to turn the unit on. immediately after you see system light come on, press and hold the power button and see if it shuts off after a few seconds. If not, then its likely your motherboard is defective.
Sep 07, 2010 | Toshiba Satellite M100 Notebook
I can't shutdown my laptop
Hold the power button down for about five or six seconds, it will shut down then. If it keeps doing this, you need to look at what is running in the background that is preventing you from shutting down via the menu.
click RUN
type in msconfig
take a look at what is scheduled to load at startup and then try to decide if you really need to have that application on all of the time. BE CAREFUL. If you don't recognize an entry, leave it alone until you can learn what it is.
Dec 12, 2009 | Dell Inspiron 1525 Notebook
Conputer won't power on
Hi there.
Remove the power adapter and the battery, plug in AC power and hit the on/off button, if it powers up wait for the OS to load up and the shut it down again, put the laptop battery back in and power it up.
post back with the results please
Good luck and thanks for using Fixya!!
Feb 23, 2009 | Dell Inspiron 8600 Notebook
Presario v2000 stuck in hibernation, can't power it up
remove battery plug in power...see what happens ...nothing happens press and hold power button until you hear response(shut down)press power as usual to boot.if it doesnt work first time try a few times more remember to keep power button pressed to shut down.
Oct 19, 2008 | Compaq Presario R3000 Notebook
Whining usually comes from the hard drive and indicates that it's beginning to fail. Locate the hard drive in your machine, hit the power button, then listen to see if the sound is coming from the hard drive area, if so, then the hard drive is beginning to fail. As far as it failing, it may go the next time you turn it on or it my last for months, hard drives a funny that way.
Jul 07, 2008 | Compaq Evo N610C Notebook
Frozen laptop
According to the manual
Using Emergency Shutdown Procedures
If the notebook does not respond to the Windows shutdown
procedure (Start > Turn Off Computer > Turn Off), try the
following emergency shutdown procedures in the sequence
■ If the notebook is running Windows XP Professional: Press
ctrl+alt+delete. Select the Shut Down button, then select Shut
down from the drop down list.
■ Press and hold down the power button for at least 4 seconds.
■ Unplug the notebook from external power and remove the battery pack.
Apr 14, 2008 | Compaq Presario X1000 Notebook
Computers & Internet Logo
696 people viewed this question
David Payne
David Payne
