My Haier XQJ50-31B splatters what looks like oil on the floor.
My washing machine seems to be splattering oil all over the floor when it spins. The colour of this (oil) went from almost black to a light brown and now the machine sounds like its rubbing when it spins. I am on a tight budget (aren't we all) and cannot really afford to have this looked at by a proffesional, I love to diy and fix alot of my appliances by trial and error, so if this sounds like something I can fix myself I would love to hear from you. Thanks Heaps, Kiri.
SolutionGuy
  • 331 Answers
SOURCE: Oil/Grease under washer machine
Nash, your unit appears to be made by Whirlpool. (Kenmore doesn't manufacture anything, they purchase from major manufacturers and put the "kenmore" name on them) If, as I suspect, it is made by Whirlpool... the top transmission seal is failed allowing small amounts of water to enter the tranny. The water, being heavier than oil, will displace the oil through the top of the tranny... out through a "weep" hole. The weep hole is not designed to allow fluid to escape, it's designed to allow air to enter and exit the transmission housing, compensating for the heat expansion and contraction of the lubricant that should be contained within. Regardless of the manufacturer, you have a main drive system failure on your hands. It'll only get worse from here. Most manufacturers put a 5 year warranty on their drive-trains, you should call them immediately. If it's over 5 years old, it's a very expensive repair.
Posted on Sep 01, 2007
  • 150 Answers
SOURCE: Hoover 700LB top loading washing machine
there should be a wiring diagram on board in an envelope or taped somewhere you can get one from sears too
Posted on May 08, 2008
SOURCE: wont agitate
My washing machine fills up fine, but then when its time to start aggitating and spin's it makes like a metal on plastic grinding noise, We would like to try to fix it ourself but have no idea which part it is. Could you please HELP?
Posted on Nov 14, 2008
SOURCE: washing machine leaking oil
your washer has a transmission and this is what is probably leaking. You might simply need a new seal or the a new transmission. You need a good handyman or contact a repairman.
Posted on Dec 02, 2008
vkufeldt
SOURCE: I have a Haier XQJ50-31b and the display seems to
I tried the hairdryer solution, didn't work for me but a hot water bottle on the buttons over night did!
Posted on May 13, 2009
Cabrio washer wtw5500xw0 loud spin and grease on floor
FIXED Cabrio has loud noise during spin - ApplianceBlog
www.applianceblog.com/.../16339-Cabrio-has-loud-noise-during-spin
Aug 21, 2009 - 10 posts - ‎5 authors
Help Jake I have a Whirlpool Cabrio model WTW6600SW2 it is almost 2 ... a week just started making a very loud noise only during spin sounds like ... size washer (110.297) (loud whirring and grease splatter) and am trying to ...
How to tell if your bearings are bad on a Whirlpool Cabrio ...
? 1:01
https://www.youtube.com/watch?v=5rHn13lKjzc
Jan 19, 2012 - Uploaded by RenewAppliance
http://washerdryerrepairhelp.com/whirlpool-cabrio-maytag-bravo-and-kenmore-oasis- ... My floor under the washer machine hasgrease/oil marks. ... and make the suspension bad when it spinsmine has been like this for about 2 months now ... Noisy WhirlpoolCabrio washer during spin - Duration: 0:54.
Jan 16, 2016 | Washing Machines
Spin cycle extra loud
Good Morning Friend,
I understand that the spin cycle is extra loud in your Frigidaire washer, model# GLWS1233A. I also see that you have grease splattering inside the front and right side panels at the bottom of your appliance.
Certain amounts of clunking or gear sounds are normal in a heavy-duty washer.
If you are hearing any rattling or clanking sounds, there could either be foreign objects such as coins or it could be belt buckles or metal fasteners.
If you are hearing a squealing sound, your washer could be overloaded. Stop the cycle and reduce the load.
Thumping sounds usually means this is a heavy wash load. This is a usual sound, but if it continues, your washer could be out of balance. Stop the cycle and redistribute the wash load.
If you are receiving a vibrating sound, there are a couple of things that could be causing this.
    1)Your washer is not resting firmly on the floor. Make sure your washer is resting firmly on the ground as well as level. You will want to make sure that it is level from front to back, side to side, as well as from corner to corner.
    2)The wash load could be out of balance. Stop your washer and rearrange the wash load.
    With you receiving grease splatters, depending on how much and how often, I suggest contacting your local authorized technician for assistance. They will be able to diagnose your washer as well as determine where the grease is coming from. Hope this is helpful.
    -Best Regards-
    WP
May 22, 2014 | Frigidaire GLWS1233A Top Load Washer
I have water leaking on maytag legacy. 9 years old. getting worse over 3 months. removed front and rear panels, dried out and looked for leaks. only water was on agitator base. im thinking tub bearings and...
Look for splatter signs along all of the inter panels, including the ones removed, splatter marks will be just below the line of the tub. Pleazer Appliance...
Apr 14, 2014 | Maytag Legacy Top Load Washer
Can the bearings and seals be replaced on my Whirlpool Cabrio washing machine?
yes it can be repaired but I am not sure where you can bye the parts from not sure where you live usa / uk if you live in the uk I could tell you where to get them and how to do the job
Nov 30, 2011 | Washing Machines
LG Washer makes LOUD noise when spinning
The main seal is leaking on the drum bearing hence the splatter of soap softened grease The water from the drum is coming through the seal and into the bearing and this is washing the bearing clean of grease. No option than to get it replaced with a new drum bearing kit , Sorry !!
Jun 04, 2009 | LG Washing Machines
Kenmore 23012 / Clothes still wet after spin cycle
Remove end caps from console (put fingers behind top and pull towards you. small flat head may be required). and the 2 phillips screws behind them. Pull console towards you and up, it wil flip out of the way. Unplug door switch connection on top rear right of cabinet (3 wires). Put flat head STRAIT DOWN into brass looking clips and push forward. They'll pop out. Lean cabinet towards you and shine flashlight inside. Look for oil splatter about 8" up from bottom. If there's oil, then the trans has leaked oil into the clutch and it's slipping. Repl. transmition and clutch assy. If you see oil, it's cheaper to buy new washer. Trans and labor is about 400
Mar 17, 2009 | Kenmore 23012 Top Load Washer
Off balance spin cylce
The base of the tub assembly rests on a white plastic ring called a 'snubber'. If any type of lubricant gets in this area, the tub will wobble excessively. The major cause for this issue is a failed transmission where oil has leaked out and into the snubber. The transmission may be warranted for 10 years. Check your owners manual. A good method to check for oil is to tilt the machine back and remove the plastic cover in the center of the pulley, if it contains oil, the transmission is leaking also look at the inside cabinet wall for signs of oil splatter.
If you need further assistance, let me know
Regards,
reg501
Jul 19, 2008 | Maytag Atlantis MAV6000 Top Load Washer
FAULTY WASHING MACHINE
is it a GE or Hotpoint? if so it is the main bearing. the center seal might have leaked water on the bearing.  if you look inside the washer you will see a ring of rust splatter inside the case of the washer. if this is the case than you have to change the transmission or buy a new machine.
transmissions are $200+
Jun 27, 2008 | Indesit Washing Machines
XL1800 Microwave Problem
A LOUD ticking sound could very well be a High Voltage Arc. This is usually caused by a breakdown of insulation on High Voltage Wires, or components. It can also be arcing between the door frame and the cavity. Usually where the bottom of the cavity floor meets the door frame. Indication of this will be small areas on the door where it looks like the paint has been chipped off, but if you look close you will see it is small burned marks. Another area is the Splatter Shield located inside and at the top. It looks like a Plastic Cover. It is not plastic, but a fiber material. Grease, and food will get trapped on and under this Splatter Shield. Over a period of time the grease and food particles will break down from being cooked over and over again. They will then form Carbon. Which will Arc when Microwaves are present. Remove Push-Pins holding Splatter Shield. Clean by washing with dish detergent . If burned (arc) spots are still present after washing, replace Splatter Shield or arcing will continue. Once Carbon has burned through, it will continue to burn.
Jan 21, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Leak in washing machine
can you tell where the water is hitting the belt from is it in the middle of the wash tub or from the outside of the wash tub please let me know if its from the middle of the tub its probably the seal that keeps the agitator from leaking, and if its from the side the in lines from the water spicket or the valve that controls hot and cold in the machine could be leaking, please look closely and try to see where the wateris dripping down from. thank you, then let me know
Dec 21, 2007 | Washing Machines
Washing Machines Logo
41 people viewed this question
Top Washing Machines Experts
