Question about Dell 810 All-In-One InkJet Printer
Dell All-In-One 810 Printer installation problems
My parents recently bought a new machine from Dell, and as this printer was on special offer at the time, they snapped one up. However, I'm having real problems installing it for them. It connects via USB - no problems there, the machine (running XP Home Edition) 'finds' the printer without any problems. It's the driver/software that's causing the problem. I tried installing the software on the CD that came with the printer, but it doesn't seem to have had the desired effect, as no printer information appears in the 'Printers' system screen, and when I try printing anything, all that happens is the document is sent to the MS Office Document Image Writer and is saved to disk (which I suppose is logical, as it is set as the default printer - because the computer doesn't think there *are* any other printers!). I've downloaded the driver for the printer from the Dell website, but as it's basically what's on the CD, that's not helped us any. Every time the machine is turned on, it finds the printer connected once more - but we just can't get the driver installed so we can use it! Any ideas?
  • 3 more comments
  • Dave Cooper Jan 01, 2007
    I'm fairly sure I followed the instructions correctly the first time I tried to install the printer, but since I've had no joy, I tried uninstalling everything and starting from scratch as suggested.
    However: no joy. Even after uninstalling everything and starting from scratch, the installation process doesn't correctly install the printer. Windows comes back every time with the pop-up stating that there was a problem with the installation and the device may not work correctly - even though the installation runs its course and seems to have installed the printer properly. When the PC is restarted, the "Add new hardware" pop up appears as if nothing had happened.
    Someone on another forum suggested running a system restore to restore the PC to its state before I originally tried to install the printer, but System Restore has failed to change the computers setup ("No changes have been made"). So it looks like I'm back to square one!
  • alexstanding Jan 11, 2009
    the program will not uninstall can u help
  • Anonymous Feb 10, 2009
    CANNOT INSTALL THE DIVICE
  • Anonymous Mar 28, 2009
    Not listed in the control panel under scanners and cameras
  • ehrick_32 Apr 27, 2009
    Can't Install the printer
Do you have windows Vista? Sometimes this causes problems with software installation.
Posted on Jun 24, 2008
  • 624 Answers
From what you describe the printer is not installed correctly. I would try uninstalling everything associated with this device, unplugging it and then retry the installation process again. I don't know if the instructions are clear but you should not connect the USB cable to the printer until after the software is installed or when prompted by the software wizard.
Posted on Jan 01, 2007
  • tomj23 Jan 02, 2007
    You?re caught in a loop for sure. I had something similar happen to me a few years ago and it turned out the device was defective. If you can you might try installing the printer on another computer. If the same problem occurs then I would call Dell since its still under warranty.
    President:
  • 2,961 Answers
You generally install the software first, not hardware, so disconnect printer, uninstal any printer driver you already installed. Re-start pc and use the printer installation cd for the driver, run set up programme as directed, then re-connect printer when prompted, it should then be recognised and pop up in your task bar. It should then say 'hardware installed and ready to use' and ask if you wish to set printer as default printer.
  • andrew pester
    andrew pester Jan 02, 2007
    Uninstall the driver again and restart pc.
    Next time your pc finds new hardware and asks for the drivers do not click install automatically, click instead install manually.
    When the next box pops up, insert driver cd click on the radio button 'search in this location' and highlight on the drop down menu your cd rom whether it be your d,e, or f drive.
    Make sure then; that the cd drive whirrs away, this will tell you it's searching in the cd for the driver.
    The found new hardware will change to your printers' manufacturer name and hopefully will be ready to use.
    If you still cannot get it installed, either the cable is faulty or the printer has a recognition fault.
SOURCE:
My dell 810 printer will scan but won't print, i have recently bought a new dell laptop, do i have to change some settings on it?
IF THE LAPTOP YOU HAVE BROUGHT IS A DIFFERENT OPPERATING SYSTEM THEN INSTALL THE SOFTWARE THAT IS RELEVANT TO YOUR OPERATING SYSTEM. (IE XP, VISTA ,WINDOWS 7)
Aug 18, 2010 | Dell 810 All-In-One InkJet Printer
I get a cartridge missing message in a Dell 810 printer
I am having the exact same problem. Just got my cartridge refilled, and whenever I hit the print command, I keep getting the message "printer cartridge missing." It's obviously there! gaahhh, so annoying! I hate dell.
May 09, 2010 | Dell 810 All-In-One InkJet Printer
I got a new computer and it does not have the download for my Dell 810 on it. I no longer have the cd that came with the printer. Do you have a short cut to download so I can use the printer? Thanks
Just copy and paste.
Hope this helps.
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=PRN_ALL_A810&os=WW1&osl=en&catid=&impid=
Sep 21, 2009 | Dell 810 All-In-One InkJet Printer
I have a Dell 810 printer/scanner. Recently my
You need to get the scanner (TWAIN) driver installed. You should be able to download it of the Dell website.
Aug 03, 2009 | Office Equipment & Supplies
BOUGHT NEW DELL COMPUTER. DELL 810 WILL NOT SCAN TO COMPUTER, BUT WILL PRINT WHEN YOU SCAN
My 810 acted up suddenly and just stopped working. It had been ok with a new computer which is now 2 years old. I uninstalled and reinstalled the printer driver. That solved my problems.
Jun 16, 2009 | Dell 810 All-In-One InkJet Printer
Hello
Usually you can download complete drivers and scanning applications from the manufacturer's support web site. I usually throw my CD's away and download the most recent drivers and software off of the site - even when the printer is new the drivers on the manufacturer's site are usually more recent than the ones on the CD.
Jun 25, 2008 | Dell 810 All-In-One InkJet Printer
Dell 810 All-In-One InkJet Incompatible Ink Cartridge error message
Well, first off ,it's dell's fault, not yours. Even Official Dell cartridges are temperamental at best. The cartridge error you are explaining is common with Dells. They even have what's called a marriage issue, meaning the cartridge will work in only one single printer. However, I'm not sure how to fix it. Sometimes, you can install a new one and the other cartridge you never touched gives you fits, and goofs up. I'd say get a new printer. Dell is increasingly getting more stingy with their ink, and truth be told, I don't think their quality (*lexmark makes dell, so stay away from them too) matches HP or canon. If you want the best cost per page, get a canon that has individual ink cartridges. They are easy to refill, and print a great picture. You pay more $$ up front, but you'll save a ton in the long run
Jan 07, 2008 | Dell 810 All-In-One InkJet Printer
New installation 810, printer works A1, scanner won't work
Uninstall and reinstall the software. Normally the software installed on the computer controls the scanner functions for the all in one dell stuff. Check dells site also for any updates that might correct this issue.
Jul 08, 2007 | Dell 810 All-In-One InkJet Printer
Dell 810 All-In-One InkJet Printer Logo
3,378 people viewed this question
Top Dell Office Equipment & Supplies Experts
David Patricia James
Marvin
Marvin
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
