Question about Poulan Featherlite Gas Blower, with Low Emission Engine, 150 M
Quit working during operation
We have tried replacing the spark plug and the Ignition module . Will not even try to start. Doesn't seem like it is getting any spark.3-4 years old...
  • Anonymous Nov 24, 2008
    I have the same problem, I thought it wa a broken fuel line, but it wasn't.
  • 163 Answers
Easy way to find out if its getting a spark is to remove the plug, put it back back in the connector and just let it hang down while you try to start it. you should see a bright blue spark
Posted on Nov 29, 2008
1988 pont 6000 quit and would't restart. Generates 42 code. I have shop manual. Flow chart led to ign. module or ecm. I replaced both. The car idled for 20 min. and quit.
I don't know liter size of engine? I don't know exactly what testing you have done? I need more info?
You have dis ignition? Engine cranking, do you have spark at the plugs, proper fuel pressure and fuel injector pulse?
The purple wire with white tracer from ignition module to computer has a dc pulse with engine cranking? With bypass ignition, engine cranking, it's the ignition module that controls spark, during cranking rpms. Did you check voltage and ground for ignition module. With dis ignition, there is a crank sensor? I'm not saying replace anything. I would have replaced the --spark plugs and plug wires, Possibly the ignition coils.
I just don't know exactly what testing you have done?
If you have already done everything I suggested, then, pardon my post. Just trying to help.
Aug 25, 2017 | Cars & Trucks
Victa v160 runs for a while then stops
Ignition module is failing
Oct 14, 2012 | Garden
I have a 92 Olds Cutlass Cierra with the 3.3 L V6. My daughter drove it to the store and it wouldn't start when she went to leave. The starter worked but the engine wouldn't start. After about 5...
If there is spark out of one coil than its not the crank sensor.
does this have one coil assembly with 6 posts or are there three individual coils?
If it has three individual coils try swapping the coil that works with one that doesn't. If the one that wasn't working now works and the one that was working doesn't than you have a bad module. If the coil that was working still works and the coil that doesn't work still doesn't work than you have a bad coil.
If it has one coil with 6 posts I would replace the coil and the module. It is not uncommon for the coils to go bad and take out the module at the same time.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Aug 19, 2011 | 1992 Oldsmobile Cutlass Ciera
Mower will not start, seems to be ignition problem, engine doesn't even try to fire. checked spark plug and gap, checked ignition switch wire and changed coil pack.
Remember, if all of the safety interlocks aren't "made", the ignition circuit will never "close".
The symptom will be not even trying to turn over.
Gary
Jun 27, 2011 | Garden
Won't start but is getting plenty of fuel. Also has a new spark plug.
Test the spark plug (gapped at 0.020") for blue, snappy spark. If weak or nothing, remove the left side cover to expose the flywheel and ignition module. Turn the flywheel until the magnets are under the poles of the module, insert a thin business card into the pole gaps, loosen the module screws to allow the module to contact the magnets. Tighten the screws and turn the flywheel somewhat to release the card, then turn the flywheel one full turn to make sure the gaps don't close up. Remove the ignition switch wire from the module body, and try for spark again. If nothing, replace the module using the above procedure. If you did get spark, replace the ignition switch wire and try again--if nothing now, look for a short circuit to ground in the wire or the ignition switch. If you got a good spark in the first test, pour a little fuel mix into the plug hole and try for start--if pops several times, you have fuel delivery problems. Check the fuel filter, air cleaner, and muffler for plugging. Check the fuel lines for decay or other damage. Make sure the primer bulb fills with fuel when pumped several times. Does the engine seem to have good compression? Hope some of this helps!
Dec 11, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Hey there,i have a 1991 msuatng LX with the 2.3L ho engine running an 8 plug head. it sounds like i may have a misfire of some sort or my timing may be out but im not sure how to tell, could someone give...
Insert each wire on the proper terminal of the ignition coil. Ensure that the coil boots are fully seated and both locking tabs are engaged. The terminals are identified on the ignition coils. Install wires as shown in the illustration. The 2.3L firing order is 1-3-4-2 for both ignition coil assemblies.
Distributorless Ignition System In the distributorless ignition system (DIS), all engine timing and spark distribution is handled electronically with no moving parts. This system has fewer parts that require replacement and provides a more accurately timed spark. During basic operation, the EEC-IV determines the ignition timing required by the engine and a DIS module determines which ignition coil to fire.
Components
The distributorless ignition system (DIS) for the 2.3L twin spark plug engine consists of the following components:
  • Crankshaft timing sensor
  • DIS module
  • Two ignition coil packs
  • Spark angle portion of EEC-IV
Crankshaft Timing Sensor
The crankshaft timing sensor is a dual hall effect magnetic switch, which is actuated by the dual vane cup on the crankshaft pulley hub assembly. This sensor generates two separate signals, PIP (profile ignition pick-up) and CID (cylinder identification). The PIP signal provides base timing and RPM information, while the CID signal is used to synchronize the ignition coils. Initial timing (base timing) is set at 10 degrees BTDC and is not adjustable. Ignition Coil Packs
Two ignition coil packs are used for the 2.3L dual plug engine. The two ignition coil packs are triggered by the DIS module and are timed by the EEC-IV. Each coil pack contains two separate ignition coils for a total of four ignition coils. Each ignition coil fires two spark plugs simultaneously, one spark plug on the compression stroke and one on the exhaust stroke. The spark plug fired on the exhaust stroke uses very little of the ignition coils, stored energy, and the majority of the ignition coils, energy is used by the spark plug on the compression stroke. Since these two spark plugs are connected in series, the firing voltage of one spark plug will be negative with respect to ground, while the other will be positive with respect to ground. Refer to thePowertrain Control/Emissions Diagnosis Manual for additional information on spark plug polarity. DIS Module
The main function of the DIS module is to switch between ignition coils and trigger the coils to spark. The DIS ignition module receives the PIP and CID signals from the crankshaft timing sensor, and the SPOUT (spark out) signal from the EEC-IV module. During normal operation, PIP is passed on to the EEC-IV module and provides base timing and RPM information. The CID signal provides the DIS ignition module with the information required to switch between the coils for cylinders 1 and 4 and the coils for cylinders 2 and 3. The SPOUT signal (from the EEC-IV) contains the optimum spark timing and dwell time information. The dwell time is controlled or varied by varying the duty cycle (duration) of the SPOUT signal. This feature is called CCD (computer controlled dwell). Therefore, with the proper inputs of PIP, CID and SPOUT the DIS ignition module turns the ignition coils on and off in the proper sequence for spark control. CID is also sent to the EEC-IV micro-processor to allow for Bank to Bank fuel control. Failure Mode Effects Management
During some DIS system faults, the Failure Mode Effects Management (FMEM) portion of the DIS ignition module will maintain vehicle operation. If the DIS ignition module does not receive the SPOUT input, it will automatically turn the ignition coils on and off using the PIP signal. However, this will result in fixed spark timing (ten degrees BTDC) and a fixed dwell time (no CCD). If the DIS ignition module does not receive the CID input during engine cranking, random coil synchronization will be attempted by the module. Therefore, several start attempts (cycling the ignition from OFF to START) may be required to start the engine. If the DIS module loses CID input while engine is running, the module will remember the proper firing sequence and continue to fire to maintain engine operation. Dual Plug Inhibit
Dual Plug Inhibit (DPI) is a function of the EEC-IV that is only used when the vehicle is being started at temperatures -7° C (20° F) and below. During engine cranking, the EEC-IV will only fire the spark plugs on the right hand side of the engine. When the engine has started, the EEC-IV will send a signal to the DIS module to start normal dual plug operation. Ignition Diagnostic Monitor
The Ignition Diagnostic Monitor (IDM) is a function of the DIS module. The DIS module sends information on system failures to the EEC-IV which stores the information for diagnostic self test. The IDM signal also is used to drive the vehicle instrument tachometer, and test tachometer for system
Nov 19, 2010 | 1991 Ford Mustang
I have a 1982 lincoln mk v. It wont start. I replaced the Ignition spark module and the coil . I even used starting fluid to see if the problem was fuel. But it still wont start.Please help.
Make sure it is not firing.Since you installed the ignition module,the plugs may be fouled out by fuel.If so,replace the spark plugs,and it will start.If there is no spark,the stater in the distributor will be the most likely problem.The stater is the other part that goes out,if the ignition module doesn`t.I hope this helps,let me know if I can help you any more.
Oct 25, 2009 | 1983 Lincoln Mark VI
'99 Saturn SC1 with intermittant check engine light P0341
a p0341 code mean cam reference performance, really it means you have a secondary ignition problem,,,,like a bad ignition module
a bad crank sensor
a high resistance spark plugs,do not use bosch platinum plugs in these cars
high resistance spark plug wires,,,i work at the dealer and the first thing we do is replace the spark plugs and wires if that dont work we replace the crank sensor,if thatdont work we reaplce the ignition mondule,and by then your fixed and you started with the cheapest items first,,,i would try plugs and wires and a crank sensor,,,,wires $50 plugs $14 crank sensor $37
Oct 23, 2009 | 1993 Saturn SC1
No spark on 1988 s-10 pickup 2.8 new plugs,wires coil,cap and rotor.ran for about 20mins and then quit,wont start
It could be that the ignition module is defective and causing this problem.If it's the original ignition module it may be time to replace it. The ignition module can be tested by your local Shucks or Auto Zone usually for free, The module when its starting to go out will work fine until it warms up, it will then quit working because the coils inside of it short out, until it cools down. If the module is completely gone there will be no spark at any time, The module is inside the distributor under the rotor held in by a couple of screws,
Jul 21, 2008 | 1997 Chevrolet S-10 Pickup
Poulan Featherlite Gas Blower, with Low Emission Engine, 150 M Logo
184 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
roeb
Are you a Poulan Garden Expert? Answer questions, earn points and help others
