Question about Sharp Aquos LC-30HV4U 30 in. LCD HDTV
Mono sound only
I just purchased a Sharp AQUOS LC32D64U HD TV and I have two problems with sound (I am using the TV speakers not external ones). The first problem is that I only get mono sound not stereo. The second problem, which may be related to the first, is that even at max volume, the sound is not very loud. My TV feed is satellite.
I have an LC42D64U with firmware U0709111. This is an 11 month old unit. It was working fine until I lost power one day, then I couldn't get any sound. It always showed up as Audio: mono. I tried every setting and nothing (although XBOX via HDMI still played though the onboard audio, so I knew it wasn't a HW issue).
After searching around for a method to change the mono/stereo I resorted to the Fred Flintstone's fix and simply pulled the plug on it. Immediately after turning it back on it worked.
This is hardly a fix but it worked for me.
Posted on Dec 10, 2008
No sound on my sharp aquos lc-45gd4u 45 in
Assuming you are using the internal speakers, check and make sure you have the audio enabled. Some TV sets have a option to turn off the internal speakers. Also make sure mute isn't turned on. If you are using external audio setup, double check your connections.
Nov 24, 2012 | Sharp Aquos LC-45GD4U 45 in. LCD HDTV
I'm trying to connect external speakers to a Sharp Aquos LC-C3234U TV but not having any success. Can anyone help?
Apperently this tv has a history of sound board related problems. So if you are trying to connect external speakers because you have no sound from the set then you still will be sound-less. On the other habd if you just want more sound then I would suggest using a surround sound system which will readily connect to your set.
Oct 31, 2012 | Sharp Televison & Video
How can I connect my altec lansing speakers/bass to my sharp tv? I currently connected it via a wire that feeds from the altec lansing to the tv in the audio input. I am using HDTV and am trying to get...
Probably won't work. The audio amplifier in the TV isn't strong enough to connect external speakers. It would be best to use a sound bar using the optical connection.
Jun 17, 2012 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
How to update sharp aquos lc32d64u firmware. won't read from usb device to update S0803271 to S0909081. firmware name is "SAL2A217.UVP"
I was able to successfully update my Sharp's firmware by using a USB drive that was:1) formatted in (fat, not fat32)2) had only the one update file (.uvp) and3) a small USB drive (4gb - other posts said 2gb or less)
Feb 08, 2010 | Sharp LC-32D64U LCD TV
Good picture, no sound. you can turn the tv on and off and eventually the sound will come on? tried bypassing the hd digital box, still didn't work.
hi first of all u should check ur transistor connections.Check your Horizontal and vertical output transistors.You should also check the horizontal and vertical yoke connections as well as your low voltage regulators.... if any of these got damaged u should purchase a new one.. but try to purchase with the help of a tv service assistant...thank u!!!
rate me
Jun 11, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
External speaker hook-up possibility
Yes, its absolutely possible. You can connect external speakers from analog output of TV. Even you can use AV receivers available in the market which can be used to amplify OR process the tv sound with latest digital processing techniques, it would be very much pleasant than the sound from tv.
--Sandy
May 26, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Speaker distortion on SHARP 37" Aquos Hi Def
When you are changing channels you are using the tuner of the sat reeiver. the tv does not know you are changing a channel . It is just receiving a constant signal from the SAT receiver. I would suspect a problem with the receiver. Try another one first .
Apr 24, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Sharp Aquos LC-32D44U stuck in ""Mono"
I dont know if this will work for you, but its worth a try. I had the same problem.
1. I changed to a station that was having the problem (an analog station with MONO displayed on the screen).
2. I unplugged the TV for about 15-20 minutes. (I was thinking maybe something needed to refresh, so thats why i unplugged the tv.)
3. I plugged the tv back in and voila. The station showed up as MONO then immediately swtiched to STEREO.
After that, i was able to use the AUDIO feature on the remote to actually change from MONO to SAP, etc.
Ive had my Sharp for about 5 months now, and thats the first time its happend to me. Luckily, i solved the problem...this time.
Hope it helps.
Feb 12, 2009 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Sharp Aquos rattling bass
the sharp some models dont put a spacer between the speaker and the case causing the speaker to hit the case at med to high volume you can check this and make you a spacer out of washers on each screw that mounts the speakers between the case and peaker frame make sure that the washers or spacers you use dont contact the speaker core. and dont do anything that will void the warrenty if nothing else let the store fix it.
Dec 12, 2007 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Audio Problems with Sharp Aquos T. V.
Just talked to a fellow at Audiotronics regarding Sharp Aquos.
This is a widespread problem with audio on their TV's, The tech. said there may be a full recall regarding this problem!!!
Nov 10, 2007 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Sharp Aquos LC-30HV4U 30 in. LCD HDTV Logo
280 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
