Question about Lenovo 3000 Y410 Notebook
CD-Rom Drive is not working properly....may be registry problem??
CD drive
  • sweetoo_nice Nov 20, 2008
    thanks but i need more help
    Sergeant:
  • 237 Answers
I need some more info, all i have is your opinion. what are the symptoms?
Posted on Nov 20, 2008
  • zabrina liang Nov 20, 2008
    Why is it not working properly? not reading discs? not recognizing discs? not recording? Please elaborate just a little---not too much because then it might get confusing=)
    Genius:
  • 1,913 Answers
Open cpu reatthc power cable and data ide cable.
theh if not works may be uyour lense is not working properlyt in cd rom
I have an Acer Aspire 5332 and the CD-Rom/DVD Drive (Optiarc DVD RW AD-7580S ATA Device) is not working properly...every time I put a disk of any kind (i.e CD/DVD/Game) it doesnt recognize it and load
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps you
Mar 22, 2012 | Acer Computers & Internet
Tip
Recognize that your cd is a burner
To resolve this issue, edit the Microsoft Windows registry to identify the CD-R drive or CD-RW drive as a recordable drive. To do this, follow these steps.WARNING: If you use Registry Editor incorrectly, you may cause serious problems that may require you to reinstall your operating system. Microsoft cannot guarantee that you can solve problems that result from using Registry Editor incorrectly. Use Registry Editor at your own risk.
1. Click Start, and then click Run. 2. In the Open box, type regedit, and then click OK. 3. Expand the following registry subkey: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\CD Burning\Drives 4. On the File menu, click Export. 5. In the File name box, type backup of drives key, and then click Save.
Note You can restore this registry subkey by double-clicking the backup of drives key.reg file that you saved. 6. In the left pane of the Registry Editor window, click the Volume{GUID} folder under Drives, where GUID is a 32-character hexadecimal globally unique identifier.
Note If you have more than one CD-ROM drive in the computer, an additional Volume{GUID} folder is listed for each drive. 7. In the right pane of the Registry Editor window, double-click Drive Type. 8. In the Value data box, type 1 or 2, depending on the drive type, and then click OK.
The drive type should be 1 if it is a CD-R and 2 if it is a CD-RW. 9. Quit Registry Editor. 10. Click Start, and then click My Computer. 11. Under Devices with Removable Storage, right-click the CD-R drive or CD-RW drive, and then click Properties on the shortcut menu. 12. If the Recording tab is displayed, Windows recognizes the drive as a recordable device. 13. Click Cancel.
Note If you have more than one CD-ROM drive, DVD-ROM drive, or CD-RW drive in the computer and the Recording tab is not displayed, an incorrect drive may have been configured as "recordable" in the Windows registry. To troubleshoot this issue, follow these steps: a. Follow steps 1 through 9 to edit the Drive Type value of the Volume{GUID} folder whose value you previously changed. b. In the Value data box, type 3, and then click OK.
The drive type value of 3 indicates that the drive is a standard CD-ROM and is not writable. c. In the left pane of the Registry Editor window, click the next Volume{GUID} folder. d. Follow steps 7 and 8 to change the Value data entry to 1 or 2, depending on the drive type. e. Quit Registry Editor, and then follow steps 10 through 12 to confirm that the Recording tab is displayed in the properties dialog box of the CD-R drive or CD-RW drive.
on Jan 05, 2010 | Computers & Internet
My cd was not reading properly.... i am cont to view mt data on cd dreive position
make sure that the cd rom is getting enough consistent power test all leads that are attached to the cd rom including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd rom then plug them back in this will activate found new hardware wizard
hope this helps or
you might have to uninstall then reinstall your cd rom or uninstall the driver then reinstall for this device
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Jan 14, 2011 | Sony (SONBLACK52XROM) CD-ROM Drive
***** problem? it wont be recognized by compute, why oh why??? can you please help
try to change ur jumper setting of ur cd rom drive,set into master mode or slave mode! and try to change ur cd rom cable also.. check ur bios if ur cd rom drive is enable.
Jun 19, 2009 | Toshiba (P000242100) Internal 14x CD-ROM...
Acer aspire 5520 cd rom drive is missing
use this tool to reset the cd in the registry
after you run the file - reboot the computer -
http://www.dougknox.com/xp/utils/XP_CD-DVD-Fix.zip
May 05, 2009 | Acer (99.B0311.002) Internal 50x CD-ROM...
Compaq drive array (non pnp) can't start/does it effect cd/rom
im it is not hard for you to reformat your computer,it will be easy to work..because it is conlict in the registry.. i had the same problem.i format my pc and my cd drive work fine..
Mar 03, 2009 | Computers & Internet
Drive not showing in WinXP (error code 39)Liteon Combo SOHC-5236v
After loading the Windows, the DVD/CD-ROM drives work properly, but we can not see the drives in “My Computer” (System can not recognize the drives.). When try to run the drives, it shows up a notice “Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code39).” Before solving this error, check the drives connection correctly, then follow the steps below:
Delete Device Manager. Most people will firstly think of Windows “Find New Hardware” when drives missed, but it does not always work out. To fix the problem: open “My Computer”’ “Control Panel” ’“System”’“Device Manager”’ “HDC(Hard Disk Controller) ”, then click “Delete”. Follow the note to reboot computer. After rebooting, the computer will find the Primary IDE Controller and Secondary IDE Controller again and install the drivers. Restart the computer again while the installation is completed. In this, we can get back our CD/DVD-ROM Drives.
The other way is by editing the registry to return the missed CD/DVD-ROM drives (Code 39 error.). Obviously, it is too risky to edit the registry if you are not familiar with it. To fix the error from the registry, carry out the following steps:
Exit and close all applications currently running on your PC.
Step1. Click Start > Run and type in Regedit, press Enter.
Step2. Look for the following registry key:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\ {4D36E965-E325-11CE-BFC1-08002BE10318}
Delete any of the following registry entries under this key directory:
LowerFilters
LowerFilters.bak
UpperFilters
UpperFilters.bak
Step3. Reboot your PC and open My Computer to check that the CD-ROM drive is visible.
Also, have a look at the Device Manager to see if the yellow exclamation mark and the error code 39 are gone.
System errors are not welcome guests that bring up unhappy computing experience. Registry Easy (www.registryeasy.com) is a professional troubleshooting system maintenance tool that can help you to solve this error and many more.
Article Source: How to fix DVD/CD-ROM drives (Code 39 error) in Windows XP or Vista
Posted on 2 January '09 by , under TECH NEWS.
This worked for me.
Feb 12, 2009 | Lite On (SOHC5236V) CD-RW/DVD-ROM Combo...
My pc
Replace the drive is the only thing you can if you are sure the drive is not functioning.
Jun 11, 2008 | LG CRN 8245B (CRN-8245B) Internal 24x...
Lenovo 3000 Y410 Notebook Logo
136 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
