Question about Garden
Push rods bending
Bent two push rods in june and again in late sept. sitting on the tractor on the left side. a friend told me that their have been problems the 25 hp. engine bending push rods. the tractor is 8 yrs. old. i changed oil and filter every 100 hrs. like the book says.
  • 1 more comment
  • gossett501 Nov 22, 2008
    the engine is a 25hp briggs and stratton engine. model no. 445777 and the type is 0154-e1
  • Backlash465 Feb 01, 2009
    I have the same problem. My engine is on a Poulan riding lawn mower. I noticed it had no power all of a sudden. With the blades turned on the motor work choke of. I pulled the cover and found the top push rod bent and the bottom one had dropped loose from the rocker arm. How do I fix it and what do I do to stop it from happening in the future?
  • chris killeen
    chris killeen May 11, 2010
    what is the engine make please? A model number would be great as well. thanks.
  • 95 Answers
SOURCE: 24 hp engine. one bent push rod, second rod
This happened to me,the engine sat for some time and the valves were varnished with stale fuel,they stuck in the guides.This bent the push rod and it was only running on one cylinder.The missing push rod worked its way into the crankcase through an oil passage . I took the engine sump of and found the push-rod. I cleaned removed the head,cleaned the valves and guides replaced push rods and gasket and it ran fine after that.I use fuel stabilizer now,it keeps the varnish from forming.
Posted on Jul 31, 2009
  • 57 Answers
SOURCE: Need to Change the oil
On most likely the right side of the engine is where you will find the oil drain. It will likely be in the form of a pipe with a cap. On most of these models the will not be an oil filter. Briggs and Stratton recommends SAE 30 engine oil. Also log on to mtdproducts.com and you should be able to download an operators manual. The model and serial # are located under the seat.
Posted on May 18, 2009
  • 21 Answers
SOURCE: 24 hp engine. one bent push rod, second rod missing
just found the same problem on my father in laws mower (24 hp briggs) I took the engine off of the mower, drained oil, turned on its side and removed lower case. There was the missing pushrod wraped around the camshaft gear. no clue on how in the hell it did that! It also ended up breaking the govenor (quick look) will look for more damage tomorrow.
Posted on Jul 27, 2009
moretons
  • 155 Answers
SOURCE: oil capacity for 14.5 hp briggs engine
That would be 1.2lt to 1.4lt from empty
Posted on Aug 12, 2009
  • 61 Answers
SOURCE: No spark in JD lawn tractor engine
it could just stuck, loosen see if moves reset points.
Posted on Sep 07, 2009
What would cause both pushrods on left cylinder to bend
One ting that cause a push rod to bend is a valve guide that work it way out causing bottoming the spring travel. I haven't seen this person but work with others on finding the problem.
It is strange that both bent would be bent; although a valve that broken free could this too. Since OHV valve guides are generally not available as a replacement part the only solution is to replace the head.
May 27, 2015 | Garden
One cylinder bends push rods
Sounds like you're timing is off this unit have a timing belt or timing chain it might've jumped to the valves may be opening two early or too late hit in the Pistons
Sep 10, 2014 | Husqvarna 23hp Briggs & Stratton 48-inch...
Craftsman lawn tractor
Hi, had it been sitting some time unused?
Sounds like the valves are stuck in their seats and the rods bent when the motor pushed them with the cam.
You might be lucky and the one that fell in didn't get into the works.
Make sure you fish it out before doing anything else.
I'm guessing it is the typical side valve type motor?
Remove the valve cover (I guess you have already to get the push rod out) and using some sort of lever try and move the valves up against against their springs. Don't bend them with sideways pressure though. If they're stuck some CRC / WD40/oil or similar will help to get them moving. Remove the spark plug and spray CRC etc onto the valve heads inside the cylinder.
Assuming the push rod hasn't contacted anything moving while the motor was being wound over and done more damage, you should be good to go with new push / 2nd hand push rods. Just check there is some clearance between the push rod and the valve stem when each valve is closed.
Oct 09, 2013 | Craftsman Garden
Where is the spark plug on the 2011 honda ruckus?
Under the spark plug cap on the left side of the motor (left side while your sitting on the machine)
http://vimeo.com/2402295
Oct 09, 2012 | 2011 Honda Ruckus
Last december we went to adjust the valves for the first time and there were no push rods installed on the left side. We installed new push rods and it has run great until now. Sept. 2010. both push rods...
Happened to me also, seems a very common problem on B&S V twins. Reading on the web leads one to conclude that poor design and ever worsening gasoline quality are the culprits. I usually run a midgrade or high octane gas in my mower, when I bent my rods I had just put in a tank of the Duke & Duchess low rent stuff. Also I could not help but notice that the replacement rods from B & S were much heavier duty than the ones I bent.
Sep 21, 2010 | Garden
18 Hp OHV Briggs and Straton craftsman tractor. Has 1 alumium push rod and 1 steel. Alumium keeps bending twice now. Has worked fine for six years
i have about the same engine and mine will not even start, although i've used starting fluid and have spark on the plug still it will not fire up. if the rod is bent will this keep my engine from trying to start(fire) please respond to savannah_316@netzero.com thanks.
Jul 22, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman Lawn tractor - When turning to the left the Left front wheel turns much farther then the right front wheel does on a hard right turn. Almost perpendicular to the tractor. Busings are brand new....
I've noticed this on other Craftsman and MTD mowers. The ones with the one main steering rod from the steering wheel to the left wheel and a connecting rod from the left wheel to the right wheel. I think that since we are advised to mow in a counter-clockwise direction, they design the mowers to turn tighter towards the left. It's in the design just like you suspected.
Apr 18, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My 24hp Briggs and Stratton ohv engine has bent push rods on one side. The top valve can be pushed in but the bottom one will not push in. Is the valve stuck in the open position? If so how can it be...
unable to answer if valve opened or not but does sound like ur bottom valve is bent or piston made contact and bent it to fix need to remove head and replace valve also need to inspect piston face is not damaged from possible contact
Apr 12, 2010 | Craftsman 24 Hp 48" Deck Yard Tractor
I have a Husqvarna YTH 2348 the deck anti sway bar came looses fell of frame and bent, I removed rod strightened and need to kown how to put rod back in proper location on the frame and deck bracket
Once you've straightened it - you've finished the hard part. Now take the end without the pin and stick it into the hole located on the transmission frame (the metal piece that the transmission sits on.) It is directly under the seat. The hole is on the front side of the tranny frame. Once you have it all the way in, take the pin end and put it through the mower deck brace (right side.) There is a hole there also for this end. If it doesn't go through enough to get the washer and pin through, push the mower deck towards the anti-sway bar. It should give a lot since the anti-sway bar is off. Once you fasten it, your'e done!
I only know this because it just happened to me today. I have the same mower as you, so I thought I would share.
Jun 04, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Recurring bent push rods/knocking engine- ideas?
I have seen this myself on a 3.4L (2.8, 3.1, 3.4, 3.5 & 3.9 are all mechanically the same engines). The valves may have a varnish build-up on their stems causing them to stick in the guides.
Apr 26, 2009 | 2000 Pontiac Grand Prix
Garden Logo
300 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
