Question about Fossil Watches
I had the battery changed on my water-resistant watch by a jewelry store and now the watch leaks. i no longer wear it around water but it keeps stopping. the watch was a xmas gift in 2006 and i had no problems til the back was taken off by the jewelry store.is it still covered by the warranty?
    New Friend:
  • 161 Answers
Take it back to the jewelry store and explain what happened. Be nice but firm.
Posted on Nov 20, 2008
Missing screw to hold band together need replacement
Most jewelry stores--or even jewelry counters in department and discount stores like Walmart--keep a supply of replacement screws for when one is lost while changing a watch band. Ask around, show them your watch, and you may even get the right screw for free!
May 06, 2011 | Field and Stream F187GWBS e by Field &...
Tip
Changing a watch battery.
If you don't have the proper watchmaker's tools (and you'll need several!) I recommend that you not do this yourself. You could scratch the case or damage the movement if you don't know what you're doing. If it's a water resistant watch the gasket also needs to be replaced once it is opened. DO NOT reuse a gasket! For about $8 any watch or jewelry2_bing.gif store can change the battery and renew the gasket for you. Most Sears stores will do it while you shop.
on Apr 15, 2010 | Watches
How to prevent water leaking inside,after replacing the batteries.. should i replace the gasket to? after replacing the batteries....
Normally gasket has not to be replaced after battery change.But all depends of the use.For example if you wear the watch in salt or pool water and never flash it with fresh, clean water after,it may be a cause of gasket wear.Remove the back cover.Replace all 4 batteries(be sure first that you can do this with extreme caution as all parts are tiny).Remove gasket.Check gasket condition(cracks,gasket too dry and hard).If gasket OK, apply a small amount of special silicon compound for watch gaskets,all around and to all sides of the gasket,put it back in place,carefully.Be sure that gasket is set correctly all around.Put the back cover in place and screw with much caution (not too tight-a little resistance).Your watch now normally is water resistant.But if you want to be 100% sure,take the watch to a serious repair center where it will be tested under pressure ( 3 Atm average).Then they will tell you if your watch is 100% water resistant.
Oct 11, 2010 | Casio PRG-40T-7 Pathfinder
I can't open the back of my watch to put a battery into it
If you don't have the right tools don't even try - you'll risk damaging your nice watch. Instead, take it to a watch shop or jewelry store (Sears does it too) and let them do it with the right tools, correct battery and - very important - a new gasket to keep it water resistant. Cost for the battery replacement is about $8.
Apr 28, 2010 | Seiko Pulsar Europa Ladys Size PXQ495...
How do u change the battery in a 5.11 watch i have a 5.11 field ops watch, was told i had to send it in to be replaced, i dont feel that its necessary how do i do it?
Take it to a watch shopor jewelry store and they should be able to do it for about $8. If you do it yourself you'll need some specilaized tools to asvoid damaging the watch and a new gasket for the caseback to keep it water resistant. The old gasket cannot be reused even if it looks ok. Once the gasket has been compressed it will leak if reused.
Apr 24, 2010 | Watches
How do i get the back off to switch the battery off my freestyle cortez watch
If you don't have the proper tools I recommend that you not do this yourself. You could scratch the case or damage the movement if you don't know what you're doing. If it's a water resistant watch the gasket also needs to be replaced once it is opened. DO NOT reuse a gasket! For about $8 nay watch or jewelry store can change the battery and renew the gasket for you.
Apr 12, 2010 | Freestyle Cortez Mid Watch
How do I open Kenneth Cole watch KC 3567 to replace battery?
If you don't have the proper tools I recommend that you not do this yourself. You could scratch the case or damage the movement if you don't know what you're doing. If it's a water resistant watch the gasket also needs to be replaced once it is opened. DO NOT reuse a gasket! For about $8 any watch or jewelry2_bing.gif store can change the battery and renew the gasket for you.
Apr 11, 2010 | Kenneth Cole 1213 Wrist Watch
How to change the battery in the 01 binary watch model ZE-102-B2
Apr 11, 2010 | Watches
How do you open a DKNY 3423 watch?
Apr 11, 2010 | Bulova Watch
To change battery
Apr 10, 2010 | Casio OC500 Oceanus watch
Watches Logo
409 people viewed this question
Top Fossil Watches Experts
Jimmy Accardi
EugenesDIYDen
EugenesDIYDen
Are you a Fossil Watch Expert? Answer questions, earn points and help others
