Question about Rainbow 75th Anniversary Canister Vacuum
Powerhead on rainbow not working
The powerhead gets power - wires all connected- nothing appears broken yet the beater bar is not turning.
  • lauraguenthe Nov 25, 2008
    You wrote
    the motor is NOT running - press the red button on the nozzle (assuming you have the model with the button on the nozzle)
    If it stops working as soon as you release the button -
    Did you mean if it STARTS working as soon as you release the button?
    The only time its pushed is if its not working. ?
    Belt is a new replacement.
  • 701 Answers
The belt may look fine but it still might be stretched and therefore the brush won't turn against the resistance of the carpet. You can get the replacement belts here:
http://vacbelts.com/rainbow-power-nozzle-belt.htm
Posted on Oct 25, 2009
  • Rainbow Expert
  • 324 Answers
If the motor is NOT running - press the red button on the nozzle (assuming you have the model with the button on the nozzle)
If it stops working as soon as you release the button - you need a new circuit breaker. If Motor in the nozzle works but brush does not spin - you have to replace the belt.
Good Luck
Posted on Nov 25, 2008
Brush on rainbow will not turn but motor does because it burns the belt
Could be locked up beater bearing. remove beater bar and turn bearing by hand ro see if that is the problem. turn shaft on motor to see if that is locked up.
Jul 20, 2014 | Rainbow E series Canister Wet/Dry Vacuum
I have power and air suction, but the beater will not turn and the belt is fine.
Check that you are getting power to the brush roll motor. Many Rainbows have a reset button on the power head.
Jan 31, 2014 | Rainbow Vacuums
Belt no longer turns the brush
JKGonzo:
You'll need to open the vacuum head and remove the beater bar. Clean up the bearings at each end of the beater bar and reassemble the head.
May 25, 2013 | Rainbow Vacuums
Rainbow series E vacuum beater bar circuit won't reset.
The breaker is bad. It will need serviced by an authorized dealer. The E series powerhead is notorious for this issue.
Dec 20, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Power head turns on and off as the unit is vacuuming
Probably not hose but more then likely is a problem within your wand. Try connecting your hose handle directly to your powerhead and see if you can get consisten power. I work in customer service for electrolux and more then likely it is in fact the wand
Jul 17, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Hoover Elite Rewind - powerhead brushes are not turning
most likely band is broken. Usually there is a spare in the box or on the unit when new. Unscrew 2-3 screws by beater bar (brushes) pull off cover and replace band.
Jul 09, 2009 | Hoover U5507900 Elite Rewind Bagless...
Hoover 5470-900 no longer contacts carpet with beater brush
your floor adjustment spring is broken there is a plastic slider and clip if it is broken the height adj will not work you should get a new vacuum because this repair can cost as much as a new vac.also this is a common problem with the hoover brand I would get a sebo or an oreck they have a great warrentty and you will more than likly never buy a other vac.
Jan 24, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Brush does not turn on my vaccum
If there is no suction when you disconnect the beater bar assembly near the hand hold where you grab the vacuum, then there may be either a restriction in the vacuum line between there and the vacuum section (that rolls around behind you), or the vacuum line from the handle point to the rollaround section is not properly connected. This all assumes the vacuum motor in the rollaround is running.
The beater bar section does nothing but cause dirt particles to be sucked into the vacuum system. The vacuum or suction is created in the rollaround unit.
Jan 22, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Beater bar brush stopped working...
Does the power head motor stop, or does the brush roll stop. If it is the brush roll stopping, replace the belt and/or the brush roll. If it is the motor, you may need to clean out around the motor, it may not be getting enough air to cool causing it to overheat and stopping. That the brush roll plate off, take out the screw, and the top will come off, then you can check to see if cleaning is the answer, if not, the motor may be bad.
Jan 12, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow 75th Anniversary Canister Vacuum Logo
1,164 people viewed this question
Top Rainbow Vacuums Experts
Jim Parker
Jim Parker
Chris Nomland
Chris Nomland
Are you a Rainbow Vacuum Expert? Answer questions, earn points and help others
