Question about Epson Stylus 880 InkJet Color Printer
Epsom 880 stylus stopped printing
It sounds like it's printing,nothing but blank pages.I purchased a cleaning kit,nothing,tried all the tricks,unplug,pull cartridges,then plug back in and install them so they would b primed,nothing.Tried all the utilities many times,nothing.Should I just dump it?Oh,I also tried installing new cartridges.Thanks and help.
  • 1 more comment
  • Kdizzle79 Jan 01, 2009
    My printer is doing the same thing I don't need ink I just took the cartridges out and pressed them out and  they had ink come out. They still have the plastic on the bottom where the holes are. What should I do?
  • Anonymous Jan 10, 2009
    Replaced ink and now all sound and no print. Tried all the utility programs several times to no avail.
  • john milligan May 11, 2010
    did you pull ALL of the tape from the top of cartridges?
    OR
    if using off-brand cartridges, did you poke the bottom holes (if instructions said to!)
  • 514 Answers
Did you pull ALL of the tape from the top of cartridges?
OR
Posted on Jan 11, 2009
Epson Color Stylus 880 not printing, blank pages only
With some printers they need to be the recommended brand of ink cartridge. Are you using Epson's own cartridges? If not might be worth changing to them. It sounds as though the issue is with the cartidges and not the printer itself. Hope this helps.
Oct 28, 2016 | Epson Stylus 880 InkJet Color Printer
Epsom NX130 wont print after replacing new ink cartridge. Have taken all out turned off power. Not working
Does it try to print, but the page is blank, or does it simply sit there?
If it tries to print, but nothing comes out, you may have a clogged print head.
If it doesn't even try, did you use a genuine Epson cart, or an after market? Epson printers won't print if even one cart is empty.
May 02, 2015 | Epson Stylus Nx130 Mfc Inkjet
Have just installed new ink to my Epsom Stylus sx215 but wont print, just blank pages
Do a "nozzle check". Do you get anything?
Did you remove the tape pull-off tabs that let ink flow?
If you get nothing or very little with the nozzle check, and you did remove the tabs. do a "head clean" and try again.
Feb 14, 2015 | Epson Stylus Office Equipment & Supplies
I changed the black ink cartridge but the printer prints blank pages. I have tried cleaning the printer but no luck. What can I do? (epson color 880)
reinstall your driver also check for driver updates
once unistall the driver from the system and restart and install it again and try
Mar 08, 2011 | Epson Stylus 880 InkJet Color Printer
Have an Epsom stylus color 440. will not print
I'm trying to do a print nozzle check on my Epson Stylus Color 440 printer that I have but a pop-up box say "Error, can't print". Why is this?
Oct 06, 2009 | Epson Stylus Color 440 InkJet Printer
My Epson Stylus 880 suddenly started printing blank pages. Can you suggest what would make all print heads stop working at the same time
Hi,the ink are they genuine,try head cleaning and check the nozzle.if's not then the logic board cuold have gone faulty or the print head.
Jul 01, 2009 | Epson Stylus Color 880i InkJet Printer
I replaced both ink cartridges for the printer, won' print.
Please follow the procedure your printer has which forces it printer to clean the print heads.
I have experience of other epson stylus models.  I have previously spoken to epson about this exact problem.  Repeating the head cleaning process a minimum 5 times cleared the problem.
Running head clean multiple times in succession builds up pressure in the print heads - causing (usually new) cartridges to work correctly.
kind regards
Jan 27, 2009 | Epson Stylus 880 InkJet Color Printer
Prints blank pages
make sure u have the printing options from printer settings set to black only and not colour..
Sep 09, 2008 | Epson Stylus 880 InkJet Color Printer
Epson Stylus Photo R220 InkJet Problem
this sounds like ur both cartridges are empty...
Jul 28, 2008 | Epson Stylus 880 InkJet Color Printer
Epsom stylus all in one dx7450
press 'Control' + 'P' on a page (as tho you want to print)
click 'Maintenance'
there you'll find various options to clean heads etc, that should do it. tho it does deplete your inks considerably each attempt. & you'll probably find it needs more than one clean.Good luck!
Jun 08, 2008 | Epson Stylus Multifunction Inkjet Printer/...
Epson Stylus 880 InkJet Color Printer Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
